Old Mar 10, 2004, 03:23 PM
JB is offline
JB
Find More Posts by JB
JB
JB's Avatar
Copenhagen, Denmark
Joined Jan 2000
DC-9-21 EDF model
Some fellow modellers have encouraged me to open this new thread and show details of my current project: A Douglas DC-9-21, scale 1:11. SAS phased out the aircraft last year, but I managed to have a close look at some of them and take several photos and measurements before they were ferried to the US – some of them with my friend Torben Back Sřrensen at the controls.
I wanted a large model in order to accommodate several scale features and to have a docile model to fly. The scale 1:11 will allow for near scale nacelles with 120mm fans powered by HP 370/20/A3S motors = some 3kp thrust per engine.
Main data:
Span (overall) 2586 mm
Length (overall) 2893 mm
Height 762 mm
Wing root chord 493 mm
Tip chord 100 mm
Wing area 76,83 dm2
Est. all up weight 9 kg
Main features: Scale retracts with doors, Wheel brakes, scale flaps incl. inner triple slotted section, full leading edge slats, spoilers.
My first concern was transportation. It has to go into a normal passenger car. I decided to make the fuselage in two sections and detachable wings, tail and rear cone. They can then be stowed into a 60x70x130cm box....I hope!
More pictures to follow shortly......
JB is offline Find More Posts by JB
Old Mar 10, 2004, 03:50 PM
CAW_01 is offline
Find More Posts by CAW_01
Joined Feb 2004
Love The Idea of a DC-9. Presumably foam. Would love to get the plans and build one myself
CAW_01 is offline Find More Posts by CAW_01
Old Mar 10, 2004, 04:20 PM
Hawker is offline
Find More Posts by Hawker
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
JB, sounds very nice! Can't wait to see more pics.
Hawker is offline Find More Posts by Hawker
Old Mar 10, 2004, 05:47 PM
AirX is offline
Find More Posts by AirX
EDF rules... :)
AirX's Avatar
United States, TX, Katy
Joined Nov 1999
Cool likes like a few airliners coming out. JB we wopuld love ot see the design and build as you progress through it.
Eric B.
AirX is offline Find More Posts by AirX
Old Mar 10, 2004, 06:48 PM
RCParkflyer is offline
Find More Posts by RCParkflyer
RCParkflyer's Avatar
Racine, WI AMA# 809291
Joined Nov 2003
signing in to follow the thread, I'm most interested in the LE Slats set up and how your going to make this "transportable" Who makes 120mm Fans ?
RCParkflyer is offline Find More Posts by RCParkflyer
Old Mar 11, 2004, 12:35 AM
Rudi is offline
Find More Posts by Rudi
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
JB, if your DC9 will be so wonderfull as your Airbus A300 I vote you for the title "King of Modellairliners"
Greetings from vienna
Rudi
P.S Go on and give us more photos please !
Rudi is offline Find More Posts by Rudi
Old Mar 11, 2004, 05:10 AM
JB is offline
JB
JB
JB's Avatar
Copenhagen, Denmark
Joined Jan 2000
These are the parts to be assembled before flying. The wings are fitted with four dural studs to be locked to the centre wing by 3mm grub screws. The studs are secured to the carbon tube main spars by cyano and kevlar.
The two basic fuselage frames consist of five longitudinal carbon tubes fitted with dural end pieces at the joining face. Five 2mm screws are used for assembling the two halves of the fuselage.
Two 4mm titanium rods protrude below the vertical tail and fits into the fuselage where they are secured by 3mm grub screws. A further 2mm screw is fitted at the foremost end of the tail.
The horizontal tail is attached at its pivoting point by two nylon brackets secured to the vertical tail by four nylon screws. A trim device – to be designed later – will be linked to the tail near the leading edge.
Having solved the assembly I could concentrate on designing the various components. I always start with the most complicated items. If they cannot be made there is no point in going any further!
I started during the winter 2002/2003 with the undercarriage. Then the triple slotted flap sections and the leading edge mechanism.
More later.......
Old Mar 11, 2004, 02:58 PM
JB is offline
JB
JB
JB's Avatar
Copenhagen, Denmark
Joined Jan 2000
Nose Gear:
Flight and maintenance manuals show perspective drawings, but no actual dimensions so I had to take a few measurements on the gear to get the proportions reasonably right. The linkage activating the doors is done in a clever way and I wanted to do the same on the model.
Old Mar 11, 2004, 03:02 PM
JB is offline
JB
JB
JB's Avatar
Copenhagen, Denmark
Joined Jan 2000
I worked several hours at the pc to make a set of drawings and then at my small lathe/milling machine to make all the bits and pieces.
The leg has a build in coil spring and direct steering is provided through a servo fitted on top of the leg allowing small turning radius on the ground. The rims are machined in two halves and joined by eight 1mm screws and nuts. A 4mm alu-nut and a similar locknut secure the wheel to the shaft.
Old Mar 11, 2004, 03:06 PM
JB is offline
JB
JB
JB's Avatar
Copenhagen, Denmark
Joined Jan 2000
Here is a side wiev:-
Old Mar 11, 2004, 03:23 PM
Hawker is offline
Fly Brushless!
Hawker's Avatar
Las Vegas
Joined Aug 2002
JB, your work is just amazing! Talk about being inspirational.
You are THE Master Modeler of the Ezone in my book!
Thanks for the great pics!
Old Mar 11, 2004, 04:05 PM
Iso Octane is offline
Find More Posts by Iso Octane
Iso Octane's Avatar
Toronto, Canada
Joined Jun 2003
Oh... wow!
Can't wait to see more!
Iso Octane is offline Find More Posts by Iso Octane
Old Mar 11, 2004, 05:22 PM
CarreraGTSCS is offline
Find More Posts by CarreraGTSCS
Lori, hey, you're home early
CarreraGTSCS's Avatar
United States, NJ, Freehold Township
Joined Jan 2004
He-llo! Here I am sanding blue foam and there you are engineering miniature parts that could pass any A&P inspection. Simply amazing!! I'm not worthy.
CarreraGTSCS is offline Find More Posts by CarreraGTSCS
Old Mar 12, 2004, 12:02 AM
Rudi is offline
Rudi's Avatar
Joined Jan 2001
Incredible, what it is possible Against you JB I am a small sausage, please go on and share with us your construction !
Thank you
Rudi
Old Mar 12, 2004, 12:08 AM
Eddie P is online now
Find More Posts by Eddie P
Official Boat Bum
Eddie P's Avatar
United States, NV, Reno
Joined Mar 2000
JB, this has to be the ultimate Airliner project so far. Amazing! I am extremely impressed.
Eddie P is online now Find More Posts by Eddie P
C-17 Globemaster EDF Model GlasairAllen Electric Ducted Fan Jet Talk 5 Sep 09, 2008 10:31 AM
Foam DC-9 for GWS EDF-40 Rudi Electric Ducted Fan Jet Talk 140 Nov 23, 2007 05:41 AM
Build Log Edf Dc-9 ScalePilot727 Aircraft - Electric - Airplanes (FS/W) 82 May 30, 2007 02:43 AM
DC-9 Airliner for EDF-50BH - Official Build Thread Hawker Electric Ducted Fan Jet Talk 77 May 29, 2007 09:54 PM
DC-9 EDF-50 that ROCKS! Hawker Electric Ducted Fan Jet Talk 1032 Dec 28, 2006 12:19 AM
