Building & flying a 55” EPP P51 Mustang Miss America
Hi all,
A few weeks back, I posted here to see if there was an interest in the CAM range of models (www.combatairmodels.com) and even though a few people posted some answers, there was much less interest than I was expecting. Whether this is because not many people have an interest in EPP PSS models or these particular models do not appeal to you, I cannot tell. It appeared that the CAM models are very different to the Leading Edge Gliders or Patton PSS EPP models. They are not some of these High Performance gliders (wing section used is S3021, not as fast as RG15/14…), but this is not the philosophy of Bruno at CAM. Bruno intends to offer a range that is fun to fly but still looks fairly scale. One deciding factor concerning the wing section is that it had to allow installation of standard servos. I have seen his models fly and decided to import a few for the guys at my local slope. We now have 2 P51 and 2 Spitfires that should be flying soon. I will have an F5 Tiger soon too. Quite unusual is the size of the models. They are not 48 inches, they are not 60 inches, they are 55 inches (a deciding factor was the size of the boxes that are available to Bruno). I am posting here the assembly technique because I can see you guys with LEG or Patton planes spend hours trying to get that perfect scale finish, and even though I admire your work, this is not what EPP models are about to me. At the slope, we want to use our models for combat too, hence we do not want to paint our models. My P51 will also be very aerobatic by adding a rudder, and I can’t stop thinking about knife-edge when I look at the side area of its fuse. So this thread is about a simple building technique to obtain a fairly scale (semi-scale I guess) finish and still be able to use the model for combat. I used the same technique as for EPP flying wings, the only difference being that I used Solartex (a heavy but strong covering) instead of Oracover/Solarfilm and others. I will also post my impressions about the flying and certainly some airborne shots and videos will follow. My set up is 4 Futaba S3001 servos (I have had some in my flying wings for 2 years without breaking a gear ever, I even broke twice the servo arm after a hit on my aileron – the control rod is very rigid – and the gears are still fine), a Multiplex Pico 4/5 receiver and a 4 cells pack of HE1100 NiMh. I am also using a switch with harness. I did a few modifications to the model too: I made the wing removable and fitted a tow hook on the model. Some of you might still be using the expensive 3M77, but I found a much cheaper alternative that seems to work as well: I tried Spray Glue for In Car bass box (people that make their own bass box use it to stick the carpet to the MDF) and simple Carpet Spray Glue (the latter being the cheapest one at £3.99 for 500ml). And they seem to do the job as well as the 3M77 (£15 in UK,when it was available that is) Also, I used 5mins epoxy and Silicon (the type used for gluing/fixing fish tanks, which is also the type of silicon recommended to do the hinges on the Aeromod range of moulded gliders) when required. The main reason for using these glues is that I had them available and didn’t know the UK alternative for the Shoe Goo you guys are using in the US. Here is a picture of what comes in the kit. All I needed to complete the model was Spray Glue (3M77 or similar), 3 (4 in my case) standard servos, a receiver, a receiver pack, a switch harness with charging plug and some Solartex (blue, red and white). I also had to purchase some semi-flexible control rods (Sullivan type) and made a U shape piano wire for the 2 elevator halves (I used 3mm instead of the 2mm advised because I was not happy with the 2mm one). Shown here is the the P51 |
I started the building with the fuselage. Cutting a band of sandpaper allows you to sand the fuse very easily and still have a nice symmetrical round shape at the end. You only need to move the sandpaper band from side to side whilst holding the fuselage in between your legs. I sanded the fuse to shape, trying to be as close as possible to the full size P51 (thanks to pictures found on http://www.airwar.ru/other/drawe.html). I used 240 grit sandpaper to finish with 600 grit.
| Thread Tools | |
| Sold P-51 Mustang, Miss America ARF | bruff | Aircraft - Electric - Airplanes (FS/W) | 4 | Jul 27, 2007 10:12 AM |
| Hangar 9 Miss America P51 | Joe Ford | Fuel Warbirds | 2 | Nov 23, 2004 10:55 PM |
| World Models Miss America P51 80" WS | overpowered | Giant Scale Airplanes | 3 | Aug 22, 2004 10:57 PM |
| Building my own EPP flying wing | soholingo | The Builders Workshop | 4 | Apr 28, 2004 11:50 PM |
| Brushless Epp JAS Gripen, building and flying | henke | Foamies (Kits) | 7 | Apr 17, 2004 11:21 AM |
