Dream-Flight Libelle DLG - Discus Launch Glider
Have you been looking for an affordable DLG plane that performs? The Libelle is it!
The Dream-Flight Libelle is a real performer at an awesome price.
Wingspan:1200 mm (47.2 in)
Wing Area:21.31dm2 (330 in2)
Weight:278-290 gm (9.8-10.2 oz)
Wing Loading:13-13.6 gm/dm2 (4.3-4.5 oz/ft2)
Servos:Hitec HS-35HD
Receiver:Hitec Minima6E
Battery:4.8v 300mAH NiMH
Transmitter:Hitec Aurora
Manufacturer:Dream-Flight
Available From:Dream-Flight.com
Street Price:$120
The first time I saw someone fly a DLG (discus launch glider) plane I was stunned. I immediately started doing my research on DLGs and the issue I had was the price - expensive! I did finally get a DLG and to date I have owned 3. I think there is no purer form of flight in the RC world. You control your ailerons, elevator and rudder. You have to rely on your plane and your brains to find thermals to keep the plane in the air.
What I really wanted was something small enough to throw in the car and inexpensive enough to not worry about. The trick to that equation is finding an airframe that is up to the task. When I saw Dream-Flight was releasing my dream plane I was quick to contact them. The plane arrived quickly and my questions were answered just as fast.
Dream-Flight Libelle DLG Review - RCGroups.com (10 min 20 sec)
In The Box
The medium sized box shown with a dragon fly wing as the art. Libelle is German for dragonfly.
Most of the hard work is done for you.
The Manual
The manual covers the complete build process. I was left with no questions about the exact steps needed to build the Libelle. I would also like to note that the manual is as much a soaring and trimming guide as it is an assembly guide.
Hardware
All hardware needed is included. I'm pretty picky about hardware and everything that shipped with the Libelle worked for me. Be careful not to lose the small clevis screws!
The Wing
The wing comes in two halves. Carbon fiber is preinstalled in the wing halves.
The Tail Group
The stabilizer simply screws in place on the factory installed stab mount.
The rudder has a channel molded into it that allows you to CA it on. You can also use epoxy. I went with CA and it has held up fine to flying. I also used some tape like the instructions suggested.
The Fuse
Electronics
Servos
This plane is made for the Hitec HS-35HD. Be sure to power these servos up and find center before installing them on the plane. This is done to prevent damage to servo. Dream-Flight also offers servo extensions that you can buy separately from their online store.
RX
The only limitation for the receiver is that is has to fit in the small fuselage. I found the Minima6E was perfect for this since the servos connected on the side and not the top.
I ran the antenna wires down the side of the fuse.
Battery
Dream-Flight sells a battery that is made to fit in the nose of the fuse. It is a 4.8v 300mAH NiMH battery. Everything I have these days is lithium polymer so I wasn't sure how I was going to charge it. I used my charging cable from my Hitec Aurora to charge this battery.
I was able to fly the Libelle on a calm day and a very windy day. The concern anyone would have with a low cost DLG bird is how does it fly? I thought it flew great. Even though it only weighs around 10 ounces it still managed to penetrate the air. The flip side to that is that at 10 ounces you could really milk the air that you had. It also really communicates to you while flying, If there is a thermal you will see it.
I set all the control surfaces to neutral and the only trimming I had to do was on the elevator. After we pulled a little weight from the nose that worked itself out too. It is a great flying machine.
The next question is how tough is it? It's made out of foam so that was a concern. The rudder was my biggest concern since it is going to be in contact with the ground every time you land. I'm happy to report it held up fine. At one point I did a full speed nose plant. The only thing that happened was the servos in the fuse needed some CA added to lock them back into place. I was impressed. I think the light weight of the plane is what keeps it from sustaining any major damage.
While we didn't find any thermals on our initial flights we managed to keep the plane in the air a good while and have a fun. We even did some slope flying off a very small embankment next to our field.
There is a lot to like about this plane. The price is what should grab you first. If you ever wanted to try your hand at flying a discus launch glider this is the plane for you. I think it's smaller size and light weight make it a great grab-and-go plane for the field or the beach.
Jason Cole spent the day flying the Libelle with me and he said, "From my POV it's a great entry level DLG. It won't match performance of a competition one, but its good enough to be fun."
I will post updates this spring and summer after I have more thermal hunting time with the Libelle.
The build is simple and fast and you don't need anything fancy to build the plane. I built the whole thing sitting at my office table. The plane is obviously designed by real DLG pilots. The construction is light and strong.
I had a blast flying the Libelle and I'm excited to have it in my arsenal of planes. I see some early summer lunch breaks that involve me and the Libelle out hunting for thermals. I also think that since it is such a low cost DLG alternative that I'm more likely to to be aggressive with this plane.
The Dream-Flight Libelle is a winner in my book and just what I was waiting for someone to produce!
About Dream-Flight
Dream-Flight is a small family-run business based in Goleta, California. Known as the "Goodland," this coastal community offers a variety of soaring conditions.
Dream-Flight's goal is to create unique aircraft that are pure fun to fly. They focus on beginners through experts. Their passion is creating quality, affordable R/C aircraft that get more people outdoors to enjoy the wind and sun.
Dream-Flight Libelle DLG- Get Out and Glide (2 min 5 sec)
Libelle Discus Launch Tips
  • Launch into the wind.
  • Allow the glider to hang freely from the peg supported by your index finger and middle finger.
  • Fully extend your launching arm horizontally during entire launch sequence.
