Old Dec 15, 2001, 11:05 PM
WilliamSettle is offline
Find More Posts by WilliamSettle
Triad of Fun
WilliamSettle's Avatar
Joined Nov 2000
Another E3D is born...
It's ready to fly but I have a little more oracover to put on. I like Gary's red one so much, I thought I'd duplicate the color scheme except for the "E3D" letters since I don't know how to do that.
It's pretty much stock GW setup and weighs in at 54 oz with:
Endo/GB600/APC 12x8
Schulze Slim 50Be
10xRC-2400
HS-81's (non-MG)
FMA Quatum 8
Night Flying LED's in wing tips and tail
Magnetic hatch latch (rare earth magnets)
If I can keep it together for a brush life or two, it will get a Hacker B40 transplant.
Unfortunately, after all the work I've done on it, I won't be able to fly it for a couple of days because of rainy weather.
<a href="http://www.chingadeer.com/e3d/e3d.jpg" target=image><img src="http://www.chingadeer.com/e3d/e3dthumb.jpg" ></a>
Click on the picture for the original 2048x1536 version of it for a LOT more detail!
WilliamSettle is offline Find More Posts by WilliamSettle
Old Dec 15, 2001, 11:14 PM
Andreas is offline
Find More Posts by Andreas
Joined May 2000
Re: Another E3D is born...
Looking good!
It's been raining since a MONTH now,
no chance to fly mine:_(((((((
Andre
Andreas is offline Find More Posts by Andreas
Old Dec 16, 2001, 02:35 AM
ScotY is offline
Find More Posts by ScotY
ScotY's Avatar
Joined Feb 2001
That looks great, Bill! Hope you get to fly it soon! 54 ounces? That's way over a POUND lighter than my Magic!
ScotY is offline Find More Posts by ScotY
Old Dec 16, 2001, 12:46 PM
Dereck is offline
Find More Posts by Dereck
Visitor from Reality
United States, VA, Arlington
Joined Dec 1996
Nice job!
Mine's ready to start covering, once I vacuum the workshop clear of some balsa dust and do some odd "hunnydo's".
Doing mine yellow flying bits, blue fuselage bits, mostly see-through with solid nose. Getting the covering around the wing, as its glued in now, has suddenly occurred to me that it could be 'interesting'.
For the letters - use your word processor, find an appealing font for "E3D" and just increase the size to the most you can print out. If you can find bigger trim, blow it up some more on a copier. Tape your trim / film whatever onto a cutting board with the template above it. Arm yourself with a new #11 and get cutting.
Or go to a sign shop and get them to run you one up!
I'm not so much worried about the current weather as my current state of flying practice!
Dereck is offline Find More Posts by Dereck
Old Dec 16, 2001, 10:41 PM
Triad of Fun
Joined Nov 2000
Thanks guys, appreciate the feedback. Yep, it's way lighter than both of my Magic's. Actually, I sold my second magic already.
Dereck, good idea on the lettering, I'll try that later in the week.
Old Dec 16, 2001, 10:50 PM
Whizwaz is offline
Find More Posts by Whizwaz
I like cheese...
Whizwaz's Avatar
Bloomington, IN
Joined Sep 2001
Covering
William,
Looks great! Can't wait until mine arrives and I can start building
I have one question: What covering did you use? The color really catches my eye, and I would like to cover mine the same color. (I'm sure it's light too.)
Whizwaz is offline Find More Posts by Whizwaz
Old Dec 16, 2001, 11:00 PM
Triad of Fun
Joined Nov 2000
John, I used transparent red and dark red Oracover from Hobby Lobby. It requires a little more than one roll so get two.
I used the dark red for the bottom and the red on the top and sides. I also used ultracoat for the white but would not recommend it. It leaves a horrible seam compared to the Oracover. When the Oracover is seemed, it's virtually invisible.
After covering the wing, I wish I had of used the dark red everywhere. The red is really a light red and even though it is beautiful, the dark red will knock you eye out is is so deep in color.
Old Dec 17, 2001, 02:42 AM
GregG is offline
Find More Posts by GregG
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
William, She looks terrific! I'm starting to get the urge to try one after seeing one like yours. If I only had the room to build!
GregG is offline Find More Posts by GregG
Old Dec 17, 2001, 08:20 AM
Dereck is offline
Joined Dec 1996
Started covering mine last night - should have been doing something else, but Bill's new baby inspired me.
