Old Feb 24, 2014, 07:29 AM
hunterdude is offline
Find More Posts by hunterdude
Joined Dec 2010
Guillows #905 P-51D freeflight warbird
Started this one this weekend. Coming from laser cut kits some of the fits are a little disappointing but I got kit from Hobby lobby with 40 percent off coupon.....for 8 bucks the plans are beautifully drawn and a pleasant build. I have heard flights of 30 seconds to 59 seconds are possible if built and trim well. As a kid I could never get a war bird to fly...I am looking forward to see If my build skills have improved. I imagine the flight times where without the rather heavy landing gear supplyed with kit. Also noticed the dihedral is quite a bit which may explain why this kit will fly. Pics coming soon!
hunterdude is offline Find More Posts by hunterdude
Old Feb 25, 2014, 01:37 PM
kevin matthews is offline
Find More Posts by kevin matthews
carbondale il
Joined Jan 2007
Here's mine.
kevin matthews is offline Find More Posts by kevin matthews
Old Feb 25, 2014, 08:23 PM
carbondale il
Joined Jan 2007
Be sure to take note of the two wing semi-span root ribs on the plan. Both are set at an angle for dihedral and bowed inward to fit flush up against the slightly curved surface of the fuselage sides.
Old Feb 25, 2014, 10:12 PM
Joined Dec 2010
Very nice camo and build Mr Matthews...have you flown her yet? what is a good build all up weight for good flight performance with this kit? I did notice the angled balsa part. I glued ribs in starting with tip and worked in to land gear area rib...glued angle part to that rib..then inner most rib to angle part to create bow...seems to dry fit well to fuse sides. I just noticed you upgraded to what appears to be PP silver prop? And much larger than stock? Do you like it? I have much to learn about trim and good prop and motor selection...thank you for sharing your pics!
Old Feb 26, 2014, 11:04 AM
carbondale il
Joined Jan 2007
Hunter, I haven't flown this model yet. I have exchanged the stock prop for a larger 7" for other models the same size and it works okay. Yes, it is a Peck. i'm going to exchange the Pecks for the Czech props, they are better. Larger props are more efficient. I'm glad you took care of the root ribs. I have several planes I'd like to maiden fly this coming season, the P51 included. I'm thinking a single loop of 1/8" might be enough. If you use a second layer of tissue for camo, apply it with dope instead of Elmer's white glue. Just brush on a coat over a couple of dry coats of dope and then brush another coat over the camo layer. Elmer's changed their formula a few years ago. It is stronger but it doesn't like a coat of dope on it.
Build Log Guillows P-51D Mustang #905 rc conversion servohead117 Scratchbuilt Indoor and Micro Models 48 Jan 09, 2015 06:48 AM
Build Log Guillows P-51D Kit #905 "May B, or C" MPP Scale Kit/Scratch Built 129 Sep 23, 2014 02:42 PM
Sold FMS V6 P-51D Petie Warbird (LPU Only) HardAbz Aircraft - Electric - Airplanes (FS/W) 9 Jan 04, 2014 01:16 PM
Discussion Plans Needed, Mustang P-51D Guillows Kit 905 delanok Free Flight 4 Jul 20, 2013 02:29 PM
