Old Feb 19, 2014, 01:01 PM
Cliff Hanger is online now
Find More Posts by Cliff Hanger
California Desert... 7 miles from nearest town
Joined Jan 2010
Wondering how you are doing?
It's been a few days.
Cliff Hanger is online now Find More Posts by Cliff Hanger
Old Feb 20, 2014, 04:13 AM
profesorul is offline
Find More Posts by profesorul
profesorul's Avatar
BUCURESTI
Joined Feb 2009
@ Cliff Hanger THANK YOU for asking .
Unfortunateley NOT much progress. I have some hard days on work and some things to do at home . There is always a VEEERY LONG Priority List
I wheel keep You on post with everything I do .
profesorul is offline Find More Posts by profesorul
Old Feb 20, 2014, 09:59 AM
Joined Jan 2010
Very good.
We'll be watching for new posts.
Old Feb 26, 2014, 04:21 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
QUESTIONS:
1) I found these Water Pump on eBay
http://www.ebay.com/itm/WATER-PUMP-E...#ht_1961wt_867
can be used to Fill/Empty a ballast tank for my LA sub ?.....is necessary to have a speed controller for it?.....how about the price/seller?.
My intention is to buy 2 pieces , one for these project and one for spare for another project .
2) how to make the propeller shaft be parallel to axis of the submarine ?.....what usual method can be applied for these operation ?
THANK YOU
MARIUS
Old Feb 26, 2014, 10:24 AM
Joined Jan 2010
1. Water Pump... It says 1 liter per minute at 6 volts. Might be worth giving a try.
2. Getting the propeller shaft straight with the boat.
What I do is I put the rear shaft bearing in place, loose.
I put the propeller shaft rod in place through the bearing.
Put the propeller on the shaft to make sure it centers on the tail cone of the hull.
Adjust as needed.
Using a ruler, center the shaft side to side in the hull.
If your hull separates mid hull then you can just look across the beam and get the shaft centered vertically. Use a ruler and check from inside bottom of hull up to shaft.
Check with ruler from inside top of hull.
Build some sort of support. I used pieces of styrene glues together. Siliconed second bearing to support.
Old Feb 27, 2014, 03:45 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
THANK YOU ,
In my country I couldn't find graphite bronze for the propeller shaft bushing , can I use encapsulated ball bearings instead ?.....won't sail in salt water , only in freshwater lakes or swimming pools.
I have a very good White Grease , used for High Temperature , to apply on Ball Bearings .
MARIUS
Old Feb 27, 2014, 09:22 AM
Joined Jan 2010
I am not sure I would go with ball bearings. Anything at all get in there and they will stop turning.
Graphite bronze, silicone bronze, oilite bronze ......these are just small bronze bushings like in small electric motors.
In USA, they can be found in hardware stores, auto parts stores and other fix it parts stores. You can even find them in computer hard drive motors.
I think I would use just short pieces of pain brass tubing before ball bearings if I couldn't find bronze bushings. A little grease and be done with it.
Old Feb 27, 2014, 02:55 PM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
You are Right , it's logic . I'll see what I can find .
THANK YOU for these ideas .
MARIUS
Old Mar 06, 2014, 05:25 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
HI ,
To day I am very glad because I did some progress on the project.I know is NOT very much but when You don't have SPARE time at all and Your work shop is the kitchen and work bench is kitchen table - IF YOU GET THE PERMISSION from "MASTER CHEF" my WIFE !!! is A PROGRESS .
Couple days a go I glued a piece of PVC sheet on both Dive Planes . I din't have to file them to shape .
Description:
Description:
Description:
Yesterday and to day I did the Motor mount from a small piece of aluminum sheet .
It was necessary to Drill , cut , tap , file .
Doesn't look much but I keep the tools in to a small crowded closet , some of them on balcony , where is my lathe too !!! .
When I tray to do something it need 30min to get the tool down and another 30min - 40min to clean the work place .
I told You all these to see way is gonna be a very long thread plus the "dam found" always missing !.
Description:
Description:
Description:
Description:
Description:
See You soon I HOPE .
All the Best
MARIUS
Old Mar 06, 2014, 11:06 AM
marinaru_ro is offline
Find More Posts by marinaru_ro
Romania, HD, Sāntandrei
Joined Apr 2006
Looks good Marius, just one question: is that aluminium sheet strong enough to stay straight and not to allow vibrations to the shaft?
Regards,
George
marinaru_ro is offline Find More Posts by marinaru_ro
Old Mar 06, 2014, 11:32 AM
Joined Jan 2010
Vibration may be an issue with only one side of the mount secured.
Two sided mount will limit vibration.
Old Mar 06, 2014, 01:45 PM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
Good point . But is going to be a Little difficult to do because of those 2 holes for push rods near by .
Name: Motor Mount_question.jpg
Description:
What is You suggestion for it ?.
MARIUS
Old Mar 06, 2014, 01:56 PM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
Regards,
George
I don't know . I didn't test it eat . I didn't had thicker aluminum sheet , but if is thicker is more difficult to bend twice so close - to gain space inside - and I don't have the necessary tools for that . All I have for these operation is an old 80mm vice , a piece of wood and a small hammer for it .
MARIUS
P.S Salutare GEORGE
Old Mar 06, 2014, 02:38 PM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Marius,
I applaud your workmanship. I do agree about vibration and movement of the motor. Could you secure it on the sides by adding a tabs? That way you have the bottom and both sides holding it firmly in place.
Peace,
tom
tchalfant is offline Find More Posts by tchalfant
Old Mar 06, 2014, 02:46 PM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
Originally Posted by tchalfant View Post
Marius,
Peace,
tom
THANK YOU TOM ,
I need everyone's support for that .
As always YOU have a more accurate view than me !.
Yes I can do an extra support .
Clear Waters
MARIUS
Discussion Any indoor flying near Los Angeles? Akura2 Micro Ready-to-Fly 7 Jan 20, 2014 09:48 PM
Found Mobius Video Cable needed in Los Angeles Today Mauronic FPV Equipment (FS/W) 3 Oct 10, 2013 03:29 PM
Wanted Windrider BD-5J EDF (LPU Los Angeles area) Left Coast DJ Aircraft - Electric - Jets (FS/W) 4 Sep 29, 2013 06:23 PM
Discussion Testing 1/3 scale ASW in Los Angeles rhokita Slope 2 Sep 21, 2013 11:54 PM
