| RCCars | Crack Roll | Flying Giants | RC Power | The E Zone | Lift Zone | Our Sponsors | |||||||||
#1 |
Guest
Posts: n/a
Small Air conditioner compressor convert to air compressor & vacuum pump?
Hello, I have a small window air conditioner that has been discharged of the
freon and was wondering if i could convert it to be either a compressor or a vacuum pump. Possibly both? The ac was working perfectally before it was dropped and one of the copper pipes in a radiator cracked releasing the coolent. |
#2 |
Guest
Posts: n/a
Re: Small Air conditioner compressor convert to air compressor & vacuum pump?
"Howard R Garner" <hrgarner@innova.net> wrote in message news:EHo5c.6692$CI3.3241@fe03.usenetserver.com... > krem wrote: > > Hello, I have a small window air conditioner that has been discharged of the > > freon and was wondering if i could convert it to be either a compressor or a > > vacuum pump. Possibly both? The ac was working perfectally before it was > > dropped and one of the copper pipes in a radiator cracked releasing the > > coolent. > > > > > > Here are a couple of sites to look at. > > http://www.paragoncode.com/shop/vacuum_pump/ > http://www.berkut13.com/sucker.htm > > Howard Garner > Pickens, SC > Good, I see that these are being used for vacuume pumps but would the air outlet on them be enough for an airbrush if a holding tank was attached? What kind of pressures would it be able to build up? |
#3 |
Guest
Posts: n/a
On Mon, 15 Mar 2004 21:27:37 GMT, "krem" <news@rkremser.endjunk.com>
wrote: > >"Howard R Garner" <hrgarner@innova.net> wrote in message >news:EHo5c.6692$CI3.3241@fe03.usenetserver.com. .. >> krem wrote: >> > Hello, I have a small window air conditioner that has been discharged of >the >> > freon and was wondering if i could convert it to be either a compressor >or a >> > vacuum pump. Possibly both? The ac was working perfectally before it >was >> > dropped and one of the copper pipes in a radiator cracked releasing the >> > coolent. >> > >> > >> >> Here are a couple of sites to look at. >> >> http://www.paragoncode.com/shop/vacuum_pump/ >> http://www.berkut13.com/sucker.htm >> >> Howard Garner >> Pickens, SC >> > >Good, I see that these are being used for vacuume pumps but would the air >outlet on them be enough for an airbrush if a holding tank was attached? >What kind of pressures would it be able to build up? > These pumps are wet sump lubricated and air discharged would carry a certain amount of oil with it. You would have to fit an oil seperator to stop oil mixing with the paint, the case of the pump itself acts a holding tank for a vacuum (to allow oil mist to settle out of the gas). HTH John |
#4 |
Guest
Posts: n/a
"krem" <news@rkremser.endjunk.com> wrote in message news:35269c4a677e652621b6f244e2de4c15@news.teranew s.com... > Hello, I have a small window air conditioner that has been discharged of the > freon and was wondering if i could convert it to be either a compressor or a > vacuum pump. Possibly both? The ac was working perfectally before it was > dropped and one of the copper pipes in a radiator cracked releasing the > coolent. > You might ask the folks over in alt.hvac. Good luck--else at least have some fun and report back to us... <G> -- SVL |
#5 |
Guest
Posts: n/a
"krem" <news@rkremser.endjunk.com> wrote in message news:9ff12297bb7110c395d7729c31b839fe@news.teranew s.com... > > "Howard R Garner" <hrgarner@innova.net> wrote in message > news:EHo5c.6692$CI3.3241@fe03.usenetserver.com... > > krem wrote: > > > Hello, I have a small window air conditioner that has been discharged of > the > > > freon and was wondering if i could convert it to be either a compressor > or a > > > vacuum pump. Possibly both? The ac was working perfectally before it > was > > > dropped and one of the copper pipes in a radiator cracked releasing the > > > coolent. > > > > > > > > > > Here are a couple of sites to look at. > > > > http://www.paragoncode.com/shop/vacuum_pump/ > > http://www.berkut13.com/sucker.htm > > > > Howard Garner > > Pickens, SC > > > > What kind of pressures would it be able to build up? > 400psi high enough for you ? -- SVL |
#6 |
Guest
Posts: n/a
"Gerald Ross" <gwader@netcommander.com> wrote in message
news:405663cb_5@corp.newsgroups.com... > krem wrote: > > Hello, I have a small window air conditioner that has been discharged of the > > freon and was wondering if i could convert it to be either a compressor or a > > vacuum pump. Possibly both? The ac was working perfectally before it was > > dropped and one of the copper pipes in a radiator cracked releasing the > > coolent. > > > > > It might be good to put an inline oiler on the intake side since there > is a lot of metal rubbing against metal inside the pump. Not sure the > oilers used on pressure lines would work, but it would be worth a try. > > -- > > Gerald Ross, Cochran, GA > To reply add the numerals "13" before the "at" > ........................................... > No matter who you vote for, the > government gets elected. > > > > > -----= Posted via Newsfeeds.Com, Uncensored Usenet News =----- > http://www.newsfeeds.com - The #1 Newsgroup Service in the World! > -----== Over 100,000 Newsgroups - 19 Different Servers! =----- What kind of oil should be used? something as simple as wd40 or a heavier oil? |
