Old Mar 15, 2014, 08:25 AM
bobly is offline
Find More Posts by bobly
Joined Sep 2010
Originally Posted by simibill View Post
BNF does not include a transmitter. So I expected the setup to not require anything except the normal check of control movement and setting the travel and expo according to the manual.
Getting tougher to understand. "Normal check of control movement" always been number one - which is what you did and found you had to reverse one channel. It's the first thing you check any time you bind tx and rx and on every preflight check. Is this the first time you ever found a control direction that needed to be reversed?
bobly is offline Find More Posts by bobly
Old Mar 15, 2014, 10:13 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
I'm not sure what problems you guys are having. When I bound my TX, a Spektrum DX9 to my Artizan, I had to reverse the aileron channel. After that, and doing a test of the AS3X as per the manual, everything works fine. I didn't have to go into the receiver to "reverse" anything. I have about 10 flights on mine now with no issues, AS3X works as it should. I have done some advanced aerobatics with my Artizan and the plane performs fantastically. I think some of you are over thinking this, or your TX is to blame.
chucksolo69 is offline Find More Posts by chucksolo69
Old Mar 15, 2014, 11:59 AM
bobly is offline
Joined Sep 2010
Agree - simibill seems to think something is wrong if he has to reverse a channel in his transmitter. I have tried to explain that this is perfectly normal to no avail.
Old Mar 15, 2014, 12:17 PM
simibill is offline
Find More Posts by simibill
General Factotum
simibill's Avatar
United States, CA, Simi Valley
Joined Mar 2007
Well Mr obvious, The need to reverse a channel is perfectly normal in an installation not involving a AS3X system. In my case, I was concerned that the need to reverse my aileron channel would result in the Gain settings in the AR635 Rx also needed to be reversed. chucksolo69 said he did not need to change the gain settings on his Rx even though he did reverse his aileron channel. Trying to observe the movement of the ailerons when rocking the model to check proper deflection is difficult.
simibill is offline Find More Posts by simibill
Old Mar 15, 2014, 02:14 PM
Joined Apr 2011
Again, not really. All you need to do is make sure that when the appropriate wing is pitched down, so is that particular aileron. Very easy, a no brainer.
Old Mar 15, 2014, 04:15 PM
lv2soar is offline
Find More Posts by lv2soar
Los Angeles, CA
Joined Mar 2004
That's why I asked him if he was new to RC and a new flyer. That's something a newbie would ask. But he replied no, he is not a newbie. So I agree with you
lv2soar is offline Find More Posts by lv2soar
Old Mar 15, 2014, 05:19 PM
bobly is offline
Joined Sep 2010
Maybe I just tried to explain the wrong thing. The best approach might have been to explain that changing the travel direction in your transmitter has no effect on the as3x system. The only way to change any programming in the receiver is to go into program mode
Old Mar 16, 2014, 01:08 AM
lv2soar is offline
Los Angeles, CA
Joined Mar 2004
I think he is a new flyer. If you been flying a little, you know that once you bind the TX and RX, you need to check all flying surface and do a flight check. His question is what newbie would ask
Old Mar 17, 2014, 09:23 PM
mybad is offline
Find More Posts by mybad
Sure, I can fly after sunset!?
United States, MI, Novi
Joined Jan 2011
A couple of years ago I bound my brand new PZ SE5a to my Dx6i and took off on my maiden flight, which was also my very first aileron flight, with the ailerons reversed!!!
I can't believe I landed it safely! Fortunately I picked a calm day and a very large field. I walked we'll over 100 feet to where I managed to set her down. So yes, it came out of the box that way for me.
Lesson learned!
mybad is offline Find More Posts by mybad
Old Mar 24, 2014, 10:46 AM
mark.mcclelland is offline
Find More Posts by mark.mcclelland
Joined Aug 2012
I had to reverse the aileron servo on my BNF T-28. DIdn't seem like a big deal to me at the time...
mark.mcclelland is offline Find More Posts by mark.mcclelland
Old Mar 24, 2014, 03:53 PM
Joined Apr 2011
I think the big question was that perhaps when you reverse the ailerons on a plane equipped with AS3X stabilization, do you have to go in and tell the AS3X receiver you have done so. The answer is no. A BNF T-28 wouldn't be questioned since it uses a standard RX without AS3X. Just a tiny bit of confusion is all.
Old Apr 20, 2015, 03:00 PM
twelti is offline
Find More Posts by twelti
United States, CA, Thousand Oaks
Joined Feb 2015
Artizan + Spektrum 635
Not sure if this thread is still alive, but:
Just bought an Artizan with 635 rx (using DX6 tx). Ailerons were reversed, so I reversed it in the tx. i have not done a any programming of the rx, just the stock settings for the Artizan. Every looked good, control surfaces moving in the right direction for stabilization (though not moving much, especially the elevator). I made some adjustment of the mechanical linkage to get a neutral elevator, but otherwise no issues. Flew it, and it seems to really want to go up. That is, if you give it a bit of up elevator, it wants to go up even more. I had to fight it to get it level and bring it back. CG was not an issue (checked). I'm not sure what the gear was set to on the tx (I didn't know about the 2 rx modes yet). I REALLY don't want to try to reprogram it, and not sure what i would do differently anyways. Any suggestions anyone?
Another question: are the stock settings of the two "banks" in the 635 rx identical, or do they have different rates. I see conflicting info on that. i would like to program one bank with 100% rate and standard "sport" settings for the Artizan, and one bank with NO stabilization.
twelti is offline Find More Posts by twelti
Old Apr 21, 2015, 10:59 PM
ace7938 is offline
Find More Posts by ace7938
ace7938's Avatar
Canada, ON, Newbury
Joined Sep 2014
In answer to your first question of it climbing the way it does, my visionaire as exactly the same, same receiver, Horizon told me to turn down the gains as they are too high on the elevator...well I still have not done so, but I have discovered that balancing the prop made all the difference in the world to it not doing this, at least as drastically. Also flying it slower prevents it. As you can read from above replies there are some that say its easy to adjust all this stuff. I reread the manual thinking I am going to turn down the gain ,watch the flashing lights and just go back and fly it...to unsure of how to adjust the gains...the manual sucks explaining it.
I think the gains are different in each from the reactions of my plane no proof though
ace7938 is offline Find More Posts by ace7938
Old Apr 22, 2015, 12:00 PM
twelti is offline
Joined Feb 2015
That is interesting. I will look into balancing the prop (never done that before). I had thought to try to program one of the two "banks" in the 635 to zero the gains, leaving the other bank at factory settings. That is one confusing thing: the manual says they are identical, but somewhere else it says there are different rates programmed for them. I don't see any evidence on mine, switching gear ch with surfaces deflected shows no difference.
I just fixed all the Artisan's trims mechanically, so tx sub trims all exactly zero'd out. Will try again
New Product Parkzone ArtiZan with AS3X Aerobatic's Plane ChuckTseeker Sport Planes 1709 Jul 13, 2016 06:14 PM
Cool NEW Parkzone ArtiZan with AS3X Aerobat Red Flyer Parkflyers 203 Oct 24, 2015 09:19 PM
Discussion PZ Artizan & Eflite UMX Radian & EFlite Allusive Vapor Trails Atlanta Area RC 7 Jan 29, 2014 08:08 PM
Alert Parkzone ArtiZan with AS3X Aerobatic's Plane ChuckTseeker Electric Plane Talk 0 Jan 29, 2014 01:07 AM
For Sale Parkzone mossquito bnf, parkzone micro citabria bnf, hobbyzone champ all for $150 um nut Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 3 Nov 07, 2013 12:51 AM
