Old Feb 06, 2014, 04:43 AM
profesorul is offline
Find More Posts by profesorul
profesorul's Avatar
BUCURESTI
Joined Feb 2009
LOS ANGELES build logs
Be ADVICE : Is gonna be a very long thread so PLEASE have patience !
Earlier this week I took courage and I start working on these project .
That is a LOS ANGELES submarine bought it from someone on the forum .
- I started with rudders depth as required for the large volume of Sisyphus work ....
- after many, many hours of sanding an file I managed to do what you can see in the pictures...
HOW TO FIX :
1) file until get same length?
2) fill until get same length ?
Description:
Description:
Description:
- then continued with bow rudders ....NO problems here ,
- with tower is another story and I have some questions about the place to put axis for Bow Rudders ....( see pictures )
Description:
- I do not know what those two parts are and which should be put it ( see pictures )
Name: Corect Position.jpg
Description:
1) what are those holes and witch should be drilled ( I think some of them should be don do the captive air !)
Description:
What should be the corect distance for depth rudders and steering rudders:
Name: Dive Rudders_what distance.jpg
Description:
Name: Stern Rudders_what distance.jpg
Description:
Description:
Description:
Description:
Description:
Name: Shippment Accident_how to REPAIRE.jpg
Description:
Name: mold casting defect.jpg
Description:
OK for now,
THANK YOU
MARIUS
profesorul is offline Find More Posts by profesorul
Old Feb 06, 2014, 09:15 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
A regrettable error : I posted 2 threads with the same subject...... how can I delete one of them ?
MARIUS
Old Feb 06, 2014, 01:05 PM
Subsonic Mike is online now
Find More Posts by Subsonic Mike
Doing things differently
Subsonic Mike's Avatar
UK, England
Joined Sep 2009
As far as I know their isnt a delete button, just erase all the text from this thread and replace it with something like --accidental duplicate post--
Michael
Subsonic Mike is online now Find More Posts by Subsonic Mike
Old Feb 06, 2014, 01:32 PM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
OK . THANK YOU ,
But I think is not right , and may be is going to be fix one day ! .
At least can I CLOSE it ? ( like the one when You sold something )
MARIUS
Old Feb 06, 2014, 02:49 PM
tchalfant is offline
Find More Posts by tchalfant
tchalfant's Avatar
United States, NV, Las Vegas
Joined Aug 2011
Marius, I would offer that you do not separate the topics anyways......If it applies to your LA Class sub, keep them together.
Love seeing you work on this!
tchalfant is offline Find More Posts by tchalfant
Old Feb 07, 2014, 03:20 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
HI @tchalfant ,
Of course is not a problem for me . I wheel take Your advice and keep them both active .
I DIDN'T WANT to be "out side of the lows" that's eat .
For the moment all I have is these :
Description:
Description:
Description:
Name: WTC and Caps Lok.jpg
Description:
Description:
- any suggestion about Reliable Speed Controller ......Fail Safe devices and what else should be ?
- the RC is FUTABA 6EXP - 6 channels (4 + 2 ) ,40MHz .
I know is an very old model but that's gonna be do the small budget
Old Feb 07, 2014, 12:43 PM
tchalfant's Avatar
Joined Aug 2011
Marius,
Normally I would say Mtroniks ESC, but I also like Microgyro's controller here:
http://www.microgyros.com/index.html
Old Feb 08, 2014, 11:28 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
What would You recommend from Mtroniks ?.
MARIUS
Old Mar 18, 2014, 11:04 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
My BELOVED colleges I know is too soon for these stage of my project but I hope there wheel the time when I'm gonna need some Decals for my sub.
So there is some questions rising :
1) every type of subs has a different Decals ?
2) is necessary to buy a particular decals , for example My Los Angeles , or there are some general witch can be used , and by choosing what to put on them is what determine the particularity of a specific one?.
3) and of course where can be bought at decent price all of these ?.
Can You show me some pictures about what/where/how did You put Your Decals on Subs?, or guide to another place where I can find these answers .
THANK YOU
MARIUS
Old Mar 28, 2014, 03:18 PM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
Good Evening ,
- I advanced a little bit with component arrangement in WTC ....
- I mounted on a speed controller and receiver a piece of Velcro , and on PVC bracket also.....
- I put thicker wires to the motor ....
- I don't know what connectors to use for coupling the motor with speed controller and for connecting the battery to the speed controller ....
- I have not forgotten either the fuse that protects the receiver or the main switch ,
- I am most interested about what capacity should have receiver battery power ..... now I have 4,8 V = 4x1, 2V/2100mA - NiMh Accumulators ...
- is enough to power the receiver? .....
- if yeah, that autonomy would be? ...
I have some questions :
- what methods are most commonly used to isolate the power supply wires from the battery when they enter in the WTC ? ;
- can I put Sealed Lead Acid battery terminals in the in water if it does not fit into the WTC ? ;
- not is discharged or is short circuit?
Pictures next days . To day batery is empty
MARIUS
Old Apr 01, 2014, 06:01 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
HI there , I have a bag pressure from a device to measure blood pressure and has the dimensions from the picture ...... would be enough water volume for my sub ?
What are the most used methods to calculate what volume of water is needed ?
PLEASE I need these answer FAST in order to buy the necessary length of the Acrylic Tube .
Description:
Description:
All the Best and CLEAR WATERS
MARIUS
Old Apr 03, 2014, 01:16 AM
marinaru_ro is online now
Find More Posts by marinaru_ro
Romania, HD, Sāntandrei
Joined Apr 2006
Salut Marius!
I belive it will be enough for your sub, but please take good care with that brass geared pump, i have used one in the past and the inside seals are not very good, water can easily reach to the motor under pressure. I would recommend using a Kavan geared pump. The Kavan is able to produce 4 to 5 bar without problems.
Regards,
George
marinaru_ro is online now Find More Posts by marinaru_ro
Old Apr 07, 2014, 05:37 AM
profesorul's Avatar
BUCURESTI
Joined Feb 2009
SALUT GEORGE ,
Thank You for telling me these .
I wheel take care about the pump . I am not decided eat if is going to stay in the same wtc with the rest of the components or in a separate wtc along with Rubber Balloon but separated by a Sealed Wall - with on O-ring .
Unfortunately I spent all my Founds and I don't have money for another Pump .
MARIUS
Discussion Any indoor flying near Los Angeles? Akura2 Micro Ready-to-Fly 7 Jan 20, 2014 09:48 PM
Found Mobius Video Cable needed in Los Angeles Today Mauronic FPV Equipment (FS/W) 3 Oct 10, 2013 03:29 PM
Wanted Windrider BD-5J EDF (LPU Los Angeles area) Left Coast DJ Aircraft - Electric - Jets (FS/W) 4 Sep 29, 2013 06:23 PM
Discussion Testing 1/3 scale ASW in Los Angeles rhokita Slope 2 Sep 21, 2013 11:54 PM