#7 |
Guest
Posts: n/a
I've used freezer pumps for both pressure and vacuum. I've taken the
pressure up to 150 p.s.i.g. (the kit wasn't safe for more) but there was plenty to go. An oil run-back on the pressure side is essential. Also, these pumps won't start on pressure. PrecisionMachinisT <Precisionmachinist@hotmail.com> wrote in message news:c36135$241gqs$1@ID-178395.news.uni-berlin.de... > > "krem" <news@rkremser.endjunk.com> wrote in message > news:35269c4a677e652621b6f244e2de4c15@news.teranew s.com... > > Hello, I have a small window air conditioner that has been discharged of > the > > freon and was wondering if i could convert it to be either a compressor or > a > > vacuum pump. Possibly both? The ac was working perfectally before it was > > dropped and one of the copper pipes in a radiator cracked releasing the > > coolent. > > > > You might ask the folks over in alt.hvac. > > Good luck--else at least have some fun and report back to us... > > <G> > > -- > > SVL > > |
#8 |
Guest
Posts: n/a
On Mon, 15 Mar 2004 20:40:58 -0800, "PrecisionMachinisT"
<Precisionmachinist@hotmail.com> vaguely proposed a theory .......and in reply I say!: remove ns from my header address to reply via email What we need here is a pressure step-down transformer >400psi high enough for you ? ************************************************** ** sorry ..........no I'm not! remove ns from my header address to reply via email Does Bill Gates dream of electronic sheep? |
#9 |
Guest
Posts: n/a
krem wrote:
> > Hello, I have a small window air conditioner that has been discharged of the > freon and was wondering if i could convert it to be either a compressor or a > vacuum pump. Possibly both? The ac was working perfectally before it was > dropped and one of the copper pipes in a radiator cracked releasing the > coolent. a vacuum pump should be perfect for an old a/c unit pump.. but a compressor i dont believe.. unless you want a low power 2-4 lbs. of pressrue??? you can go to harbor freight and for $10 get one of those 12 volt air pumps for your car and it will run circles around the old a/c [pump... i made a vacuum pump to work on auto a/c units(to pump the air out ) from an old refrigerator.. took the compressor out and then cut off the copper lines.. went to hardware store and got a 1/4 in pipe fitting and put it on the side that pulls vacuum and its been working for the past 30 yrs.. its slow, but will pull a 28-29 in. of vacuum.... but still dont think it will work for a compressor.. i put my finger on the other tube and you stop the air compressing without much force.... |
#10 |
Guest
Posts: n/a
news:35269c4a677e652621b6f244e2de4c15@news.teranew s.com > Hello, I have a small window air conditioner that has been discharged of the > freon and was wondering if i could convert it to be either a compressor or a > vacuum pump. Possibly both? The ac was working perfectally before it was > dropped and one of the copper pipes in a radiator cracked releasing the > coolent. Hi, A small word of caution from Jim Cox's book, Electric Motors in the home Workshop. He says : "These units must never be used as compressors unless a reliable and effective safety valve is fitted." He also says that they can produce upwards of 500 psi, which could possibly cause the cannister to burst. Normally they will not produce this kind of pressure in us, as the unit is handling a fixed amount of refrigerant which will liquefy before a dangerous pressure is produced. He also suggest using Shell Vitrea 68 oil. As the rest of the book seems quite sensible, and he appears to know what he is talking about, I would urge caution. Good Luck, Tom Nunce excretia in extractum est. -- Posted via Mailgate.ORG Server - http://www.Mailgate.ORG |
#11 |
Guest
Posts: n/a
On Tue, 16 Mar 2004 05:50:42 GMT, "krem" <news@rkremser.endjunk.com>
wrote: >"Gerald Ross" <gwader@netcommander.com> wrote in message >news:405663cb_5@corp.newsgroups.com... >> It might be good to put an inline oiler on the intake side since there >> is a lot of metal rubbing against metal inside the pump. Not sure the >> oilers used on pressure lines would work, but it would be worth a try. > >What kind of oil should be used? something as simple as wd40 or a heavier >oil? I would NOT use WD-40, that's mostly Kerosene and Stoddard Solvent. Great for water displacement, lousy as a lubricant. The oil to use depends on the compressor and the refrigerant that used to be in it. If it was running R-12 or R-22, it's probably an old fashioned mineral-oil based refrigeration oil. But if it was running R-134, or one of the newer HCFC or HFC refrigerants, it could be PAO or POE based synthetic oil - kinda like Mobil1... Write down all the markings stamped on the compressor ID tag, and a refrigeration supply house can tell you more than you /ever/ wanted to know. (And sell you a gallon of the right