Old Jan 29, 2014, 12:52 AM
ChuckTseeker is online now
Find More Posts by ChuckTseeker
ChuckTseeker's Avatar
Adelaide Plains Australia
Joined Dec 2007
New Product
Parkzone ArtiZan with AS3X Aerobatic's Plane
Hi all, 2014 and the first new release from Parkzone is the ArtiZan and yet again with the generosity of OMP Modleflight Adelaide, Mike has given me the ArtiZan to review and maiden, so you get an early look at this new beauty from Parkzone. "It's an AS3X equipped park flyer that will enable you to explore Aerobatics" is what it says on the box and i hope to maiden real soon to just see how it does fly. For now sit back and check out the new ArtiZan
cheers chuck
The compact ArtiZan™ park flyer is a nimble, grab-and-go sport plane that’s perfect for exploring aerobatics. The Bind-N-Fly® version comes equipped with a Spektrum™ receiver featuring a built-in AS3X® (Artificial Stabilization – 3aXis) system.
The AS3X system works behind the scenes to counter the effects of wind and turbulence using a combination 3-axis sensing and exclusive flight control software. The result is a locked-in feel that lets you focus more on the fun of flying and less on fighting the wind.
You can adjust the amount of stability the AS3X system provides or turn it off completely, but even experienced pilots will find flying with it on feels completely natural. There is no delay in control response or limits on the control throws. You will simply feel like you’re flying an expertly tuned model that goes right where you point it.
It’s this advanced technology, along with the model’s light wing loading, that gives sport pilots a superb balance of slow speed stability and high-speed agility. Anyone with experience flying a ParkZone warbird or civilian scale model will feel right at home the first time on the controls.
Spektrum™ DSMX® receiver with AS3X system, installed
Powerful 480-size, 960Kv BL outrunner motor, installed
E-flite® 30A Pro Switch-Mode ESC, installed
Aileron, elevator and rudder servos installed
Durable Z-Foam™ construction
High-visibility blue and yellow trim scheme
Two-piece wing for easy transport and repair
Large, easy-access battery hatch
Includes 3S 1800mAh 30C Li-Po battery
Includes 2- to 3-cell DC variable rate fast charger
Requires a full-range 4+ channel DSM2®/DSMX transmitter
Wingspan: 42.5 in (1080mm)
Overall Length: 40.0 in (1017mm)
Flying Weight: 34.5 oz (978 g)
Motor Size: Park 480, 960Kv brushless outrunner
Radio: 4+ channel DSM2/DSMX transmitter required
CG (center of gravity): 3.0 in (76mm) back from the leading edge of wing at wing root
Prop Size: 10.75 x 8
Speed Control : 30-amp brushless
Recommended Battery: 11.1V 3S 1800-2200mAh LiPo
Flaps: No
Retracts: No
Approx. Flying Duration: 5-7 minutes
Minimum Age Recommendation: 14 years
Experience Level: Intermediate
Recommended Environment: Outdoor
Assembly Time: Less than 1 Hour
Is Assembly Required: Yes
Manual # English
http://www.parkzone.com/ProdInfo/Fil...-Manual_EN.pdf
Parkzone ArtiZan Un-Boxing Review with ChuckT (7 min 0 sec)
ChuckTseeker is online now Find More Posts by ChuckTseeker
Old Jan 29, 2014, 01:28 AM
team222badbrad is offline
Find More Posts by team222badbrad
Registered RC Addict
USA, PA, Tunkhannock
Joined Nov 2006
Interesting that they'd release something so similar to the VisionAire...
team222badbrad is offline Find More Posts by team222badbrad
Old Jan 29, 2014, 01:34 AM
Joined Dec 2007
I thought that when i first saw it too BUT! it is nothing like the VisionAire, it is an Aerobatic plane more like a Parkzone size Splendore The AS3X does not have any other setting but Sport!
this plane is aimed right at the Parkzone buyer and flys as easy as the T-28 but much better, so you want to explore Aerobatic's this is the Parkzone plane for you
cheers chuck
Old Jan 29, 2014, 01:46 AM
Dave Eichstedt is offline
Find More Posts by Dave Eichstedt
Warbird & Jet Lover
Mahomet, Illinois
Joined Aug 2007
The ArtiZan is not a 3D plane. Completely different flying experience from the Visionaire. This is a pure sport plane. The target was to be very similar to the T-28 but a little more capable in aerobatics. The final result probably delivers a little more aerobatic capability than originally intended, but it's still a sweet-flying bird.
