| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Guest
Posts: n/a
Re: Small Air conditioner compressor convert to air compressor &
krem wrote:
> Hello, I have a small window air conditioner that has been discharged of the > freon and was wondering if i could convert it to be either a compressor or a > vacuum pump. Possibly both? The ac was working perfectally before it was > dropped and one of the copper pipes in a radiator cracked releasing the > coolent. > > Here are a couple of sites to look at. http://www.paragoncode.com/shop/vacuum_pump/ http://www.berkut13.com/sucker.htm Howard Garner Pickens, SC |
#2 |
Guest
Posts: n/a
krem wrote:
> Hello, I have a small window air conditioner that has been discharged of the > freon and was wondering if i could convert it to be either a compressor or a > vacuum pump. Possibly both? The ac was working perfectally before it was > dropped and one of the copper pipes in a radiator cracked releasing the > coolent. > > It might be good to put an inline oiler on the intake side since there is a lot of metal rubbing against metal inside the pump. Not sure the oilers used on pressure lines would work, but it would be worth a try. -- Gerald Ross, Cochran, GA To reply add the numerals "13" before the "at" ............................................ No matter who you vote for, the government gets elected. -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- http://www.newsfeeds.com - The #1 Newsgroup Service in the World! -----== Over 100,000 Newsgroups - 19 Different Servers! =----- |
#3 |
Guest
Posts: n/a
> a vacuum pump should be perfect for an old a/c unit pump.. but a
> compressor i dont believe.. unless you want a low power 2-4 lbs. of > pressrue??? you can go to harbor freight and for $10 get one of those 12 > volt air pumps for your car and it will run circles around the old a/c > [pump... Will those suck as well as blow ? -- Boo |
| Thread Tools | |
| Alert small air compressor | Cessna 182 | Hot Online Deals | 10 | Jul 18, 2007 09:43 PM |
| Sold Air brush compressor | Twmaster | Aircraft - General - Miscellaneous (FS/W) | 0 | Feb 15, 2007 02:01 PM |
| Wanted Air brush and compressor | jlewis99 | Aircraft - Electric - Airplanes (FS/W) | 2 | Aug 06, 2005 06:59 PM |
| Air conditioner compressor for vac. bagging instead of fridge pump? | Stuart A. Hall | RCSE | 2 | Feb 20, 2005 12:02 PM |
| Small Air conditioner compressor convert to air compressor & vacuum pump? | krem | uk.rec.models.engineering | 14 | Mar 18, 2004 07:03 PM |
