Old Mar 18, 2004, 01:21 AM
Ninjak2k is offline
Find More Posts by Ninjak2k
United States, VA, Warrenton
Joined Apr 2001
Question
Electra ARF - elevator pushrod help
I'm finishing up a Carl Goldberg Electra ARF and just discovered an issue with the elevator pushrod hitting the fuselage. I can get hardly any down elevator deflection. Here's a picture of the problem:
Should I cut the fuse side back or is there something I'm missing?
Dan
Ninjak2k is offline Find More Posts by Ninjak2k
Old Mar 18, 2004, 01:23 AM
Ninjak2k is offline
Joined Apr 2001
Here's a second picture from the side:
Old Mar 18, 2004, 03:05 AM
saint152 is offline
Find More Posts by saint152
saint152's Avatar
Formerly CA now Missouri
Joined Sep 2001
Just trim the control horn with a hobby knife to the lower hole that you arent using...
saint152 is offline Find More Posts by saint152
Old Mar 18, 2004, 06:47 AM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The pushrod is hitting the fuselage, not the control horn, correct?
Is the opening in the fuselage wide enough for the control horn and pushrod if it was moved to the left a little? If so, simply relocate the control horn. Take it off, fill the holes with CA, drill new ones over to the left a little, install it again.
..a
Old Mar 18, 2004, 10:02 AM
Ninjak2k is offline
Joined Apr 2001
Yes, it's the pushrod, not the control horn that is hitting. I don't think the opening is wide enough even if the horn is moved. It's almost touching the other side right now. Here's a very poor shot of how much clearance I have:
~Dan
Old Mar 18, 2004, 10:36 AM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I would cut the fuselage - just the side where the pushrod is binding. Make it a circular cut, centered on the hinge point (where the pushrod passes through the control horn). A dremel sanding attachment should make short work of this.
..a
Old Mar 18, 2004, 11:34 PM
RicVaughn is offline
Find More Posts by RicVaughn
USA, GA, Marietta
Joined Oct 2000
Hi,
I'm helping a friend of mine build one of these. I offset the horn to one side to cure this problem. You can also just cut some balsa away to clear the rod. Both methods will work just as well. The Electra is a great plane. I learned to fly on one, and have taught many people to fly on one. Mine is about 20 years old and still kicking.
Ric
RicVaughn is offline Find More Posts by RicVaughn
Old Mar 18, 2004, 11:48 PM
Ninjak2k is offline
Joined Apr 2001
Ric and Andy,
Thanks for the replies. I ended up cutting a small cutout as Andy suggested.
What angered me just a little was that their instructions have you place the horn exactly in the spot that will cause this problem. It may have cleared if I'd shifted the horn a little, the back should be setup to have clearance for the pushrod if you center the horns, as they instruct.
Ah well, problem solved.
Dan
Old Mar 21, 2004, 03:14 AM
YarSmythe is offline
Find More Posts by YarSmythe
Addicted to RC
YarSmythe's Avatar
USA, TX, Houston
Joined Nov 2003
I had a similar problem with the kit version. I ended up removing material from the inside for the control link to move freely. There is NO slop in my elevator for sure. Andy's suggestion was also good.
This is a great plane. I just finished mine last year and have had a ball learning all about brushless motors and gearing. I started with the canned motor then upgraded to a Mega 22/20/3 direct drive with a 10x6 prop. This was a big improvement. However, I've now calculated some fascinating numbers in Motocalc to pull the 22/20/3 out and replace it with a geared Mega 16/25/3 2.5:1 motor turning a 14x9 prop...giving me twice the climb rate! I just hope the wings don't rip off when I let her go!
Happy flying, -Lee
YarSmythe is offline Find More Posts by YarSmythe
Old Mar 25, 2004, 03:34 PM
Seared Ice is offline
Find More Posts by Seared Ice
The Airplane Gremlin
Seared Ice's Avatar
United States, PA, Pittsburgh
Joined Jun 2003
I'm building a Gentle Lady kit now and putting on a motor of my own. If I have the same problem, now I'll know how to fix it. I'm a few steps away from this step of construction and it seems that larger hole in the fuse is where the pushrod is supposed to come out...it must just be that they have the Electra set up sligthly differently than the Gentle Lady.
~John
Seared Ice is offline Find More Posts by Seared Ice
Old Mar 26, 2004, 10:14 AM
Sunspot is offline
Find More Posts by Sunspot
CLUB GITMO
Sunspot's Avatar
Little Rock National Airport
Joined Nov 2003
Electras
My Favorite above all my planes....I have one that is many years old and a couple of late models.
If anyone interested in making it a better a/c...spoilers, bolt-on wing, motor configs, contact me....
Spot
Sunspot is offline Find More Posts by Sunspot
Old Mar 26, 2004, 12:35 PM
Seared Ice's Avatar
Joined Jun 2003
What's "a/c" stand for? I'm gonna add on either flaps or spoilers to my Gentle Lady sometime in the future. I also might play around with the motor setup...maybe a 400 with gearbox rather than current 600. Also, rather than the basic rubber band setup, I have mine go to one peg in the back but to fuse side pegs at front...i did this because I totally changed the hatch arrangement when making it so I could mount the electric motor. The way i will put on the bands will also hold down the hatch.
Old Mar 26, 2004, 12:57 PM
Ninjak2k is offline
Joined Apr 2001
a/c stand for aircraft.
I'd like to see some pictures of the modifications you made if you are able. I also think a geared sp400 may be a great alternative. Lee is using a 16/15/X mega which is light as well. Mine does feel a little heavy at 45 oz with a geared Kyosho Endoplasma for power, but I'm happy with it for now.
~Dan
Old Mar 26, 2004, 01:39 PM
Sunspot is offline
CLUB GITMO
Sunspot's Avatar
Joined Nov 2003
electra
I use a chameleon 550 from tower 19 turn, 3:1 gearbox 12X8 prop. 8x1300scr's
20 second climbout to altitude.....usually 8 climbouts per sortie
I have had over 40 min flights.
A/C stands for aircraft.....Sorry , I slipped back into my military jargon.
I have more pics if your mail can handle it.
Old Mar 26, 2004, 02:07 PM
Sunspot is offline
CLUB GITMO
Sunspot's Avatar
Joined Nov 2003
electra
another shot of spoiler installation
Need new ARF 3d plane.... Help? seanpr123 3D Flying 9 Apr 22, 2004 07:24 PM
Electra ARF... EflightQC Electric Sailplanes 0 Sep 01, 2003 05:59 AM
Goldberg Electra ARF OldNSlow Electric Sailplanes 6 Jun 26, 2003 10:01 AM
Dandy Sport Aileron/Rudder/Elevator Hinging HELP NOVAflier Parkflyers 11 Jun 21, 2003 07:18 PM
