This thread is privately moderated by Nitro_Nancy, who may elect to delete unwanted replies.
Old Feb 04, 2014, 01:18 PM
Nitro_Nancy is offline
Find More Posts by Nitro_Nancy
Nitro_Nancy's Avatar
United States, CA, Industry
Joined Jan 2011
New Product
New Exceed Formula 1 650MM Electric Powerboat
Shop Now - http://www.nitrorcx.com/99b-10024-f1-650-ep-artr.html
Experience the highest class of inboard powerboat racing in the world with the Exceed Formula 1 powerboat. The Exceed F1 650mm (25.5") Powerboats hull is constructed with a tunnel hull catamaran format capable of both high speed and exceptional maneuverability. The tunnel hull design creates aerodynamic lift due to a wing formed by the deck and under the surface of the hull. This increases lift and reduces drag allowing the boat to barely touch the water at high speeds. The entire hull is constructed of fiberglass allowing it to remain tough yet lightweight and then gel coated over for sleek gliding performance and reducing drag while improving efficiency.
The Exceed F1 outboard motor is one of a kind. A 2636kv water-cooled 380 sized brushless motor is encased in a fiberglass outboard motor shell which pivots for maximum water condition tuning and performance. The brushless motor mounted in the power head drives a collet housed in the midsection which drives the prop through a flexdrive shaft propelling the 3 bladed 3.2x1.4 prop. The 50 amp brushless electronic speed controller is also water cooled through a water pickup found on the stern of the hull. The bottom half of the outboard motor including the skeg is constructed of CNC billet aluminum for maximum toughness and durability.
Upon removing the magnetized rear canopy of the F1 boat, you will find a balsa radio tray plate covered by a removable plexi sheet used to protect your receiver and outboard motor steering servo. Forward of this tray is a balsa seat with velrco provisions to mount your selection of a 11.1v 2200-4500mah rated lithium polymer battery.
This F1 boat is exhilarating to operate and is one of Exceeds latest offerings. It comes almost ready to run with electronics mounted and ready to go. You will need a radio system, lipo battery, and charger to complete the build and be fully operational and ready to rip the water.
Specifications:
Length: 650mm
Beam: 250mm
Height: 145mm
Weight w/ battery:1250g
Hull Type: Fiberglass formula 1
Motor: B2848-2636kv water-cooled Brushless with 50A ESC
Propeller: 3-blade Carbon-reinforced Plastic Diameter3.2xPitch1.4
Driveline: Outboard-drive
Hardware: CNC outboard-drive
Required to Run:
Radio(required)2ch
Bettery(required): 11.1v 2200-4500mah Lipo
Charger
Nitro_Nancy is offline Find More Posts by Nitro_Nancy
Site Sponsor
Old Feb 04, 2014, 11:28 PM
dogz85 is offline
Find More Posts by dogz85
Australia, VIC, Shepparton
Joined Jun 2008
looks very nice
dogz85 is offline Find More Posts by dogz85
Cool Electric formula one, Where they came from? Edalves68 High Performance 78 May 21, 2014 03:57 PM
Discussion New 2014 Exceed RC 1/10 scale 6x6 MadTorque Crawler 2.4ghz Ready to Run hobbypartz Product Announcements 1 Jan 10, 2014 03:28 PM
Discussion Electric Formula 1. How Does one Begin? doehunter High Performance 8 Nov 30, 2013 03:27 PM
electric formula 1 txfly High Performance 5 Jul 22, 2005 04:47 PM