Reckon I am committed to my first (and probably last!) see-through model aircraft, but suspect that the yellow I thought was such a good idea when I ordered it is going to be a tad too see-through
Am approaching covering around the wing. Anyone offer any good ideas as to how to get around this one? Been so long since I did a mid wing one piece, I can't recall how to!
Old Dec 17, 2001, 08:48 AM
GWRIGHT is offline
Find More Posts by GWRIGHT
Product Manager at Hobbico
GWRIGHT's Avatar
United States
Joined May 2000
Start by cutting a couple strips about 3/16" to 1/4" wide. Iron them on at a bit higher temperature, around the junction of wing and fuse. If you get the temp high enough on the iron,.. it'll go around OK and stick down. Then when you cover the fuse, cut a piece for the fuselage, and use the endplate on the wingtip to cut out the airfoil. Slip it over, iron it on. Then cover the wing in 4 pieces, top/bottom, right/left,.. or if you're really adventurous, you can try one piece per side, but every time I try to do that and iron it on around a wing, I end up sticking the covering together and wasting it,..then going to 4 pieces Of course I'm not the most patient person in the world either,.. just ask my wife
GWRIGHT is offline Find More Posts by GWRIGHT
Site Sponsor
Latest blog entry: blog
Old Dec 17, 2001, 08:53 AM
GWRIGHT is offline
GWRIGHT's Avatar
United States
Joined May 2000
GWMP Q&A
It was suggested that I start a thread here for discussions on GWMP product(s). Although there's only one kit right now, there is a second in the works (Kwik-E), and plans for more after that (next one looks like it'll have to be an 80" span model). A single thread will be easier than wading through all the various topics. I'm on here as often as possible and try to answer things in a timely fashion.
Site Sponsor
Old Dec 17, 2001, 09:12 AM
kevin is offline
Find More Posts by kevin
kevin's Avatar
United States, OH, Grove City
Joined Aug 1999
good idea
gary,
do you sell the 10t pinions seperately? if so how much are they? and what would shipping be? if not where is the best place to get them?
thanks
kevin is offline Find More Posts by kevin
Latest blog entry: Video of my Freewing Yak-130
Old Dec 17, 2001, 09:18 AM
GregG is offline
Speed Demon
GregG's Avatar
Antioch,CA,USA
Joined Dec 1999
Thanks Gary, this should make it easier for all of us to keep up with your work. Keep'em coming and Keep'em flying!
Old Dec 17, 2001, 10:52 AM
Peter W is offline
Find More Posts by Peter W
Peter W's Avatar
London
Joined Jul 2001
hi,
can you pick up the E3D by the wingtips with flight battery inside without it snapping? i COULD do it with my twinstar but they bend quite a lot.
just worried about strength of this thing, when you have an all foam model like a twinstar, you take for granted how hard you can come in, but if the 3d CAN fly at walking pace into the wind, then things should be okay right?
As Gary said in another post, it's designed for flight load.
as for covering, how do you do it with NO wrinkles! it's a mystery to me so that's why i choose ARTF's! i've found no good posts with links to sites with diagrams showing how, and yes, i HAVE seen the insructions that come with the various film manufacturers products but myabe a finishing book would help?
oh! love this edit function! caould you make E3D have steerable tail wheel without adding significant weight and still fly good in air? would be SOOOOOO cool to have an electric model that can prop hang at my site AND taxy back...........
Peter W is offline Find More Posts by Peter W
Old Dec 17, 2001, 11:01 AM
GWRIGHT is offline
GWRIGHT's Avatar
United States
Joined May 2000
It has a steerable tailwheel and taxis back after every flight (assuming I leave enough juice in the batteries)
Yes, you can pick it up by the wingtips with everything onboard,.. and shake it quite vigorously. The wing is, if anything, a bit "overbuilt". Spars are only 1/4 sq balsa, but it's full span shear webbed, plus the leading edge is rolled 1/16" sheet which adds tremendous strength.
Site Sponsor
Service from Gary Wright Model Products barlows Vendor Talk 2 Aug 26, 2003 09:22 AM
Gary Wright Model Products E3D Robert Wick Electric Plane Talk 8 Apr 18, 2002 03:19 PM
Kudos to Gary Wright dottney Electric Plane Talk 0 Oct 18, 2001 08:50 PM
Gary Wright videos over on squid yb2normal Sport Planes 2 Oct 13, 2001 07:24 PM
Gary Wright shows us his stuff - video available! Andy W Electric Plane Talk 17 Sep 28, 2001 03:37 PM
