Schumacher Mi1v2
1/10-scale entry-level electric 4WD on-road touring car
The ideal first “Race Car”, the Schumacher Mi1v2!
Schumacher has a great plan to help get people into touring car racing and the plan is called the Mi1v2! The Mi1v2 was designed to be the perfect first race car for somone itching to try 1/10-scale electric touring car racing. The goals that Schumacher set out to achieve was to make the Mi1v2 to be super easy to maintain, built to be extremely durable to handle the inevitable crash and most important…great to drive! The belt-driven 4WD drivetrain is efficient and the motor mount is precision CNC machined from aluminum. The chassis is setup to be equipped with the latest LiPo battery packs and offers a range of easy adjustments and option parts so that you can tune it to the track that you will be racing on. Schumacher is offering the Mi1v2 in a kit or in an assembled version. The assembled version will still need the same accessories that the kit requires.
KEY FEATURES
  • Optimized chassis and top deck design to easily accept a wide range of LiPo packs.
  • 24-piece ball bearing set provides ultra-low rolling resistance.
  • Large differential and layshaft pulleys minimizes belt loading without the belt jumping and maximizes belt efficiency.
  • Rear in-board toe-in options for excellent traction on slippery surfaces.
  • Dual-belt transmission offers efficient, fast and great run times.
  • Robust aluminum motor mount helps in lowering motor temps.
  • Front in-board toe-out options gives more front end bite on slick tracks.
  • Twin track, ball raced, limited slip ball differentials with Tungsten Carbide balls offers long life with super-smooth action and low rotating mass for awesome acceleration.
  • Includes a lightweight foam front bumper.
  • Front and rear anti-roll bars included.
  • Ball bearing support steering system
REQUIRED TO COMPLETE
  • 2-channel radio system
  • Motor
  • Speed control
  • Servo for steering
  • Tires
  • Pinion gear
  • LiPo battery pack
  • Body
  • Paint for body
ITEM NO. DESCRIPTION
K151 Mi1v2 4WD touring car - KIT
K152 Mi1v2 4WD touring car - ASSEMBLED
Learn more—Schumacher!
There are no posts
News Schumacher CAT K1 Aero Paul Onorato Car Talk 0 Dec 10, 2013 12:21 PM
Sold Schumacher Mi4CXL SRM Cars - Cars and Parts (FS/W) 0 Nov 10, 2013 08:30 PM
News Schumacher Cougar KF Paul Onorato Car Talk 8 Nov 06, 2013 12:27 PM
Sold NEW Schumacher Mi5 Sedan SRM Cars - Cars and Parts (FS/W) 0 Oct 28, 2013 09:01 AM
News Schumacher – New Mi5 chassis conversion and Ti Balls Paul Onorato Car Talk 0 Sep 27, 2013 04:26 PM
