Old Mar 20, 2004, 10:06 PM
jdd44 is offline
Find More Posts by jdd44
Joined Mar 2004
Can someone please tell me how
to hook up a new connector to my Hitec flash 5 wall charger? I want to cut off the standard connector that plugs into the tx and add a connector that will charge the battery while removed from the tx. The wires to the standard connector are both black, but one has long white dashes on it. Does this one go to the red or the black wire on the new connector? Thanks in advance for any help. JDD
jdd44 is offline Find More Posts by jdd44
Old Mar 20, 2004, 11:02 PM
Peter Young is offline
Find More Posts by Peter Young
Dead stick!!
Peter Young's Avatar
Joined Mar 2002
I don't know the answer, but I'm curious as to why you want to do this?
Peter Young is offline Find More Posts by Peter Young
Old Mar 20, 2004, 11:12 PM
boomerace is offline
Find More Posts by boomerace
Been There! Done That!
boomerace's Avatar
Eugene, Oregon, United States
Joined Sep 2001
Make an adapter.... get the Female plug from Radio Shack then you can plug and unplug it for charging your TX. Center is plus outside is negative.
boomer
www.boomerseflight.com
boomerace is offline Find More Posts by boomerace
Old Mar 21, 2004, 08:52 AM
jdd44 is offline
Joined Mar 2004
PY- Iwanted to be able to slow charge a tx battery(I have 2) and still use the tx with the other battery. The slow charger takes about 15 hours.
Boomer- Thanks for that info; that's exactly what I needed to kn ow. And, by the way, thanks for your valuable contribution to the SSBOK (Slowstick Book Of Knowledge) which has enabled me to (starting from scratch and knowing nothing):
1. Choose a great plane as a gift for my son.
2. modify it to be almost bulletproof.
3.Learn how to fly it in spite of a warped wing we eventually
discovered and fixed.
4. had a great time doing it all.
Your help is much appreciated.
JDD
Old Mar 22, 2004, 07:34 PM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Is the model memory in Flash5(if yours is a computer) non-volatile? If I remember right, having volatile memory means you'll lose all your model data when you remove your battery.
larsy87 is offline Find More Posts by larsy87
Old Mar 22, 2004, 08:07 PM
boomerace's Avatar
Joined Sep 2001
Cam,
Removing Battery No problem!
boomer
Alert can someone please help me setup my Heli-Max gyro? crx_ef8 Electric Heli Talk 0 Nov 25, 2003 07:58 PM
Gyro ttrouble please can someone please help me??? zetex Micro Helis 5 Sep 15, 2003 09:51 PM
Someone please tell me about these NMH Batterries... KZZ Batteries and Chargers 2 May 16, 2003 08:12 PM
Help!! Can someone please tell me how to hook up a twin in paralell? Joe Elston Power Systems 6 Oct 22, 2001 06:37 PM
