Old Jan 30, 2014, 06:51 PM
charlie conley is offline
Find More Posts by charlie conley
United States, KY, Bowling Green
Joined May 2011
Phantom fc 40
I just recieved my new phantom fc 40 from B&H photo. The first thing I noticed was that both sticks on the TX were spring loaded. I wonder how DJI does any testing with a spring loaded throttle. Some problems I can understand but this is a little way out for me. Has anyone else had this problem.
charlie conley is offline Find More Posts by charlie conley
Old Jan 30, 2014, 06:54 PM
DWA is offline
DWA
Find More Posts by DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
United States, CA, Mission Viejo
Joined Dec 2004
It is a new feature. The throttle stick is supposed to be spring loaded on this phantom. It makes it easy to hover at any given altitude by just letting go of the throttle stick.
Dave
DWA is offline Find More Posts by DWA
Old Jan 30, 2014, 06:55 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
A lot of the guys were unsure of this feature when they first saw it. But after using it have come to like it.
Old Jan 30, 2014, 06:59 PM
Joined May 2011
Thanks for the answer. Do you hold the throttle all the way down until you get the GPS to lock
on. If I turn on the tx and connect the battery the light just flashes red.
Old Jan 30, 2014, 07:15 PM
FatKevinSmith is offline
Find More Posts by FatKevinSmith
Joined Jan 2014
You should probably read the FC40 documentation on the DJI website before attempting to do anything. It is quite helpful and comprehensive.
FatKevinSmith is offline Find More Posts by FatKevinSmith
Old Jan 30, 2014, 07:50 PM
DWA is offline
DWA
DWA
1Corinthians 13:1-8
DWA's Avatar
Joined Dec 2004
No that is not how you get GPS lock. Leave the sticks centered when you power everything up. I would also recommend reading through at least the quick start guide and that should get you on your way. And then read the manual of course.
Old Jan 30, 2014, 09:19 PM
Empire Support 5 is offline
Find More Posts by Empire Support 5
Empire Hobby Support Team
Joined Jan 2014
If the light is just flashing red you have a Low voltage alert or other abnormal alert, ie: configuration error, TX data error, or compass calibration error.
To get GPS lock make sure you are outside and turn on tx then turn on Phantom FC 40.
Keep the aircraft stationary until the system start and self-check has finished.Then wait for the system to warm up gradually with the LED blinks Yellow 4 times quickly. Take off the aircraft after 6 or more GPS satellites are found (Red LED blinks once or no blinking red).
Empire Support 5 is offline Find More Posts by Empire Support 5
For Sale MWC Flight Controller Bonanza: The Flip FC <$20. Mega Pro <$40 & GPS COMBOS <$80 witespy Aircraft - Electric - Multirotor (FS/W) 15 Sep 08, 2014 02:37 AM
Discussion ESC to FC and Receiver to FC power wires xjz Power Systems 1 Jan 22, 2014 02:16 AM
Sold Multiwii Pro FC with GPS $40 SOLD soarsimon Aircraft - Electric - Multirotor (FS/W) 2 Jul 20, 2013 09:51 PM
Sold Warthox FPV v2.0 multiwii FC $40 shipped! kicekilla Aircraft - Electric - Multirotor (FS/W) 3 Sep 10, 2012 02:37 PM
Sold DJI NAZA FC 200.00 shipped and 4esc 18a for 40.00 skyhulk Aircraft - Electric - Multirotor (FS/W) 3 May 04, 2012 04:16 PM
