Espritmodel.com Heli Air
Old Mar 16, 2004, 01:36 AM
coffeemug's Avatar
Duluth MN
Joined Jan 2004
Webra T4-60 break in...
I'm finally getting around to using the Webra T4-60 I purchased around 1990 or so. Initially I didn't give it much of a break in. It would (seem to) lean out in the air and every flight was a deadstick. Now I'm finally going to give it another try, and hope someone out there might be able to suggest whether it needs more break in time or if the Webra T4-60's had some inherant problem like poor fuel draw ect. (I'm expecting it to replace the old Saito .45 on the front of my Playboy Sr. which needed a lot of added noseweight anyhow.) Thanks for any suggestions. Nick
coffeemug is offline Find More Posts by coffeemug
Old Mar 21, 2004, 07:52 PM
Cold Weather Eh?
Kiana, Alaska
Joined Dec 2003
ONe of the first things you may want to do, is to check the compression, then if it is still good it should be fine. Though you may want to run some engine oil in it. If the engine is kinda hard to turn over, i would reccommend a short time where you basically break it in over again.
alaska_flyer is offline Find More Posts by alaska_flyer
Old Mar 21, 2004, 08:42 PM
coffeemug's Avatar
Duluth MN
Joined Jan 2004
The compression seems to be fine, and it seemed to furn over well enough before and better after some Marvel Mystery oil. I'll run it in some more when I get a chance... Thanks
-Nick
Webra 40 blackhead, Break in Cman Engines 1 Jul 25, 2005 07:12 AM
Webra T4-60 Wanted SON OF PALEFACE Aircraft - Fuel - Airplanes (FS/W) 5 Nov 25, 2002 12:17 PM
What and how to oil after motor break-in ? jnyoun Electric Plane Talk 3 Jun 05, 2001 08:18 AM
