Mar 13, 2004, 12:45 PM
LI, New York, USA
Joined Mar 2003
Your GWS F4-U is certainly not too heavy to ride a thermal. It is probably lighter than the Aspire.
The 3 Meter Sailplane that I am going to maiden tomorrow weighs 80 ounces.
My Aerobird, which thermals very well is about 17 ounces.
If the plane will glide nicely, it will ride thermals. You just have to know what to look for.
The best conditions are calm air, hot sun and low humidity. Some big dark area surrounded by lighter areas. A freshly plowed field is good. A parking lot works. A large building with a black roof is awesome.
However I have caught thermals at 35 degrees F in 15 mph winds. They can be weak and they move fast, but the are there!
Here are some thoughts on the hunt!
Get your Aspire up about 500 feet working your way up wind. Then cut the motor and trim the plane for nice level flight. Now, focus on watching the plane and keeping it on a nice steady glide. Steady as she goes. Try to keep your hands off the sticks as much as possible.
Let the plane ride with the river of air giving it only occasional input to keep it going in the general direction you want to go, but don't be a stickler about it. Let it drift like a fly on the surface of the river, waiting for a trout. If you listen with your eyes, it will speak to you, but you have to listen.
Glide across the wind, not into it and not with it. Sort of a 45 -60 degree left for a while then a 45 to 60 degrees to the right. Nice and slow and easy. You want to cover the sky and search the moving river of air, like a bird looking for food.
As you are flying watch the wing tips the nose and the tail. If a wing seems to bump up, or if the nose seems to drop or the tail rise for a moment, you probably just brushed a thermal. Go immediately into a turn in the direction of the wing that rose.
Try to make a circle, but not too tight or you will lose too much altitude. Try for about a 50-75 foot diameter. Complete a couple of turns and see if the plane seems to be rising. If it is, just stay with the turn but give it a little up (back) stick. Not a lot, just a little. Maybe two to four clicks on the up trim. Just a little. We don't want to scare the thermal, we want to bond with it.
Try to observe if the plane is rising steadily, or if it seems to rise and fall. If the second, that means you are not centered in the thermal so work your way more toward the side of the circle where the plane rises.
Remember that thermals move with the wind, so you are not trying to stay in one place in relation to the ground. The air is like a river and you are trying to stay in a little whirlpool that is moving with the river.
If you go into the turn and make a couple of turns with no success, then just resume the search pattern I mentioned. Angles across the wind. Not into it and now with it.
If you are getting out too far, work your way back the same way, angles to the wind.
Unless you hit a boomer, you are not going to immediately know you are in lift, so you have to watch the plane. Sometimes it becomes apparent because you realize that your not sinking but appear to be holding altitude. The only way to do that is to be in lift.
As I say in the photo essay: " It is a hunter's game, if you are up for it."
Follow me, silently, and I'll show you where there's lift.
Good luck pilot! May your hunt go well!
