Espritmodel.com Heli Air
Old Mar 21, 2004, 06:29 PM
Marion
USA, NC, Hillsborough
Joined Oct 2003
Old Balsa - Help
Today I acquired an old model, flown in 1972 at the Nationals. The covering had been removed, so the delightful complex structure was visible. The balsa seems to be very brittle -- the glue seems OK, just the balsa is very, very brittle. It breaks awful easy, and I do not think it will survive the shrinkage of covering materials.
Does anybody know how to remedy this situation so the structure might be useable again?
Marion
Marion is offline Find More Posts by Marion
Old Mar 21, 2004, 06:38 PM
Joined Feb 2004
How about a coat of paint on the frame. It may saturate the wood, and "glue" all the loose particles that make it brittle, together and strong again. This is just a guess, or suggestion, if your interested.
My uncle gave me a 40 ytear old guillows plane, a rib shattered into pieces when I cut the first notch out, I had a fresh blade too.
Bythebookie2 is offline Find More Posts by Bythebookie2
Old Mar 23, 2004, 08:49 PM
Marion
Joined Oct 2003
Anybody else have more ideas on this problem???
Old Mar 23, 2004, 09:10 PM
mode1's Avatar
Southwest Missouri
Joined Oct 2002
Thin ca on the wood should make it hard again without adding weight. ?
mode1 is offline Find More Posts by mode1
Transfer of plan lines to balsa...help! JonB The Builders Workshop 12 Dec 13, 2002 01:28 PM
OK I have had it with balsa- Help me to become a foamie nut Dandi6065 Foamies (Kits) 2 Jan 05, 2002 02:01 PM
EP CONCEPT (old) PARTS...HELP!!! jpduke Electric Heli Talk 2 Sep 24, 2001 12:28 PM
Modifying an Old Balsa Trainer for Electric (Tyro Too) ballardb Electric Plane Talk 3 Sep 11, 2001 07:13 AM
