Old Mar 18, 2004, 06:13 PM
edkoz is offline
Find More Posts by edkoz
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
How do you avoid paint bleeding under tape??
What's the trick to prevent the paint from bleeding under the tape when painting foam (GWS).
I'm using the blue painters tape.
This hasn't been a problem in the past but now it is. I'm using the same paint and tape as before.
edkoz is offline Find More Posts by edkoz
Old Mar 18, 2004, 07:02 PM
TEM is offline
TEM
Find More Posts by TEM
TEM
Joined Aug 2003
Spray on real thin coats of paint! Take many light coats instead of a thick one!
TEM is offline Find More Posts by TEM
Old Mar 18, 2004, 07:57 PM
edkoz is offline
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Bleeding
You're right, I was kind of horsing the paint on this time instead of multiple light coats.
Thanks for the wake up call.
Old Mar 18, 2004, 08:47 PM
TooTall is offline
Find More Posts by TooTall
victim of the system
TooTall's Avatar
Home of the Toledo RC show
Joined Jul 2003
after applying your blue tape for stripes I thin down polycrylic and brush 2 coats over the tape line.....this will prevent bleeding under the tape......
TooTall is offline Find More Posts by TooTall
Old Mar 18, 2004, 09:06 PM
P-51 flyby is offline
Find More Posts by P-51 flyby
P-51 flyby's Avatar
United States, NC, Rocky Mt
Joined Oct 2003
How do you avoid paint bleeding under tape?? Very well thank you!
No if i have had the tape around for a bit i will cut about 1mm off each side and i get straight edges
P-51 flyby is offline Find More Posts by P-51 flyby
Old Mar 18, 2004, 09:26 PM
foss1997 is offline
Find More Posts by foss1997
toledo, oh, usa
Joined Nov 1999
use a nicer, high quality trimming tape and then lay your masking tape over that. make sure you mask it off just before you are going to spray and make sure its down well, use thin layers, or hit it once w/ clear....that way you cant see the bleed :-)
scott
foss1997 is offline Find More Posts by foss1997
Old Mar 18, 2004, 10:40 PM
edkoz is offline
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Thanks guys, I lik the idea of the polycrylic over the tape before the color.
Ed
Old Mar 18, 2004, 10:57 PM
edkoz is offline
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
TooTall:
Just painted my wing ... Fantastic results.
Thanks a lot !!
Ed
Old Mar 19, 2004, 10:44 AM
Dzlstunter is offline
Find More Posts by Dzlstunter
Dzlstunter's Avatar
Jacksonville, IL
Joined Dec 2002
One other way is to lay down your tape, then spray a light coat of the adjacent color along the edge of where you plan to paint the new color. Let it dry, then apply the new color. Any paint that bled through will match the adjacent color. Just another way to skin the cat . Good luck, Dzl
Dzlstunter is offline Find More Posts by Dzlstunter
Old Mar 19, 2004, 01:20 PM
cadconversions is offline
Find More Posts by cadconversions
Around the World
cadconversions's Avatar
Scottsville, KY
Joined Jun 2002
Good tape (haven't had any luck with the blue painters tape) and pull the tape off immediately after you spray. Works for me everytime. Paint bleeds through as it's drying. Not immediately when sprayed. Thin coats.
cadconversions is offline Find More Posts by cadconversions
Old Mar 19, 2004, 01:35 PM
edkoz is offline
Watch This !!!
edkoz's Avatar
Rochester, MI
Joined Apr 2003
Cad:
What is "Good Tape" ??
Old Mar 19, 2004, 02:44 PM
Ledbetter is offline
Find More Posts by Ledbetter
Central California
Joined Aug 2003
I always use Scotch brand now. I've had it with cheap masking tape.
I clean with alcohol before applying the tape. I run my fingernail along the edge to "seal" it. After I spray, i arrange the object so that when drying, gravity pulls the paint AWAY from the tape.
Ledbetter is offline Find More Posts by Ledbetter
Old Mar 19, 2004, 04:49 PM
Around the World
Scottsville, KY
Joined Jun 2002
I got some masking tape at Hobby Lobby (craft store) that was in the model department for plastic cars. Works great on wood and foam (isn't that sticky) but Ledbetter was right. Any name brand high quality tape usually works.
Old Mar 19, 2004, 05:13 PM
rcav8r2 is offline
Find More Posts by rcav8r2
rcav8r2's Avatar
United States, PA, Beaver
Joined Sep 2001
I use el-cheap-o electric tape. Blot it on my shirt a few times to cut down the tack. There MAY be some bleeding if I go heavy, but good enough for me
rcav8r2 is offline Find More Posts by rcav8r2
Old Mar 19, 2004, 06:46 PM
foss1997 is offline
toledo, oh, usa
Joined Nov 1999
IMO the blue 3m tape is the best----it leaves no residue and comes off w/o pulling off other layers.
they key to getting a good clean line is to first mask off w/ some VERY thin ( 1/8" width or so, depending on application) speciatlity tape. Then overlay your masking tape and paper layer. Its also impt to pull it off soon after your last coat.
Scott
How do you avoid bubbles with solite? Brian T Scale Kit/Scratch Built 2 Nov 06, 2005 11:37 AM
How do you load photo's under your name? Starguard Site Chat 2 May 02, 2004 06:53 AM
Paint bleed under tape - How do you avoid edkoz Scale Fuel Planes 9 Apr 11, 2004 05:24 PM
how do you get the little quote under every message you write Pablito Parkflyers 2 Feb 09, 2002 06:00 PM
How do you get the little picture under your name? Scomis Site Chat 12 Feb 05, 2002 09:03 PM