  • Facing into the wind, begin one complete rotation allowing the centrifugal force to transition the glider to a horizontal flight.
  • You may take a few steps into the wind while rotating.
  • At the end of one complete rotation release the glider into the wind, slightly above the horizon.
  • Allow the glider to climb using a bit of up elevator or a launch preset switch with up elevator.
  • Smoothly push the glider's nose down to level flight when it has almost reached it's max height.
Old Mar 13, 2014, 10:53 AM
alexzuga is offline
Find More Posts by alexzuga
Joined May 2013
I want one!!!!!
alexzuga is offline Find More Posts by alexzuga
Old Mar 13, 2014, 12:04 PM
Vapor Trails is offline
Find More Posts by Vapor Trails
DFC~ We Do Flyin' Right
Vapor Trails's Avatar
USA, GA, Atlanta
Joined Nov 2008
I am looking forward to putting one of these together after SEFF
Vapor Trails is offline Find More Posts by Vapor Trails
Latest blog entry: Pin-ups
Old Mar 13, 2014, 12:23 PM
chips303 is offline
Find More Posts by chips303
chips303's Avatar
NW Indiana
Joined Aug 2007
Thanks to Jim T, I now have one on order
chips303 is offline Find More Posts by chips303
Old Mar 13, 2014, 02:03 PM
mr.fowl is offline
Find More Posts by mr.fowl
mr.fowl's Avatar
United States, FL, Daytona Beach
Joined May 2012
Thanks for getting this review up so quick. I don't have to worry that I'm waiting for a bad glider anymore it sounds like its a blast to fly! I can't wait!
mr.fowl is offline Find More Posts by mr.fowl
Old Mar 13, 2014, 05:23 PM
lv2soar is offline
Find More Posts by lv2soar
Los Angeles, CA
Joined Mar 2004
When is it available?
lv2soar is offline Find More Posts by lv2soar
Old Mar 13, 2014, 05:25 PM
Jim T. Graham is offline
Find More Posts by Jim T. Graham
Administrator
Jim T. Graham's Avatar
United States, TN, Nashville
Joined Mar 2002
Now:
http://www.dream-flight.com/products/libelle-dlg
Jim T. Graham is offline Find More Posts by Jim T. Graham
Administrator
Old Mar 13, 2014, 07:39 PM
rcrich is offline
Find More Posts by rcrich
When pigs fly rc
rcrich's Avatar
USA, NY, Chester
Joined Apr 2008
Cool!!!!
rcrich is offline Find More Posts by rcrich
Old Mar 13, 2014, 09:02 PM
HugoCraft is offline
Find More Posts by HugoCraft
Aerobatic Fanatic
HugoCraft's Avatar
United States, KY, Louisville
Joined Sep 2007
What would be good HV (2s lipo) servos to use in this? This looks like a perfect first DLG but would like to run a 2s lipo powering the rx/servos with no regulator.
HugoCraft is offline Find More Posts by HugoCraft
Old Mar 13, 2014, 09:40 PM
akfreak is offline
Find More Posts by akfreak
United States, NV, Henderson
Joined Sep 2013
Finally a DLG I can afford
akfreak is offline Find More Posts by akfreak
Old Mar 13, 2014, 09:44 PM
ripacheco is offline
Find More Posts by ripacheco
rip
ripacheco's Avatar
United States, FL, Niceville
Joined Jan 2013
Be nice if this level if DLG become a new class of gliders. I was so surprised how expensive these DLG are
ripacheco is offline Find More Posts by ripacheco
Old Mar 13, 2014, 09:45 PM
USA, GA, Atlanta
Joined Nov 2008
A nice composite ship can quickly set you back over $1k, this is a welcome addition to the DLG lineup
Old Mar 13, 2014, 10:06 PM
kingsflyer is online now
Find More Posts by kingsflyer
We shall serve the Lord
kingsflyer's Avatar
United States, TX, Kingsland
Joined Sep 2005
Jim T, put me down for some stick time at SEFF!
McD
kingsflyer is online now Find More Posts by kingsflyer
Latest blog entry: LEDs on my T-28
Old Mar 14, 2014, 01:01 AM
DoctorBadVibez is offline
Find More Posts by DoctorBadVibez
There are voices in my head...
DoctorBadVibez's Avatar
Canada, ON, Toronto
Joined Apr 2010
Really nice Jim T! It looks like the Libelle is perfect for priming newbies into DLGs!
DoctorBadVibez is offline Find More Posts by DoctorBadVibez
Old Mar 14, 2014, 07:23 AM
TMAC4123 is offline
Find More Posts by TMAC4123
God is Good
TMAC4123's Avatar
United States, MI, Grand Rapids
Joined Jan 2011
Looks sharp!
TMAC
TMAC4123 is offline Find More Posts by TMAC4123
Cool Dream-Flight Libelle DLG MattyB Slope 1889 Today 12:42 AM
News Dream-Flight Libelle - DLG Jim T. Graham Hand Launch 2501 Jun 10, 2016 07:24 PM
Wanted dream-flight Libelle rarner Aircraft - Sailplanes (FS/W) 3 Nov 03, 2014 12:37 PM
Discussion http://www.dream-flight.com/files_download/Libelle.pdf hellmansam Hand Launch 35 Mar 30, 2014 09:03 PM
Build Log Dream-Flight “Libelle” Build and Maiden flights, check in here. Tspin Slope 8 Mar 07, 2014 07:50 PM
