Old Feb 22, 2014, 10:42 AM
jwmachon is offline
Find More Posts by jwmachon
Joined Dec 2008
3542 1185kv or 3548 1100kv
I,
Lookin at the above motors to install on a godiscover, im wanting it for range.
I have a 80a esc already
Which should I go for and which prop should I choose
Many Thanks
Jonny
jwmachon is offline Find More Posts by jwmachon
Old Feb 22, 2014, 03:28 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
We need details.... link to aircraft, make of motor, cell count
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Feb 22, 2014, 04:55 PM
jwmachon is offline
Joined Dec 2008
http://www.hobbyking.co.uk/hobbyking...00mm_PNF_.html
Looking at running on 3s 5000mah may be 2x 3s 5000
Motor 1
http://www.hobbyking.co.uk/hobbyking...arehouse_.html
Running 11x7 or 12x6
Motor 2
http://www.hobbyking.co.uk/hobbyking...ner_Motor.html
Old Feb 22, 2014, 04:56 PM
jwmachon is offline
Joined Dec 2008
This will be a model for distance and cruising on low amps open to other suggestions on 35 size motors
Old Feb 22, 2014, 08:18 PM
Dr Kiwi is offline
Dr Kiwi's Avatar
Joined May 2003
If long flight time is the aim, I'd go to 4s, and a minimal prop size which would still fly the plane, to reduce amp draw.
If you have the 3s packs then choose a minimal prop size which would still fly the plane, and reduce amp draw.
Old Feb 23, 2014, 04:04 AM
jwmachon is offline
Joined Dec 2008
Won't be using 4s it's really doin my head in now lol, really can't decide on 3542 1000kv or 3548 1100kv, I thought going bigger prop like 12x6 would be most efficient
Old Feb 23, 2014, 06:15 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The primary difference in the motors is that one is a 120g motor and the other is a 173g motor. In the links you posted there is no 1185 Kv motor, they are 1100 Kv and 1800 Kv.
If those are the two motors you are considering the 3548-1100 Kv motor would be the best choice for the larger props and for long distance or long duration low energy flights. The heavier motor will handle the highest input power and the lower Kv will also handle the larger prop best.
The 173g motor would be able to handle an input of 520W by the 3W per gram rule.
And the testing data on the APC E 12 x 6 shows that a 500W or so motor will be enough for that prop too:
APC E 12x6 - www.flybrushless.com/prop/view/51
If you were considering a slow fly prop (generally always worth trying for the low energy flights) it might work too. There is not a lot of test data on the APC SF 12x6 here but it looks like it might do OK:
APC SF 12x6 - www.flybrushless.com/prop/view/50
Jack
jackerbes is offline Find More Posts by jackerbes
Old Feb 23, 2014, 06:33 AM
jwmachon is offline
Joined Dec 2008
sorry linked wrong motor not 1800kv lol
Old Feb 23, 2014, 06:47 AM
jwmachon is offline
Joined Dec 2008
Would be nice to choose a motor / prop combo that would work fine on 3s and also 4s and just swap props as I know 4s are more efficient
Old Feb 23, 2014, 06:49 AM
Jack
USA, ME, Ellsworth
Joined May 2008
OK, even with the smaller difference in the Kv's, I would probably make the heavier motor the first choice.
On 3S you are going to have a no load RPM of 12.3V x 1185 or 1100, that would be 14,575
or 13,530 RPM. The APC E props recommend a max of 145,000 / dia. in inches and the SF props a limit of 65,000 / dia. in inches
So on 3S you will have the SF prop way over it's limit at full throttle. If you want to use a SF prop you would really have a much more efficient setup if you had a lower Kv, about half of what you are looking at now. Look at the Kv's and weights on the motors reported in the testing data I posted a link to
Jack
Old Feb 23, 2014, 07:04 AM
jwmachon is offline
Joined Dec 2008
I will try and work out charts not my strong point lol what would u recommend for most efficient set up motor/prop wise
Thankuou
Old Feb 23, 2014, 07:08 AM
jwmachon is offline
Joined Dec 2008
Think what ur saying is go for 3548 1100kv with 12x6 prop apc-e
Would I have option then to go for 11x7 on 4s later if wanted
Old Feb 23, 2014, 07:09 AM
jwmachon is offline
Joined Dec 2008
Not going to on with sf prop
Old Feb 23, 2014, 07:28 AM
Jack
USA, ME, Ellsworth
Joined May 2008
The 12 x 6 APC E has a recommended max RPM of about 12,000 RPM but it seldom need to be used at that full value.
On 3S the 1100 Kv motor would have a no load RPM of 13,530 RPM at 12.3V. But the voltage will fall under load and as the battery is depleted and that will drop the RPM. And you will not be flying at full throttle in the interest of duration and range. So, all things considered, the 1100 Kv motor and the APC E 12x6 are a good match.
Do you know the weight of the airplane? Or can you post a link to it? A typical airplane only needs a thrust of about 0.33:1 to 0.50:1 to fly well. So if you look at the thrust curve on the APC E 12x6 test data page, you can see that full throttle and full thrust is not needed after takeoff.
It if good to have power in reserve for unexpected winds and emergency maneuvers but many planes will fly on a lot less than full throttle.
And we still don't know what a "godiscover" airplane is.
Jack
Old Feb 23, 2014, 07:40 AM
jwmachon is offline
Joined Dec 2008
Lol sorry mate
Sold Turnigy sk3-3542 1185kv nib jkx250 Aircraft - Electric - Power Systems (FS/W) 1 Aug 17, 2013 12:53 PM
For Sale Turnigy 3548 1100kv Take It Outside Aircraft - Electric - Airplanes (FS/W) 3 May 25, 2013 09:53 AM
Discussion parkzone extra 300 turnigy 3548 1100kv daalma Power Systems 7 Nov 23, 2012 06:10 AM
Discussion Turnigy SK3 3548- 1050kv or NTM prop drive 35-48A 1100kv rcalldaylong Power Systems 7 Jul 11, 2012 11:53 PM
Sold Turnigy 3548/04 1100kv NIB - $26 shipped. hillbille Aircraft - Electric - Power Systems (FS/W) 4 Sep 05, 2009 02:03 AM
