Old Mar 19, 2004, 09:01 PM
garrett818 is offline
Find More Posts by garrett818
palos verdes, ca
Joined Mar 2004
Question
talon airfoil?
I am gitting some foam cores cut for my talon, but cant find what kind of airfoil it has. any info would be great!
garrett818 is offline Find More Posts by garrett818
Old Mar 19, 2004, 09:07 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
E 205
Droydx
droydx is offline Find More Posts by droydx
Old Mar 19, 2004, 09:29 PM
palos verdes, ca
Joined Mar 2004
thanks alot
Old Mar 19, 2004, 10:12 PM
palos verdes, ca
Joined Mar 2004
also what is a good plotting software that is free to plot the airfoil on?
Old Mar 19, 2004, 11:14 PM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Profili is EXCELLENT
Good luck,
Target
target is offline Find More Posts by target
Old Mar 20, 2004, 08:57 PM
palos verdes, ca
Joined Mar 2004
do you know how thick the airfoil is?
Old Mar 20, 2004, 09:58 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Its probably the stock E-205, besides, can you change the percentage of thickness without registration?
Old Mar 20, 2004, 10:03 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Just checked, there is two in Profili;
The first is 10.5% thick with a 3% camber,
The second(I'd choose) is 9.5% thick with 2.5% camber.
Target
Old Mar 20, 2004, 10:11 PM
palos verdes, ca
Joined Mar 2004
which ones best??
Old Mar 20, 2004, 11:53 PM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Go faster with the one with less camber and thinner percentage!
Old Sep 19, 2005, 09:04 AM
Wouter is offline
Find More Posts by Wouter
Wouter's Avatar
The Netherlands
Joined Sep 2004
When I compare the airfoil section at the plan with E205 provided with Profili it didn't match.
Have I made a mistake, or isn't it E205
Wouter
Wouter is offline Find More Posts by Wouter
Old Sep 19, 2005, 09:09 AM
InTheLift is offline
Find More Posts by InTheLift
It could happen...
InTheLift's Avatar
Torrance, California
Joined Jan 2004
The airfoil you end up with when you build a Talon will be anything but the intended E 205. It's a built up wing with die cutting that leaves something to be desired IMO. If you're going to have a wing cut, you might want to ask instead for a suggested wing section for this bird. The E 205 may or may not be the best choice.
InTheLift is offline Find More Posts by InTheLift
Old Sep 19, 2005, 09:32 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You could try an E214...
T
Old Sep 19, 2005, 01:29 PM
Wouter is offline
Wouter's Avatar
The Netherlands
Joined Sep 2004
E205 isn't my choice for the airfoil.
I doubt whether I take the original (kit) airfoil or something like RG15.
The first is easy to construct for a build-up wing, the second is better, but more complicated to build...
The die-cut ribs seems to me not very accurate, so I'm searching for the original airfoil, so I can use Profili for printing them.
Wouter
Old Sep 19, 2005, 01:43 PM
It could happen...
InTheLift's Avatar
Joined Jan 2004
Wouter
Understood Wouter, but my post was directed at the thread starter. The E 205 may well have been selected because it is easier to reproduce in a reasonably accurate form when built up. My point is that since the thread starter is getting a foam core cut, he need not limit himself to the stock airfoil...it is entirely possible that a different airfoil may show performance gains. I think the designer of the Talon posts these boards on occasion. Hopefully he'll chime in on the orignial airfoil of this plane???...before it went in to production as the Talon.