type & weight oil.) There is a reservoir inside the compressor body with a quart or two of refrigeration oil that will lubricate the internal workings, if you keep the oil level up. In a sealed refrigeration system that's not a problem (since it would go around one lap and get carried back with the refrigerant), but you aren't going to run it like that anymore... That means you will need to figure out which of the sealed-off tubes down low on the outside of the compressor can goes into the crankcase area, so you can rig up a piece of clear tubing as a sight gauge for the oil level. Drain the compressor oil out that fitting, refill it with the proper measured quantity of oil through the suction intake as called for on the spec sheet, and mark the "Full" level on your new tubing sight gauge. You need to catch any oil that gets past the rings and out in the compressed air, which means buying a purpose-built coalescing oil trap. But unlike a working refrigeration system I wouldn't run that oil back to the compressor crankcase, since it will probably have condensed water in it. Just drain it into a can of kitty litter (to catch the oil) every few days. Top up the compressor with fresh oil once a week, or as needed. And be sure to run a good filter on the air intake line, or the unit will suck in a ton of grit, get the oil filthy, and kill the compressor in short order. --<< Bruce >>-- -- Bruce L. Bergman, Woodland Hills (Los Angeles) CA - Desktop Electrician for Westend Electric - CA726700 5737 Kanan Rd. #359, Agoura CA 91301 (818) 889-9545 Spamtrapped address: Remove the python and the invalid, and use a net. |
#12 |
Guest
Posts: n/a
"jim" <jim@noname.com> wrote in message news:405718CB.7FB0@noname.com... > krem wrote: [snip]> a vacuum pump should be perfect for an old a/c unit pump.. but a > compressor i dont believe.. unless you want a low power 2-4 lbs. of > pressrue??? you can go to harbor freight and for $10 get one of those 12 > volt air pumps for your car and it will run circles around the old a/c > [pump... >[snip] Snag - we don't have a firm called "Harbour Freight" here in Britain.......but you can get those 12v air pumps from car accessory shops, but they cost an awful lot more than your 10 dollars! More like £30 or so ![]() Dave.p.s. this is the snag of postings to multiple groups.........what applies in the USA isn't going to apply anywhere else, and vice versa. |
#13 |
Guest
Posts: n/a
On Tue, 16 Mar 2004 22:40:20 +0000 (UTC), "Tom Jacobs"
<tomjacobs@lineone.net> wrote: >He also says that they can produce upwards of 500 psi, which could >possibly cause the cannister to burst. Normally they will not produce >this kind of pressure in us, as the unit is handling a fixed amount of >refrigerant which will liquefy before a dangerous pressure is produced. >He also suggest using Shell Vitrea 68 oil. > >As the rest of the book seems quite sensible, and he appears to know >what he is talking about, I would urge caution. I would agree - Having read that book I tried an old small refrigerator compressor (standard black sealed unit) feeding into just a pressure gauge. We put it behind a large earth bank and recorded the pressure from the other side - one of the copper tubes gave way at just under 600PSI with the compressor still going quite happily. -- Peter Parry. http://www.wpp.ltd.uk/ |
#14 |
Guest
Posts: n/a
Peter Parry told us ............. > We put it behind a large earth bank and >recorded the pressure from the other side - one of the copper tubes >gave way at just under 600PSI with the compressor still going quite >happily. > I think we are getting back to that splendid thread on explosives that ran late last summer! ![]() Mike -- Mike Whittome - life member. Curmudgeons International A branch of the Flat Earth Society |
#15 |
Guest
Posts: n/a
"Mike Whittome" <mike@windling.demon.co.uk> wrote in message news:3T8bYgA8QZWAFwcA@windling.demon.co.uk... : : Peter Parry told us ............. : : > We put it behind a large earth bank and : >recorded the pressure from the other side - one of the copper tubes : >gave way at just under 600PSI with the compressor still going quite : >happily. : > I cut open casing of a fridge compressor that had stopped working with an angle grinder and was amazed at the heavy duty quality of the compressor inside. It must have been just stuck becasue after turning it by hand it worked under power. I used it for many years to drive model steam engines nice and quiet too. I threw it out when I got a proper compressor. Chris |
| Thread Tools | |
| refrigerator compressor to vacuum pump | nwass222 | RCSE | 10 | Mar 26, 2006 11:57 PM |
| Air conditioner compressor for vac. bagging instead of fridge pump? | Stuart A. Hall | RCSE | 2 | Feb 20, 2005 12:02 PM |
| Re: Small Air conditioner compressor convert to air compressor & | Howard R Garner | uk.rec.models.engineering | 2 | Mar 17, 2004 04:01 AM |
| refrigerator compressor to vacuum pump | nwass222 | RCSE | 11 | Apr 01, 2003 01:28 AM |
| refrigerator compressor to vacuum pump | nwass222 | RCSE | 11 | Apr 01, 2003 12:56 AM |
