Old Mar 18, 2004, 07:48 AM
ClimaxPilot is offline
Find More Posts by ClimaxPilot
Chesty
ClimaxPilot's Avatar
Reedy Creek, Qld, Australia.
Joined May 2003
And a shot of the join from on top
ClimaxPilot is offline Find More Posts by ClimaxPilot
Old Mar 18, 2004, 07:51 AM
Chesty
Joined May 2003
Finally the carbon sheet has arrived :O) ummm carbon fibre , why can't the whole world be made of this stuff !
Old Mar 18, 2004, 07:53 AM
Chesty
Joined May 2003
Here's a shot of the carbon pieces i've made to form the undercarriage and wing mounts. Note the carbon discs i'll be using for the wheels and the lower wing spar. The cf arrow shaft i've used is hollow so I bent a 1 inch long piece if steel which fitted perfectly inside the shaft, I then wound the join with cf rovings and run some thin ca into the carbon.
Old Mar 18, 2004, 07:58 AM
Chesty
Joined May 2003
Another shot of the lower spar and the rovings I used
Old Mar 18, 2004, 08:00 AM
Chesty
Joined May 2003
Setting up the undercarriage
Old Mar 18, 2004, 08:03 AM
Chesty
Joined May 2003
And a shot of the partially completed undercarriage, another stay will run just under the lower wing, most measurements are to scale directly off a 3 view of the Camel, the wheels are only placed there aslo.
Old Mar 18, 2004, 08:06 AM
Chesty
Joined May 2003
Well that's all I got for now. Check back regularly as it will be completed within a week or 2.
Old Mar 20, 2004, 02:07 AM
Chesty
Joined May 2003
Here's a shot of the under carriage with a little mork work done. The carbon discs looked a little funky so I stuck some white vinyl on them, the carbon now looks a bit like the tyre......
Old Mar 21, 2004, 04:43 AM
Mick Molloy is offline
Find More Posts by Mick Molloy
MINE!
Mick Molloy's Avatar
Australia, VIC, Point Cook
Joined Jul 2003
Sweet, are these the same ones I have seen fly at brendale indoor flying i think it was a green triplane the guys were flying, they went very well indeed.
Mick Molloy is offline Find More Posts by Mick Molloy
Old Mar 22, 2004, 05:01 AM
Chesty
Joined May 2003
Brendale, is that near Caboolture ? if so then yes. You'll prolly know Lt Bernard Von Speedski then, here's a photo of the designer with the Neiport 17.
Old Mar 22, 2004, 07:57 AM
Chesty
Joined May 2003
Ok, back to the build. Next up was fitting the bottom wings. Very easy really, all I did was glued the inner wing ribs to the sides of the fuse. As you can see I have given the rib area a good sand.
Old Mar 22, 2004, 07:59 AM
Chesty
Joined May 2003
And here's a photo of the rib glued on. Pretty boring really.
Old Mar 22, 2004, 08:02 AM
Chesty
Joined May 2003
Next I run the carbon spar thru the other side of the fuse and added the other rib to the other side.
Old Mar 22, 2004, 08:13 AM
Chesty
Joined May 2003
I then added the first lower wing panel by tacking it to the rib with ca then running ca the full length of the rib. ca blaster will need to be used on most joints.
Old Mar 22, 2004, 08:14 AM
Chesty
Joined May 2003
Here's the underneath shot.
Build Log Topaz e-M build thread Jim Frahm Electric Sailplanes 85 May 12, 2007 02:32 AM
New "Slick" from www.M-A-E.com (build thread) Foam Crazy 3D Flying 57 Apr 12, 2007 09:37 PM
It's not another Sopwith Triplane - Austin Triplane build thread Looooeeee! Scale Kit/Scratch Built 58 Dec 03, 2005 03:44 PM
my brushless e-starter build thread FairlyFaded Parkflyers 2 Jul 16, 2005 10:17 PM
Yippee! balsa e-mower build thread Aidan Parkflyers 5 Jan 01, 2005 09:52 PM
