Old Dec 20, 2001, 09:33 AM
LJH is offline
LJH
Find More Posts by LJH
LJH
Moths do not fly inverted
LJH's Avatar
Greenwich CT.
Joined Sep 2000
MF/480 Balancing
I just did a quick search and came up with nothing. Can someone send me a link on this or give me a quick run down on the best way to do it. Should I worry about it useing a SP480 BB race motor. Looks like the F/18 will fly this weekend sans detailing.
Cheers,
Jim
LJH is offline Find More Posts by LJH
Old Dec 20, 2001, 10:15 AM
Admiral_Red is offline
Find More Posts by Admiral_Red
Vice President at MultiGP
Admiral_Red's Avatar
San Antonio, Texas
Joined Oct 2001
You might want to contact Robert at EJF if you need some advice. I think that balancing helps at all power ranges, even 480 input. What I did with mine is balance it with a magnet balancer desgined for props, and sand the back side of the blade that was heavy. It took a while, but it is pretty close. Now from what I read in other posts, the spinner can be another source for the rotor being out of balance.
James
Admiral_Red is offline Find More Posts by Admiral_Red
Old Dec 20, 2001, 10:38 AM
Plane Crazy is offline
Find More Posts by Plane Crazy
Flying Welder Pilot
Plane Crazy's Avatar
Reno, Nevada
Joined Jan 2001
I use a magnetic balancer that has been modified to just balance rotors. I shortened the balance rod and the lower rods so I can balance Mini and Midi rotors. I used to have problems with the long balance rod getting bent and it was a real pain to balance anything accurately. I use pieces of aluminum tape stuck inside the rotor hub to add weight. After you do a few mini fans you will see that they need weight in the same place. Usually were you see the break off of the plastic spru. Balance the rotor by itself. If you like you can also balance the spinner separately. I usually fly all my minifans with out the spinners, and have not noticed an enormous loss of power. If you use the spinner: mount the rotor and spinner in the fan and give it gradual throttle if it vibrates loosen the screw and twist the spinner in 10 degree increments until the vibration is gone. Mark both the spinner and rotor with silver or white paint so you can align them again if you have to remove them.
Gordon
Plane Crazy is offline Find More Posts by Plane Crazy
Old Dec 20, 2001, 10:43 AM
San Antonio, Texas
Joined Oct 2001
Hmm, foil tape....Brilliant!!!
James
Old Dec 20, 2001, 12:47 PM
Herb is offline
Find More Posts by Herb
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
I use a $3 balancer (I believe mine is made by Prather) & Neodymium magnets from a failed hard drive, I have used it on all sorts of fans, has worked for me to 42+krpms.
As Chris described some time ago, I use very small vinyl tape pieces on the inside of the rotor & spinner for balance. The centrifugal force will keep the tape in place securely. I first painstakingly balance the rotor, then mount the spinner on the rotor and balance again (the spinner). This avoids ruining your rotor with CA and getting same all over the place including your fingers.
There is no need to fly without the spinner, it results in a small loss in efficiency. Never needed any further adjustment once it was then mounted in the fan. I really never had a need for what some call dynamic balancing either, if the rotor is balanced, it's balanced - and will stay balanced when you put it on the (balanced) motor no matter what the rpm is (within reasonable limits)...
Herb is offline Find More Posts by Herb
Old Dec 20, 2001, 05:36 PM
MicroRotors is offline
Find More Posts by MicroRotors
3D Toy Designer
MicroRotors's Avatar
USA, CA, Hesperia
Joined May 2001
I myself do it a little differnt.
I balance it on a magnetic balancer like every one has explained but, instead of adding tape and what not, I put thick CA on the back side of the blade and wipe it with my finger to spread it evenly across the whole blade. I do this several times to build up a nice coat. Then I scrape it with a scraper to get it nice and smooth.
I also fill in the mold break off with ca.
I am finding it takes very little effort to do it this way, as you can take off little scrapeings at a time and I can get it dead nutz.
Bill
MicroRotors is offline Find More Posts by MicroRotors
Latest blog entry: My New Toy!
Old Nov 05, 2003, 10:23 PM
spiro is offline
Find More Posts by spiro
Strange Planes INC.
spiro's Avatar
Mesa AZ, USA
Joined Jun 2003
Out of round rotor hub holes!
I just picked up my first WMT Mini Fan 480 and I am trying to balance this thing....
The rotor has some poorly cast hole entrances and the cones for my high point balancer don’t really center very well in there. Doing the best job I can do, when I spin the unit on the balancer the entire fan hub rotates out of round by perhaps 10 thousandths. I imagine I can’t even start to balance this thing until I have it sitting on the balancing shaft correctly...
Any ideas?
Has anybody else had poorly cast holes in the rotor hub?
Thanks in advance,
Spiro
spiro is offline Find More Posts by spiro
Old Nov 05, 2003, 11:50 PM
Arthur Knowles is offline
Find More Posts by Arthur Knowles
Arthur Knowles's Avatar
Fallbrook, CA
Joined Oct 1998
Turn one cone around so the flat is pressing against the back of the backplate/fan. It will center properly then. At least mine do.
Arthur Knowles is offline Find More Posts by Arthur Knowles
Old Nov 06, 2003, 12:31 AM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
I use ABS GLue cause it sticks like it was part of the rotor and it's easily grinded for adjustments. Plus is doesnt leach the natural material out of the ABS like CA does weakening the part.
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Nov 06, 2003, 11:59 AM
spiro is offline
Strange Planes INC.
spiro's Avatar
Mesa AZ, USA
Joined Jun 2003
I tried flipping one of the cones around, but the flat face of the fan hub has a rough pit that wont let the fan center up properly. It looks like this pit was left over from the casting process, perhaps where the fan was removed from a part tree. Sanding doesn’t seem to be an option, as the problem is a recess and not a bump. I would have to sand down the entire rest of the face to be level with the lowest pit surface!
As luck would have it, the motor shaft hole in the aluminum drive adapter is the same diameter as the balancing shaft. I just stuck the fan on the end of the shaft and set the balancer up as I would for an overhanging heli rotor head. The fan body still does not seem to be centered that well, though it is a vast improvement. Spinning the fan causes an obvious wobble.
I could balance the fan like this, but it just seems that it should sit on there straight... Has anyone else had similar experiences? Any suggestions?
Thanks again,
Spiro
MF 480 rotor balancing Olivier Electric Ducted Fan Jet Talk 2 Sep 13, 2010 01:00 PM
Mf 480 Cutlass rogwinger Electric Ducted Fan Jet Talk 16 Oct 29, 2003 09:18 AM
MF-480/Cobalt trouble marauder Electric Ducted Fan Jet Talk 16 Dec 24, 2001 08:44 PM
MF 480 and Speed 480 question Sabrejock Electric Ducted Fan Jet Talk 12 Dec 11, 2001 12:18 PM
Mf 480 ducting henke Electric Ducted Fan Jet Talk 3 Jun 27, 2001 01:25 AM
