Old Aug 02, 2001, 10:52 AM
JensJakob is offline
Find More Posts by JensJakob
Frederiksberg, Denmark
Joined May 2001
Digital cameraes used for aerial photography
Hi
What digital camera do you use for aerial photography ?
I like the idea of instant gratification, allthough I do not like the idea of flying additionel 4-500$ HW.
JJ
JensJakob is offline Find More Posts by JensJakob
Old Aug 02, 2001, 11:23 PM
Philipp is offline
Find More Posts by Philipp
Philipp's Avatar
Grand Prairie, Texas, USA
Joined Mar 2000
I don't have one, but Sams sells the Intel pocket PC digital camera for $89 with a $30 rebate - what a deal. It is 640 x 480 only, but comes with a USB cable.
Philipp is offline Find More Posts by Philipp
Old Aug 03, 2001, 06:01 AM
Bob Chiang is offline
Find More Posts by Bob Chiang
Ithaca, NY USA
Joined Oct 2000
I've been wondering if this camera would be suitable:
http://www.softwareandstuff.com/h_co...aminicam1.html
http://www.campuswarehouse.com/243/cat243.htm?218 for a better photo of the camera
They also seem to be sold on e-bay quite frequently. I've not been able to find a weight, but the size is quite small.
Bob Chiang is offline Find More Posts by Bob Chiang
Old Aug 06, 2001, 09:28 AM
maciek is offline
Find More Posts by maciek
maciek's Avatar
Worcester, Ma, USA
Joined Feb 2001
So has anyone used one of these cameras?
maciek is offline Find More Posts by maciek
Old Sep 15, 2001, 04:41 PM
dgtaylor is offline
Find More Posts by dgtaylor
AL
Joined Sep 2001
I read the review of the "Sunny Boy" plane on Ezone. The Intel Pocket PC camera used for the aerial shots in this article are pretty impressive for 640x480.
As soon as I figure out which plane would make the best platform, I am going to get one to try.
dgtaylor is offline Find More Posts by dgtaylor
Old Sep 16, 2001, 01:26 AM
William A is offline
Find More Posts by William A
Tacoma, WA, USA
William A's Avatar
United States, WA, Tacoma
Joined Jun 2001
I'll let you know, I just ordered one.
William A is offline Find More Posts by William A
Old Sep 16, 2001, 08:09 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
We expect a full report! I tought about it, too, but you beat me to it!
I'm not sure I have an airframe big enough to cary it, so then I'd have to get that, then some bigger batteries, then a bigger truck to carry that, then a better looking wife for the passenger seat.....
Never ending spiral!
Let us know the weight....
Gene Bond is offline Find More Posts by Gene Bond
Old Sep 16, 2001, 08:17 AM
Jim McPherson is offline
Find More Posts by Jim McPherson
Just an average RC'er
Jim McPherson's Avatar
Laurel, Maryland USA
Joined Aug 2000
I've got one of these cameras. They are very light weight and take good outside 640x480 pictures. They run on 2 AAA batteries so probably would work off of the BEC in your airplane. The only problem with them is that they will only stay on for about 30 seconds at a time before they shut down "to conserve battery life" . They only way to get around this problem seems to be to plug the USB connector in the side, this keeps the camera on. Hope this helps.
Jim McPherson is offline Find More Posts by Jim McPherson
Old Sep 17, 2001, 09:46 AM
ezekiel is offline
Find More Posts by ezekiel
La Honda CA USA
Joined Oct 2000
excalent camera trick
use a cheapie analog autowind. have the roll processed as hi=res hard disk digital . the disc can then be loaded thru your hard drive. there lots of free print svcs after that. also, there is usually a print and store program on the disc.
analog fotos (regular film) are of better quality than the best $1000 digital camera fotos. a 36 roll costs me $15 to process (#12 for lo-res process).
ez
ezekiel is offline Find More Posts by ezekiel
Old Sep 17, 2001, 11:05 AM
rkrishnan is offline
Find More Posts by rkrishnan
Schaumburg,Il,USA
Joined Apr 2001
Any brand name , model # & price for the analog autowind? Found lots of manual wind disposables but no inexpensive autowinds.
rkrishnan is offline Find More Posts by rkrishnan
Old Sep 17, 2001, 11:49 AM
gnofliwr is offline
Find More Posts by gnofliwr
aka: A.Roger Wilfong
gnofliwr's Avatar
Novi, Michigan, United States
Joined Jan 2001
WRT film based cameras. Most point and shoot 35mm are autowind and can be adapted to take aerial pics (one at a time or a series). I've used a Vivitar and a Ricoh in a model rocket.
