Old Feb 13, 2014, 02:45 PM
hunterdude is offline
Find More Posts by hunterdude
Joined Dec 2010
pistochio scale?
Any source for pistachio scale kits?
hunterdude is offline Find More Posts by hunterdude
Old Feb 13, 2014, 05:05 PM
g_kandylakis is offline
Find More Posts by g_kandylakis
free flight or micro RC ???
g_kandylakis's Avatar
Greece, Central Macedonia, Thessalonika
Joined May 2006
I think none... I do not recall any.
Only peanut scale kits.
Pistachios were mostly built out of plans...
g_kandylakis is offline Find More Posts by g_kandylakis
GeorgeG97322 is offline
Find More Posts by GeorgeG97322
Power Upward
GeorgeG97322's Avatar
United States, OR, Albany
Joined Jun 2007
None to my knowledge, They are build your own. I do have several plans though.
George
GeorgeG97322 is offline Find More Posts by GeorgeG97322
Old Feb 13, 2014, 06:45 PM
Rhudson1960 is offline
Find More Posts by Rhudson1960
Rhudson1960's Avatar
United States, NY, Fulton
Joined Sep 2013
George
Never seen a pistachio kit either. Best way to get a Pistachio plan is to shrink down a peanut plan and use smaller wood. That worked for Walt Mooney!
Go nuts!
Rhudson1960 is offline Find More Posts by Rhudson1960
Old Feb 13, 2014, 10:42 PM
Joined Dec 2010
What I would like to build is a tiny old timer competition model like the Peck polmer Moth. That model is 24" span I think. May have to reduce rib count and sliced rib top covered under camber wing to get weight out of larger model design?
Old Feb 14, 2014, 01:16 AM
Joined Sep 2013
You can find plans for the Momth (FA or Flying Aces Moth) on the net. Here is one on Outerzone:
http://www.outerzone.co.uk/plan_details.asp?ID=1828
I would do it this way:
Print the plan to fit on an 8.5 x 11 page in landscape orientation. I just did this and it comes to, would you believe? 8 inches.
Build with 1/32 or 1/20 light balsa
For the wing, leave out every 2nd and 3rd rib out from the center section
Tail surfaces, just the outlines and spars
Fuselage. Maybe remove 1/3 of the uprights and cross pieces. It will be a very tight fuselage, but I think a loop of 1/16 rubber will fit OK, just don't make it very long.
Use a balsa prop and make it light. This version of the plan has a long nose!
Old Feb 14, 2014, 06:27 AM
Joined Dec 2010
Thanks for the help guys...if you know of a good flying simple old timer that would lend itself to reduced scale even better than the Moth, I am open to it. My goal is a good flyer.
Old Feb 14, 2014, 08:59 AM
DuPageJoe is offline
Find More Posts by DuPageJoe
USA, IL, Wheaton
Joined Oct 2010
I have found some pistachios in Algy2's scans from Aeromodeller. One that's in my collection of plans is of a '20's German airliner, a nice high winger, with bones by Dave Linstrum. Instead of me re posting it you should be able to find it from the file name. Otherwise, there are more pistachios out there by Dave you could search for using Dave's name.
MESSERSCHMITT M.20B. SCALE PISTASHIO. ARTICLE & PLAN. AEROMODELLER APRIL 1997
Here is the link to this. http://www.rcgroups.com/forums/showp...&postcount=979
DuPageJoe is offline Find More Posts by DuPageJoe
Old May 26, 2014, 04:41 PM
Mason W. is offline
Find More Posts by Mason W.
You know our motto, We deliver
Texas
Joined Nov 2010
Well I can actually make the print wood for pistachio scale models if your interested. I've done it with a comet tbf avenger that I scaled to pistachio scale and made the plans and the print wood that small and just used a balsa stripper to make a smaller sized stringers.
Mason W. is offline Find More Posts by Mason W.
Old Jun 04, 2014, 02:08 AM
lincoln is offline
Find More Posts by lincoln
United States, MA, Waltham
Joined Dec 2001
I've seen pistachio sized old timers flown indoors. They were entertaining. Pick something with a low aspect ratio wing.
This one was always meant to be small, but looks a lot like an old timer:
http://www.rcgroups.com/forums/showp...postcount=9243
I built one of these at the original size. Flies nicely indoors, and very slowly. I tried to use light wood, but I did make the specified bamboo wing tips, which added a lot to the weight. If you hang a plastic prop on it, it will be severely nose heavy. It looks nice with a carved wood prro
Some old ROG's and such that are already pretty small would make nice "pistachios" too:
http://outerzone.co.uk/plan_details.asp?ID=5597
http://outerzone.co.uk/plan_details.asp?ID=895
http://outerzone.co.uk/plan_details.asp?ID=2440
http://outerzone.co.uk/plan_details.asp?ID=5583
This design is already a miniature old timer, but a further reduction to pistachio size might be pretty good:
http://outerzone.co.uk/plan_details.asp?ID=4216
other possibilities:
http://outerzone.co.uk/plan_details.asp?ID=4295
http://outerzone.co.uk/plan_details.asp?ID=3543
http://outerzone.co.uk/plan_details.asp?ID=4317
lincoln is offline Find More Posts by lincoln
Build Log Resume Build Aero A.35 1/12 scale 47-5/8" Otakar Scale Kit/Scratch Built 44 Apr 09, 2016 06:55 AM
Contest Scale Build-Off 3: 1/8 Scale Bellanca Cruisemaster Dennis Sumner Scale Kit/Scratch Built 218 Jul 13, 2015 04:34 PM
Question Should we Separate this Forum into Scale ARF/RTFs and Scale Kit/Scratch Builds? Steve85 Scale ARF/RTF 215 Dec 29, 2013 04:14 PM
For Sale Trex600e fbl in scale fuselage(scale flying) lyonsdan Aircraft - Electric - Helis (FS/W) 2 Oct 15, 2013 04:36 PM
Sold Big 1/5 Scale Pica P-40 Kit Box is Still Sealed and 1/5 scale cockpit kit CADILLAC200 Aircraft - Fuel - Airplanes (FS/W) 1 Oct 06, 2013 09:29 PM
