Closed Thread
Old Mar 11, 2004, 12:15 AM
Foam rules
Thatovalguy's Avatar
HdG Md.
Joined Jan 2003
thatovalguy Bird Dog thread #4
Lets try again and see if we can make this last only a couple weeks too.
littles bipe post 21 & 22
1st thread with plans see first post for info.
http://www.rcgroups.com/forums/showt...light=bird+Dog
plans are found in this thread on post numbers as follows:
Bird Dog post 125
Hellcat post 253
Zero post 271
P-39 post 291
2nd thread, just plain fun oh and lots of good info.
http://www.rcgroups.com/forums/showt...hreadid=193543
3rd thread
http://www.rcgroups.com/forums/showt...5&pagenumber=1
Thatovalguy is offline Find More Posts by Thatovalguy
Old Mar 11, 2004, 12:26 AM
Joplin, Mo.
Joined Feb 2004
thanks tog,
i won't be trying to use a 250, i bought some to have later when i get some experience and try something faster than the fun jet and bird dog. i have an isp-a i'm going to try to use.
in following the posts it seems that when members use a j250 at the tail of a plane they usually use it direct drive, but when used up front as a tractor it is usually geared.
is there a reason or just a coincidence?
tom63 is offline Find More Posts by tom63
Old Mar 11, 2004, 12:32 AM
Always Thinking Diffrent
BlackScorpion's Avatar
Manalapan, NJ
Joined Sep 2003
TOG i have a name for the new plans..
how about The SL1?
BlackScorpion is offline Find More Posts by BlackScorpion
Old Mar 11, 2004, 12:39 AM
Foam rules
HdG Md.
Joined Jan 2003
SL1,?
Tom its just a pitch speed thing. Direct you can get more pitch speed but the plane will need to travel fast, which is mostly wing and such. Now floaters need more tractor than speed so we gear them and use larger props. Most times same thrust just differant speeds of thrust and trying to make the prop work more efficant in the speed range you want.
Old Mar 11, 2004, 12:45 AM
Manalapan, NJ
Joined Sep 2003
[QUOTE]Originally posted by Thatovalguy
SL1,?
Stewart little 1 or SLB (stewart little bipe) or SLBD (stewart little bird dog)
Maybe i'm just tired sorry about rambling.
Old Mar 11, 2004, 12:54 AM
Joplin, Mo.
Joined Feb 2004
thanks tog, that makes sense. some day i'll learn enough to not have to ask so many questions.
six months ago i hadn't even seen an electric r/c plane. then a couple months ago kirkpul, a fellow pusherpropplanes yahoo group told me about the frog. i ordered the plans and built it but made it too heavy and had to use an eps 300c to get it in the air. it flew great but was no longer a slow flyer.
then kirkpul told me about the fun jet and i found these forums. i'm hooked now on your planes.
somewhere in one of the threads i read where someone used the motor from an isp-a in an edf-50. i can't remember for sure but i think he said it worked but just didn't have quite the same power. has anyone else tried this motor?
i'd be willing to give up some power in exchange for longer motor life if the fun jet would still fly good. right now i'm not looking for a speed demon, just a nice slow easy flyer.
Old Mar 11, 2004, 06:04 AM
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Hi Tom, and welcome.
The CN12-RXC (7.2v IPS motor) would work fine in the EDF-50, given enough power. The problem is that the CN12-RLC (4.8v, or EDF motor) is a very high speed motor. The edf motor pulls about 4 amps at 7 volts (I'm pulling numbers out of the air, here), where the IPS motor would be about 2a at 7v for the same pack, rotor, etc. That's right at half the watts. Given that prop curves are exponential (HP or watts increases by the square of the speed), you could maybe use a 3 cell Li pack, or a 10 cell Ni pack, to get the power out of the system. In fact, here it is as a complete unit: http://www.balsapr.com/catalog/motor...ductId=T205030
As you can see, there's a lot of guess work and then testing that goes on to figure out a good power system. That's why, once you've found a good combo, it's hard as heck to get you to try something else.
For example, I bet the J250 would be a great motor in the EDF-55. And, it should slide right in. Some have jambed them into the EDF-50, but looks too much like work to me... Soon, I'm sure BP will have the 55 parts, so we can try.
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 11, 2004, 07:00 AM
Foam rules
HdG Md.
Joined Jan 2003
Gene I'm thinking anywhere you use a gws350 you could use the J250 with better numbers all around.
Old Mar 11, 2004, 10:42 AM
Milwaukie Or
Joined Aug 2003
BD "Mushing"?
TOG:
The pest is back, I built 4 BDs and flew the first yesterday and it had a mushing attitude. I may have my CG at the wrong location, I know I have seen it mentioned but after reading 1000s of threads I can't recall. Where is the CG located?? The AUW is 7.26oz- HS 55s RP4II C5 2S1200s and S1w/9/4.7. I know the "normal" callout is an A but shouldn't it fly on a S1? There was a lot of interest in the BD at the fly-in.
Thanks in advance,
George
N5704A is offline Find More Posts by N5704A
Old Mar 11, 2004, 11:26 AM
KC9
Master Bluecor Smasher
KC9's Avatar
Chicago IL, USA
Joined Jan 2004
George,
CG is 1/3 behind the LE, S1 is OK I use one with a 9x7 prop.
KC9 is offline Find More Posts by KC9
Old Mar 11, 2004, 11:38 AM
Foam rules
HdG Md.
Joined Jan 2003
KC9 is correct on all counts. I normally maiden with the CG forward and keep moving it back till I get it where I want it to be. And thats just to get the feel I like in a plane. Most times I need to move the battery more forward when I let guy's fly them as I normally run it back a little farther than most like to fly a plane at. But that being said move it forward some and give it a go.
Old Mar 11, 2004, 01:51 PM
Foam rules
HdG Md.
Joined Jan 2003
preview time
Old Mar 11, 2004, 02:27 PM
Milwaukie Or
Joined Aug 2003
KC/TOG:
Thanks for the reply, I am pretty close to 1/3rd chord so I will change to 9/7 prop and see what happens.
George
Old Mar 11, 2004, 03:55 PM
KC9
KC9's Avatar
Chicago IL, USA
Joined Jan 2004
TOG,
I suggest you cut the mouse's profile in the foam and then paint it accordingly. I see you moved the wing down on the fuse. This deviates from the original. I suggest you move it up 1" but continue supporting it with a solid section of the double fuse.
Old Mar 11, 2004, 04:00 PM
KC9
KC9's Avatar
Chicago IL, USA
Joined Jan 2004
Closed Thread
thatovalguy Bird Dog thread #8 Thatovalguy Foamies (Kits) 554 Feb 28, 2005 07:18 AM
thatovalguy Bird Dog thread #7 Thatovalguy Foamies (Kits) 496 Nov 11, 2004 07:48 PM
thatovalguy Bird Dog thread #6 Thatovalguy Foamies (Kits) 489 Aug 09, 2004 05:21 AM
thatovalguy Bird Dog thread #5 Thatovalguy Foamies (Kits) 494 Jun 01, 2004 05:25 AM
thatovalguy Bird Dog thread #3 Thatovalguy Foamies (Kits) 499 Mar 11, 2004 12:12 AM