The Vivitar required a mechanical setup to trip the shutter - I rigged a cheep motor/gear box to run at ~1 RPM which seemed about right for the film to get advanced and shot an entire roll during a flight (the "success" rate in getting an "interesting" picture from a model rocket is pretty low. Several years ago the was a fun event at NARAM to take an aerial picture of a target on the ground. The idea was that the winner would be the one with the target closest to the center of the frame. The winner was the only one to get a picture of the field period.). You could replace the motor/gear box with a servo and accomplish the same thing. The mechanism required a 4" diameter payload section.
The Ricoh had a jack on the side for remote shutter release - short the wires every time you want to take a pix. It also had a sequence mode - one frame per second as long as the shutter release was actuated. It would fit in a 3" diameter payload section.
The Vivitar was cheep and dirty - about $35 at K-Mart, Walmart, etc. I'm not sure of the actual model, but it was long enough ago that that model has been superceeded. If you check the camera department at any of the *.marts you'll find something similar. You'll have to work out the specifics of actuating the shutter button.
The Ricoh was about $100 and was discontinued long ago and I haven't seen any that have the same wired remote shutter or sequence mode features since - but I haven't been looking hard. You might find a used on in a camera or pawn shop, but it'd be sheer luck - there isn't a big market for used point and shoots, so they don't bring much and few are traded in.
One problem with both cameras was that they would shut themselves off after afew minutes (to save on battery) if you hadn't taken a pix. So you need to "arm" them just before flight.
gnofliwr is offline Find More Posts by gnofliwr
Old Sep 18, 2001, 03:12 AM
joemi is offline
Find More Posts by joemi
joemi's Avatar
United States, WA, Kent
Joined Sep 2001
I am thinking of getting a Wingo and trying to use a Intel Pocket PC cam, anyone have any experience doing this?
joemi is offline Find More Posts by joemi
Old Sep 18, 2001, 03:43 PM
krajesj is offline
Find More Posts by krajesj
Quaker Hill, CT
Joined Oct 1999
Someone on an earlier thread told me about an auto-wind 35mm camera from Wal-Mart. It was the Kodak ES27 EV for ~$15.00.
I had seen them earlier. They are relatively small and light. I was in the same store this week and couldn't find them. Maybe you can. It figures, doesn't it?
krajesj is offline Find More Posts by krajesj
Old Sep 20, 2001, 12:15 PM
cactus is offline
Find More Posts by cactus
United States, CO, Durango
Joined Sep 2001
This is an area of intrest for me as well. I have been doing some research on using Digital cameras and Wireless video on RC Aircraft and have found some interesting projects being undertaken by people. This first link is about using your RC TX and a spare channel to auto release the shutter button! Very cool idea. I have seen many people use a mech servo to push down on the button, but I like the electronic idea better.
http://www.wco.com/~dgreno/aboutsystem.htm
Here is a site that sells a controller board along with project details:
http://www.parallaxinc.com/html_file...italcamera.htm
cactus is offline Find More Posts by cactus
Old Sep 20, 2001, 04:12 PM
Ithaca, NY USA
Joined Oct 2000
I bought one of these cameras and agree with Kingjamez that the auto-power off feature is a problem. Thanks for the hint to plug in a usb connector. Anyone know a source to buy a usb plug?
Another odd feature is that there is a time lag (maybe one second?) between pressing the "shutter" button and when the camera records the image.
For what it's worth, I took the case apart and the actual electronic and optics board only weighs about an ounce (on my inacurate scale).
The shutter button looks to be a simple switch, though I haven't tested it yet. If it is, I intend to solder a couple of wires to the camera shutter button switch, and make a home-made switch that operates at the extreme throw of the rudder servo. The time lag may actually work to my advantage in this case.
Best Camera for aerial photography? BillH Electric Plane Talk 26 Dec 11, 2010 07:14 AM
Sold NIB Nikon Coolpix L3 5.1MP Digital Camera for Aerial Photography Tank52 Non R/C Items (FS/W) 2 Mar 18, 2007 07:31 PM
Summary of digital cameras and switches for Aerial Photography BoleyWv Aerial Photography 23 Mar 11, 2005 12:12 PM
What's the best digital for Aerial Photography? QuietRiot Aerial Photography 3 Dec 28, 2003 09:20 AM
Best plane for aerial photography dgtaylor Electric Plane Talk 18 Oct 01, 2001 02:21 AM
