Old Mar 10, 2004, 03:59 PM
rcjetpilot is offline
Find More Posts by rcjetpilot
Bot's like to know where you live
Joined Sep 2003
I'm looking for a "High Quality" gearbox for Aveox 36/24/2
Hi Folks,
I have an Aveox 36/24/2 motor (5mm shaft) and need a top of the line gearbox. The setup will be used in a Great Planes F-14 IC plane which I'm going to convert to E-power. Will definitely be using 12-16 GP 3300 cells (600-700 watts or more).
I never owned, nor operated a gearbox setup and would prefer a very high quailty unit (inline if possible). I'm not concerned about the cost, its all an invest for future planes.
Any help would be greatly appreciated.
Bob.
How about this unit?
http://www.aircraft-world.com/shopexd.asp?id=499
rcjetpilot is offline Find More Posts by rcjetpilot
Reply With Quote  (Disabled)
Old Mar 10, 2004, 04:18 PM
HienrichDorfman is offline
Find More Posts by HienrichDorfman
"Meters, Mr. Towns..."
Joined Jan 2004
Try www.flydma.com
HienrichDorfman is offline Find More Posts by HienrichDorfman
Old Mar 10, 2004, 05:06 PM
Joined Sep 2003
Hi HD,
They only carry gearboxes with 1/8 pinions. The 36xxxx series are 5mm.
FYI, the flydma site has incorrect information of its Aveox listing for the 36xxxx series. They show the 36xxx with 1/8 shafts, as this should be 5mm.
Thanks though.
Bob.
Old Mar 10, 2004, 05:19 PM
Keitha is offline
Find More Posts by Keitha
Keitha's Avatar
USA, CA, Costa Mesa
Joined Mar 2002
http://www.innerdemon.com
these are great gear-drives. They are very flexible in that you can fit just about any motor (including an outrunner) in them with a wide range of easy to change gear ratios.
I think that the MiniDemon can take up to about a B40 size brushless while the InnerDemon can hold up to two B50 size motors.
Keitha is offline Find More Posts by Keitha
Old Mar 10, 2004, 08:47 PM
Ed Lyerly is offline
Find More Posts by Ed Lyerly
Recruiter - 60 Amp Club
Ed Lyerly's Avatar
Rutherfordton, North Carolina, United States
Joined Apr 2001
http://www.newcreations-rc.com/
Ask Kirk for an Astro Superbox with pinion for 5mm shaft. Robust, helical gears ... high quality.
Ed
Ed Lyerly is offline Find More Posts by Ed Lyerly
Old Mar 11, 2004, 12:43 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
My vote is for the MEC super box or monster box, depending on the ratio you need and how big a prop you want to turn.
The biggest advantage of these is that its easy to change ratios as needed.
http://www.modelelectronicscorp.com/
Larry
Larry3215 is offline Find More Posts by Larry3215
Old Mar 11, 2004, 12:56 AM
rcelectfly is offline
Find More Posts by rcelectfly
rcelectfly's Avatar
San Diego, CA, USA
Joined Nov 2001
Try www.flydma.com and order one of the Aveox planatary gear boxes that are made for your motor.
The planatary gearboxes are sealed and will not allow any dirt to get in like the Astro or Model Electronics gearboxes will.
Chuck
rcelectfly is offline Find More Posts by rcelectfly
Old Mar 11, 2004, 01:06 AM
rroback is offline
Find More Posts by rroback
Convert!
rroback's Avatar
Los Angeles, CA (UCLA)
Joined Nov 2002
aveox must sell a planetary gearbox. I bought one form them for my... ah... what was it.. oh yah, 1412/2y. super boxes seem nice, but I'm always afraid when a gear is visible. its ok for say a speed 400 motor, but anything large, I just get nervous something may hit the gear.
Rhett
rroback is offline Find More Posts by rroback
Old Mar 11, 2004, 01:49 AM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
I'm running a super box with a Mega 22/45/3 at 480 watts, 16x10 prop. Same motor in a 12 pound bipe and a monster box at 900+ watts, 22x10 prop. No problems. Thats a bit more than a speed 400
If you have a prop strike it strips the spur gear but the box is undamaged. The gears are easy to change out.
Like I said before, the biggest advantage is being able to easily change ratios to dial in a plane/motor combo. I have 4 or 5 pinions and several spurs on hand. I can do ratios fron 2.5 up to 7+ to 1. You can pop the motor out of one plane that needs thrust and into another that needs speed.
I like them, but they aren't rite for every application.
Larry
Old Mar 11, 2004, 01:57 AM
rroback is offline
Convert!
rroback's Avatar
Joined Nov 2002
The changing the gear ratio does sound nice. Don't you ever worry about any bit of gunk jamming the gearbox? I guess it is pretty strong. I just like to have everything sealed. 900watts? oh come on! even I can pull 900watts out of a speed 400!. maybe only for 1/100 of a second before it ignites in a ball of flames..
Rhett
Old Mar 11, 2004, 09:42 PM
Joined Sep 2003
Thank you all for your comments and suggestions. Very much appreciated.
After reading everthing, here are the two units that would work:
Both are list here:http://www.flydma.com/gearbox/36_gea...ath2=zoom4006v
Astro 702 gearbox 2:38 to 1 ratio for $34.95
or
Aveox 3.7 to 1 ratio for $94.95
I need a low geared setup using a max size 13"prop and needs to handle continuous high power.
Which one guys?
Bob.
Old Mar 11, 2004, 10:20 PM
Ed Lyerly's Avatar
Joined Apr 2001
Bob,
You can use an Astro Flight #712 Superbox (05/15 size) which has a 48 tooth spur gear. Put on a 13T pinion (for 5mm motor shaft) and you get a 3.69:1 ratio.
Ed
Old Mar 12, 2004, 08:57 AM
Joined Jan 2004
Look at Northeast Sailplane Products. I just bought a Promaxx SP 3.3:1 metal planetary type. $64.
Hienrich
Discussion Looking for high-quality easy kit OR built sub bos10 Submarines 8 Jul 07, 2006 03:40 AM
WTT Aveox 36/24/2 for a Aveox 36/30/2 pequeajim Aircraft - Electric - Airplanes (FS/W) 0 Jun 22, 2004 03:06 PM
High quality gearbox for Speed 300 Jay Burkart Power Systems 6 Feb 25, 2004 08:41 AM
Looking for High Quality Coroplast Zagi Winglets? 177ichael Aircraft - Electric - Airplanes (FS/W) 15 Jul 31, 2001 11:48 PM
Looking for High Quality Coroplast Zagi Winglets? 177ichael Foamies (Kits) 13 Jul 31, 2001 08:31 PM
