Old Mar 22, 2004, 11:35 AM
csisfun is offline
Find More Posts by csisfun
Balsa!!!
Singapore
Joined Sep 2003
SF, E, HD props differences
OK, so I've seen these propellers around my LHS. There are 2 sorts of GWS propellers, one which is the SF style which is like the ones made by APC, and the other ones HD & E propeller are the ones that look like they are used in gassers.
But what is the difference between these an SF, E, and HD propeller? And what does HD stand for?
csisfun is offline Find More Posts by csisfun
Old Mar 22, 2004, 11:46 AM
TRP is offline
TRP
Find More Posts by TRP
TRP
TRP's Avatar
United States, CA, Morgan Hill
Joined Jun 2002
Heavy Duty?
TRP is offline Find More Posts by TRP
Old Mar 22, 2004, 12:26 PM
thunder1 is offline
Find More Posts by thunder1
College Park, MD
Joined Sep 2002
SF = APC SlowFlyer (geared electric)
E = APC Electric (direct drive glow/electric)
RS = GWS Reduction Series (geared electric)
HD = GWS Hyper Drive (direct drive electric)
In general the SF and RS props are intended for geared applications. They are optimized for the highest thrust at slow RPMs APC lists the SF props as being useful for 65000/diameter. So a 9 inch SF prop has a practical upper RPM limit of 7222RPM. The GWS RS props seem to have a lower upper RPM limit because they vibrate loudly when spinning fast.
The HD and E props are designed for direct drive so they have lower thrust than the SF or RS props for a given diameter at a given RPM. But they also seem to be slightly more efficient at any given RPM.
I've found that when you want to substitute an E or HD prop for an RS or SF prop you need to got up in diameter to have the same thrust.
thunder1 is offline Find More Posts by thunder1
Old Mar 22, 2004, 12:47 PM
csisfun is offline
Balsa!!!
Singapore
Joined Sep 2003
Perfect. Just what I needed to know. And:
Just what does more efficient mean? The GWS props are total crap and I'm not going to get another one. APCs are hard and they dont break easily. Unfortunately, the APC doesn't stock a 12x6 SF prop. Does it?
The closest I can find is a 11x4.7 SF prop. Nothing larger. I'm putting a 12x6E prop on the Slooooow Stick and I'm using an EPS350C (D gearing).
What do I gain from using an E prop instead of an SF?
Old Mar 22, 2004, 01:28 PM
TRP is offline
TRP
TRP
TRP's Avatar
Joined Jun 2002
Hyper Drive! Very nice.
Ted
Old Mar 22, 2004, 01:53 PM
citabria is offline
Find More Posts by citabria
Under tension
citabria's Avatar
Johnstown, Colorado
Joined May 2002
I own an 11x7 SF prop and Aeromicro.com has a 12x6 SF prop for sale. Take a look:
http://www.aeromicro.com/Catalog/pro...9_products.htm
Scott
citabria is offline Find More Posts by citabria
Old Mar 22, 2004, 02:06 PM
csisfun is offline
Balsa!!!
Singapore
Joined Sep 2003
Can't buy something off the net.
Old Mar 22, 2004, 02:40 PM
thunder1 is offline
College Park, MD
Joined Sep 2002
Efficiency for props is the amount of thrust per energy input i.e. amps go down.
So the SF and RS props "waste" slightly more energy to give the same amount of thrust. The tradeoff is usually the ability to produce thrust in the lower end of the RPM range. Which is why I mentioned the HD and E props need to go up a diameter to produce the same amount of thrust at slower RPMs.
Sold A HUGE LOT of electric props, APC E, SF and GWS HD and SF!! dawnron1 Aircraft - Electric - Power Systems (FS/W) 1 Aug 01, 2006 12:03 PM
Difference between APC SF and E props? Tram Power Systems 7 Dec 24, 2004 02:10 PM
Discuss the APC "E" props vs "SF" props Please CSI Power Systems 47 Dec 09, 2004 01:19 PM
Compare GWS SF and HD props on Razor-MH MKH Power Systems 26 Jul 03, 2003 10:54 AM
"sf" props and "e" props? FrankC29 Beginner Training Area (Aircraft-Electric) 4 Apr 25, 2003 09:11 AM
