Closed Thread
Old Mar 20, 2004, 09:46 AM
Leave me alone!
Martin Hunter's Avatar
Kamloops, BC, Canada
Joined Feb 2002
Revolution 3d EPP Trainer! by 3d_crazy Part 2
It's time for a part 2!
Here's part 1:
http://www.rcgroups.com/forums/showt...38#post1575238
Carry on
Martin
Martin Hunter is offline Find More Posts by Martin Hunter
Old Mar 20, 2004, 01:32 PM
Tee Sqaured
Thomas Manson's Avatar
Langley, B.C, Canada
Joined Jun 2001
Camon guys
Thomas Manson is offline Find More Posts by Thomas Manson
Old Mar 20, 2004, 04:20 PM
lipolys arent dangerous..
Wichita Falls, TX
Joined Mar 2004
could you use a nippy or pjs on these? if so, which model #?
Alex Shipp is offline Find More Posts by Alex Shipp
Old Mar 20, 2004, 04:44 PM
Two Rivers, WI
Joined Mar 2003
waiting for my kit!!!
Got my Axi 2212/34 and CC10---just need the plane
Ryan
ICRSHLTS is offline Find More Posts by ICRSHLTS
Old Mar 20, 2004, 05:56 PM
Begin with end in mind...
power's Avatar
Eagle Lake, Minnesota
Joined Apr 2003
Waiting for the wind, kinda looks like a patriotic zero, Did I just say that?
POWER
power is offline Find More Posts by power
Old Mar 20, 2004, 08:48 PM
Pro Bro #1008
birdie_in_texas's Avatar
USA, TX, Weatherford
Joined Sep 2003
looks nice man...!
birdie_in_texas is offline Find More Posts by birdie_in_texas
Old Mar 20, 2004, 11:05 PM
ProBro #261
mc71's Avatar
Coogee, Australia
Joined Aug 2003
I'm still waiting on that motor to come so it will be another week before I can fly with the full on setup.
Matt
mc71 is offline Find More Posts by mc71
Old Mar 21, 2004, 07:52 AM
Ontario,Canada
Joined Jan 2004
Yup looks nice Power,here is a pic Of my son's R3D,mine is not ready yet, I kinda like the pink & black version.
Im waiting on my lipo's to come in and a AXI motor mount.
jeang
jeang is offline Find More Posts by jeang
Old Mar 21, 2004, 07:12 PM
Wichita Falls, TX
Joined Mar 2004
2s on bl?
Anyone us 2s lipolys on bl motors? I am thinking of getting an AXI, Nippy, or PJS and dont really want to buy new batts ($$$$)
Old Mar 22, 2004, 02:10 AM
San Francisco, CA
Joined Feb 2004
I am also interested in a BL setup for 2s packs. my plane flies fine with 2s on a brushed motor. I can hover at 3/4 throttle with it. There has to be a BL setup that is better than that, but all the numbers I see show different. Really low thrust.
jonferran is offline Find More Posts by jonferran
Old Mar 22, 2004, 06:11 AM
Clearwater FL
Joined Sep 2003
Power, Nice Plane. STRONGLY suggest you unbolt that prop and bolt on a prop saver and a rubberband. With the prop bolted on you will do much damage to the plane that can be avoided. Do it before you fly the first time. Just trying to help.
CraigT is offline Find More Posts by CraigT
Old Mar 22, 2004, 07:46 AM
Pro Bro #1008
Joined Sep 2003
i use 2S packs on most of my BL stuff...i have razor 300 in "C" gearbox with phx-10 using 11x4.7 and 12x3.8 and 12x6 props and get great results...
also have a razor 400 in a "D" gearbox that does equally as well in my opinion...
and that is all etec 2S 700's and 2S 1200's...
Old Mar 22, 2004, 09:10 AM
Clearwater FL
Joined Sep 2003
I am using a axi 34 on cc p10 with 4 hs55's TP1320 3s1p the esc is getting hot like 125 degrees hot the draw is about 9 amp wot and only 2.5 amp at flying speed. Can the 4 servos make the esc that hot. I can fix it by putting the esc outside the fuse during the flights and it is fine but in the plane it get too hot. Anyone else having this problem?
Old Mar 22, 2004, 10:37 AM
Fuzzy Member
lupy's Avatar
Renton WA
Joined Oct 2001
you are right , it is the bec, try plugging the bat in and just running the controlls around a bit, the esc will get quite hot without the motor. When I talked to CC about this problem, they said that we are right on the ragged edge of what the esc is capable of. The Regulator will shut down if it gets too hot, saving the esc, but pos causing momentary loss of controll. The guy I talked to said that cutting the shrink wrap over the voltage regulator would help disapate heat. Its the little rectangular box with 3 tabs on one long side, right next to the black battery wire on the other side from the fets. I have an older phoenix 10 that I did this to, seemed to help, I then cut a small heatsink out of copper foil and attached it with heat transfer paste and super glue. It still gets hot, but not nearly as hot as before.
YMMV
Ken
lupy is offline Find More Posts by lupy
Old Mar 22, 2004, 05:26 PM
Wichita Falls, TX
Joined Mar 2004
What is the best Himax motor , gearing, and prop for this plane? Will it work on a 2s 1500 (Kokam)?
Closed Thread
Revolution 3d EPP Trainer! by 3d_crazy Part 3 Ulf Rieder 3D Flying 511 Sep 03, 2008 09:00 AM
Sold Revolution 3d EPP Trainer and Mini Bill Bergman Aircraft - Electric - Airplanes (FS/W) 9 Jan 02, 2006 11:57 AM
Mini 3D EPP for CD brushless: Part 2 eBird Foamies (Kits) 512 Jun 15, 2005 06:47 PM
Revolution 3D EPP Trainer Foam Only Kit Beauregard Aircraft - Electric - Airplanes (FS/W) 3 Jan 02, 2005 10:49 AM
Revolution 3d EPP Trainer! 3d_Crazy 3D Flying 514 Mar 20, 2004 09:47 AM
