Old Mar 17, 2004, 09:48 AM
iflych52 is offline
Find More Posts by iflych52
Helena, Montana, United States
Joined Sep 2003
Does this sound right? irate 850
Hello all,
My SA Dystraction has a Typhoon micro 6 and flew it with etec 2s700 w/ GWS HD 7x3.5
Just enough to keep it flying wings level. RPM was about 10,000 at 4amps. I put my new irate 850 2s pack and a GWS HD 8x4 which seems like twice the prop. Have not had a chance to fly but did tach it and guess what... abuot 10,000 RPM
Is this due to the irate holding up under better under load? WOW what a difference. Did not get a chance to check current.
Mike, did not see the 850 on your website only the 830. I hope you will carry the 850 for the same price you recently had. A great cell at a great price.
Thanks Aaron
iflych52 is offline Find More Posts by iflych52
Old Mar 17, 2004, 10:08 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Irates do hold up better than e-techs, capacity for capacity.
Howver new e-techs are in the pipeline....
Old Mar 17, 2004, 11:00 AM
mkirsch1 is offline
Find More Posts by mkirsch1
United States, NY, Spencerport
Joined Oct 2001
4 Amps on a .7Ah cell is about 5.7C, which is close to the limit of Etec cells. By then, voltage is already dropping off significantly. Attempts to draw more Amps from the cells will only result in the voltage dropping further.
The Irates are rated for 10C, and a TRUE 10C at that, so even if you're drawing twice as many Amps with the larger prop, you're still in the 9C area.
mkirsch1 is offline Find More Posts by mkirsch1
Old Mar 19, 2004, 03:27 AM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
The 830's you saw are replacements for the 850's. Get this, they have 10% higher voltage under load than the 850's. I haven't used my 850 packs yet, but have used 2s2p 500 and 2s 1300's and love them to death (no not really)! They transformed my plane from barely flyable to WOW! it flys like a bird and needs throttle management.
Flyit and see for yourself!
Justin
roccobro is offline Find More Posts by roccobro
Does this sound right? Beeping ESC, rumbling motor QuazBotch Power Systems 6 Aug 05, 2005 02:03 PM
Does this sound right to you? louisd Batteries and Chargers 1 Mar 25, 2005 03:55 PM
Question does this sound right? stirlingnut Power Systems 0 Mar 12, 2005 01:50 PM
GWS Spitfire - does this sound right? mattski Parkflyers 10 Sep 07, 2003 08:17 PM
Does This Sound Right? Scomis Parkflyers 4 Mar 01, 2002 11:46 AM