Dave Eichstedt is offline Find More Posts by Dave Eichstedt
Old Jan 29, 2014, 06:55 AM
jono80 is offline
Find More Posts by jono80
Perth, Australia
Joined Feb 2010
Looks interesting, if it balances and flies well with a 2200mAh crammed in there even better!
jono80 is offline Find More Posts by jono80
Old Jan 29, 2014, 08:00 AM
lowkeylaidback is offline
Find More Posts by lowkeylaidback
Custom Crasher
lowkeylaidback's Avatar
USA, FL, Jacksonville
Joined Jan 2010
The way it looks is nice and the niche it is trying to fill needs something new, but most people really turn up the control surfaces on the PZ T-28 and turn it into a fun flyer more that a scale warbird, that is why it is so loved but....
Would like to see something like this with the tricycle wheel setup, that is something I really like about my PZ T-28 and I wouldn't give it up unless its replacement has them, I am trying a Hobbico Millenium Master to that affect now, a little smaller but more a sport flyer.
Try a reno version of a P39, that could get my cash, powered with the BL15 motor and the prop from the PZ Extra 300, yeah!
And flaps would be a big bonus
Not saying that this is not nice but the first thing I notice is another tail dragger
lowkeylaidback is offline Find More Posts by lowkeylaidback
Old Jan 29, 2014, 08:23 AM
crashkorey is offline
Find More Posts by crashkorey
United States, NJ, Freehold Township
Joined May 2009
I DONT like tail draggers as well. All my tail draggers nose over to much . I have a splendor in the box and hope that's not going to nose over as easy as the others.
crashkorey is offline Find More Posts by crashkorey
Old Jan 29, 2014, 08:55 AM
JDMJim is offline
Find More Posts by JDMJim
JDMJim's Avatar
United States, IL, Joliet
Joined Jul 2011
That's okay, I don't like trikes.....nice replacement for the Extra300
JDMJim is offline Find More Posts by JDMJim
Old Jan 29, 2014, 09:01 AM
Custom Crasher
Joined Jan 2010
The Splendor does not nose over, my good friend has one and it is a really nice model, flies really well and has great ground handling on grass and pavement and its huge for a foamy
Old Jan 29, 2014, 10:03 AM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
I'd been thinking that Chuck's been low-profile recently, and wondering when we'd hear from him..........
Looking forward to the maiden vid!
pugsam is offline Find More Posts by pugsam
Old Jan 29, 2014, 10:43 AM
stevespana is offline
Find More Posts by stevespana
Huesca, Spain
Joined Aug 2009
Looks like a smaller version of an Acrowot Foam-e.
stevespana is offline Find More Posts by stevespana
Old Jan 29, 2014, 12:16 PM
Sabin is online now
Find More Posts by Sabin
Every pilot has his crash
Sabin's Avatar
Canada, BC, Sechelt
Joined May 2008
can i fly this thing as aggressively as i can with the polecat?
Sabin is online now Find More Posts by Sabin
Old Jan 29, 2014, 01:09 PM
pugsam is offline
pugsam's Avatar
Joined Aug 2010
For the data-obsessed, can you tell us the wing-loading and wing-cube-loading?
Old Jan 29, 2014, 05:49 PM
Red Flyer is offline
Find More Posts by Red Flyer
Fly Low - Hit Hard
Red Flyer's Avatar
Canada, ON
Joined Oct 2010
Great to see you again Chuck and Dave E !
I'm in on this one.
RF
Red Flyer is offline Find More Posts by Red Flyer
Old Jan 30, 2014, 10:32 AM
chucksolo69 is offline
Find More Posts by chucksolo69
United States, CA, Oceanside
Joined Apr 2011
I fly the Flyzone Acro Wot MkII and I see this plane as being very similar. If it flies anywhere near a good as the Acro Wot, HH will have a winner on its hands. I may get one when they become available and do a comparison between it and the Acro Wot.
chucksolo69 is offline Find More Posts by chucksolo69
Sold Ultra Micro Spitfire Mk IX BNF with AS3X Technology by ParkZone (RTF) Sgt Ski Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 4 Dec 15, 2013 01:15 PM
Sold Parkzone UMX P-40 warhawk with AS3X f250r71 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 5 Dec 14, 2013 09:43 PM
Sold Will Ship Parkzone Visionaire AS3X-AR635 Receiver - 3D Aerobatic Plane tbullard Aircraft - Electric - Airplanes (FS/W) 0 Dec 11, 2013 11:00 PM
Sold Parkzone Visionaire with AS3X and Parkzone 3s2200 battery Mike Fortune Aircraft - Electric - Airplanes (FS/W) 3 Dec 09, 2013 10:19 PM
Sold Parkzone Visionaire AS3X-AR635 Receiver - 3D Aerobatic Plane - $180 Stuart, FL 34997 wilanz Aircraft - Electric - Airplanes (FS/W) 1 Oct 31, 2013 04:27 PM
