Old Aug 05, 2001, 10:32 PM
JStory is offline
Find More Posts by JStory
United States, TX, Dallas
Joined Jun 2001
Just got a Rayovac 9 volt NiMH battery will this work on an IFO?>
Went to frys and found it with a charger that can charge 9 volt Nicads and NiMH will this work on the ifo??? Should i remove that casing??/
JStory is offline Find More Posts by JStory
Old Aug 05, 2001, 11:47 PM
JStory is offline
Joined Jun 2001
Can any of you help me??
Old Aug 06, 2001, 09:17 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
For about the 15th time from the other thread, it won't work at all. The 8.4 volt NIMH Ray0vac has to high an internal resistance to work with a speed 280.
-Jim
Jim McPherson is offline Find More Posts by Jim McPherson
Old Aug 06, 2001, 10:41 AM
foss1997 is offline
Find More Posts by foss1997
toledo, oh, usa
Joined Nov 1999
I too am interested in this..... i have a 9v (8.4?) 120 mah nicad....can you remove the casing on this?
Scott
foss1997 is offline Find More Posts by foss1997
Old Aug 06, 2001, 02:44 PM
JStory is offline
Joined Jun 2001
Why wont it work at all??? Becasue the morning i flew my IFO with it and i didnt even fully charge it. It didnt do loops or anything but it flew like it has been flying on my 6 cell pack.
Old Aug 06, 2001, 03:23 PM
rpage53 is offline
Find More Posts by rpage53
Boffin
rpage53's Avatar
Victoria, BC, Canada
Joined Apr 2001
As you found out, it can work but the motor wants to draw more than the 9V battery can provide. The battery will get stronger at first, then noticeably weaker after a few dozen flights. One of mine is at half capacity from abuse.
Since these are so cheap, you can use 2 in parallel and then get very long flights and provide the current.
rpage53 is offline Find More Posts by rpage53
Old Aug 06, 2001, 03:33 PM
rpage53 is offline
Boffin
rpage53's Avatar
Joined Apr 2001
Old Aug 06, 2001, 06:23 PM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
You can remove the casing on a GE/Sanyo 9V NiCd battery. Inside are 6 AAAA size cylindrical cells. Just be careful not to short it out, as those little NiCd cells generate a lot of heat right now.
Dave Hederich is offline Find More Posts by Dave Hederich
Got a 3DX, will this work? Thomas Manson 3D Flying 0 Jan 19, 2004 09:42 PM
Slow Stick, 8-cell 720mah NiMh, and Pixie-7P ESP. Will this work? down_shift Parkflyers 1 Feb 11, 2003 03:35 PM
Will this work as a slow charger to condition Nimh packs??? flipnidaho Batteries and Chargers 4 Jan 25, 2003 03:10 PM
Fast Charger for RAYOVAC 9 volt Nimh Batteries? Jamie- Power Systems 2 Jul 25, 2001 11:00 AM
Rayovac 9 volt Battery found on-line. PaulNJ Parkflyers 0 May 12, 2001 12:23 AM
