Old Feb 20, 2014, 07:47 AM
subpixel is offline
Find More Posts by subpixel
subpixel's Avatar
United Kingdom, England, Nottingham
Joined Dec 2007
New Product
- WLtoys v272 nano quad
The first of many nano quads to be released recently to compete with the hubsan nano.
Cheapest places to order the quads and spares from are currently Tmart, Banggood, dx.com and Tinydeal
RTF
Tmart - V272 RTF all colours avail for $25.98 $24.68 with code summer (US and China warehouses)
BNF
TINYDEAL v272 BNF all colours available $16.89
Tmart - $16.88 $16.04 with code summer(avail from both US & China warehouses)
- Black
- Green
- Yellow
Spares (and best prices listed)
Tmart
- Prop guards $2.36 (red,white,black,yellow or green)
- 5pack 100mah batteries $14.99 (US warehouse)
- set of props $1 (all colours avail, only China warehouse this price)
dx.com
- 4 sets of props $3.36 (all colours avail)
- Canopy + motor holders $3.36 (yellow / red) green is $3.40)
Banggood
- 5pack 100mah batteries $13.99
- Canopies (yellow, black, green) $1.46
- Motors $1.61 each
- Motor holders (green, red or yellow)
- Rubber feet $0.89
- Replacement frame/pcb $10.71
Tips/Info
my mini review http://www.rcgroups.com/forums/showthread.php?t=2134608
ASCII's bitesize review
mnemennth's First Reaction mini review (pre release pcb version)
Uses wltoys v2xx protocol
1st release with LGW58001RX7 pcb had a poor quality battery with a protection circuit that liked to fail as seen when the quad simply dies and requires switching off and back on, frequently occurs when given full throttle. Fix is to replace the battery.
It also had very loose fitted props that fell off at the lightest touch and are largely responsible for the quad consistently veering off in one direction and not responding to stick movement. The spare props in this case are a much tighter fit and fix the issue.
If you still have loose props you can try a number of things such as dental floss through the prop, although this doesn't work that well I've found.
You could also try a thin layer of super glue on the motor shaft but this may work a bit too well and leave you unable to remove the prop at all. Wood glue/pva in the prop hole is another way which works and is quick to do and not permanent.
Current pcb revision is LGW58001RX9, the included battery with this batch is now different and much more reliable it would appear.
The loose fitted props issue looks to have been addressed as well.
Both versions suffer from an issue with the resistor for the top right red LED having a bad trace causing that LED to have no power, apart from loosing 1 light it doesn't have any other effect so is just cosmetic and annoying, I wonder if we'll see a 3rd revision to fix this issue.
Gyro calibration
If your having issues with it drifting and your props are tight one thing you can try is recalibrating the gyros, you do this by putting it in 80% or 100% rates and then pull and hold both sticks full down and left until the LEDs flash then release the sticks and your done.
LGW58001RX7 top / LGW58001RX9 bottom
LGW58001RX7 unreliable battery 3.62g (top)
Replacement good battery bought separately 3.53g (middle)
LGW58001RX9 good battery 3.39g (bottom)
subpixel is offline Find More Posts by subpixel
Old Feb 20, 2014, 07:49 AM
SeByDocKy is online now
Find More Posts by SeByDocKy
SeByDocKy's Avatar
France, PACA, La Valette-du-Var
Joined Dec 2012
Yep a nano clone .... Good catch subpixel
SeByDocKy is online now Find More Posts by SeByDocKy
Old Feb 20, 2014, 08:00 AM
MassiveOverkill is offline
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Muhahahhaaaaaaaa!!!!!!!!!!!
MassiveOverkill is offline Find More Posts by MassiveOverkill
Site Sponsor
Old Feb 20, 2014, 08:02 AM
SeByDocKy's Avatar
Joined Dec 2012
MO
I know that you know other WLtoys quad are coming soon But DNA DNA ...
Old Feb 20, 2014, 09:20 AM
Cryps is offline
Find More Posts by Cryps
Decomposing and tearin' it up!
Cryps's Avatar
The Netherlands, ZH, Zevenkamp
Joined Mar 2013
Wow! Didn't see that coming /s
Cryps is offline Find More Posts by Cryps
Old Feb 20, 2014, 09:24 AM
jameschen072 is online now
Find More Posts by jameschen072
The flightless bird
jameschen072's Avatar
Joined Aug 2004
Aha, I was wondering when the news of this quad was gonna filter through
jameschen072 is online now Find More Posts by jameschen072
Latest blog entry: The Fei-Lun FT011 Review
Old Feb 20, 2014, 09:42 AM
SeByDocKy's Avatar
Joined Dec 2012
Since I am not planning to go to jail sooner for training nanoquads, I was expecting a bigger model from WLtoys
Old Feb 20, 2014, 09:44 AM
Joined Feb 2011
Just wait a little bit..................
Site Sponsor
Old Feb 20, 2014, 02:51 PM
subpixel is offline
subpixel's Avatar
Joined Dec 2007
So.... James, Mo if I were to accidentally buy one would you say that was a good accident or a bad one
Old Feb 20, 2014, 03:07 PM
scousethief is offline
Find More Posts by scousethief
United Kingdom, England, Redcar
Joined Jan 2006
nice quad and nicer price
scousethief is offline Find More Posts by scousethief
Reply With Quote  (Disabled)
Old Feb 21, 2014, 09:51 AM
theimacman is offline
Find More Posts by theimacman
Flyin' Ryan
theimacman's Avatar
United States, IL, Champaign
Joined May 2012
Hubsan certainly won't be happy about this. Will likely go through some changes before coming out, like the V252.
theimacman is offline Find More Posts by theimacman
Old Feb 21, 2014, 11:59 AM
subpixel is offline
subpixel's Avatar
Joined Dec 2007
I doubt we will see banggood selling it I agree but as for it changing, don't forget tmart still sell the original v252 with the all clear shell, you should know this given you bought one of them
Old Feb 21, 2014, 12:07 PM
Flyin' Ryan
theimacman's Avatar
Joined May 2012
Touché.
Old Feb 21, 2014, 12:25 PM
SeByDocKy's Avatar
Joined Dec 2012
Pfff .... I pressed check-out button but with 5% code + and -2,7 euros so got it for 19 euros .... it's not a big spending
Old Feb 21, 2014, 12:30 PM
Flyin' Ryan
theimacman's Avatar
Joined May 2012
I ordered it too, along with a green Hubsan Q4 Nano. Not holding my breath on seeing them any time soon though. heh
