Old Jan 25, 2014, 09:00 PM
tvdrone is offline
Find More Posts by tvdrone
SAR
Joined Aug 2013
Walkera QR X350 PRO (New v1.7)
WALKERA INSIDE: We were looking for a low cost, quick to assemble quadcopter, to be modified with FPV gear, something to travel with, overseas on rescue projects. So we purchased the Walkera QR X350 which can be assembled in 2 minutes, with no tools on hand. Today, our SAR teams were informed of another exciting version of the 350 size, the QR X350 Pro, compatible with Arducopter Mission Planner. We have included some photos of the final development. This new thread is designated for QR X350 Pro. Jan 2014
QR X350 Pro.: Farther, faster, longer, gimbal, FPV, Fatshark goggles and more!
Toss, Fly and Flip a Walkera X350 Pro DroneCode Quadcopter ! (5 min 19 sec)
Features:
• Quick assembly
• Completely Ready to Fly
• Up to 2 km / 1.24 miles
• Up to 25 minutes flight time
• Gimbal ready for camera anti-vibration 2-axis stabilization (new Walkera Quick Release G-2D)
• New FPV camera called the ILook included in the FPV1 Pro package
• First Person View (FPV) flight
• FatShark compatible
• GPS and "One Key" Return to Home
• GPS Auto Pilot functions
• Failsafe auto RTH and Land
• Low voltage protection
• Devention DEVO F7,10 computer radio
• Easy to see LEDs
• Balance charger with world compatible wall adapter for travel
• + Waypoints and all the core functions of Mission Planner.
Latest Firmware Updates zip/pdf: Mar 2015
http://www.iuasinc.com/firmware/
First Impressions: I must say Walkera has done a great job tuning X350 Pro with a variation of Arducopter firmware, as it flies very well stock, out of the box with g-2D gimbal. No tuning needed. If you don't want to spend weeks.. months.. tuning an DIY arducopter, this may be for you. In addition, for those who want to expand beyond the hobby of Ready To Fly (RTF) x350 Pro, will also find it even more interesting to explore the open source DroneCode.org APM Copter, Mission Planner and Telemetry.
Additional Info: The x350 Pro Devo F7 package does not allow you to start/stop recording. This is due to the 7 channel limitation. However a FP Convertor has been included for the iLook+, so if you choose to either upgrade to a 10 or 12 channel radio, you can assign that function to a switch. This other option is to sacrifice the gear switch or gimbal pitch for a record switch. There are several videos out showing you just how to do that.
Mission Planner Compatible: For the DIYDroners.
• Here is the default Full Parameter List to review: [ parameter-full-list-qrx350pro.param]
(if you restore this backup, remember to recalibrate, as your compass declination may be different to China
Note: We don't recommend that you use Mission Planner to do any tuning unless you are a Ardupilot developer, as this is only a variation of arducopter coding with custom codes, not arducopter. Changes can make your x350 unflyable.
• Everything about Waypoint Missions: http://planner.ardupilot.com/wiki/co...ts-and-events/
This is what Mission Planner brings to you:
Hundreds of GPS waypoints, free (the exact number depends on the memory of the hardware you’re using. Just point and click waypoints in the Mission Planner, and x350 Pro will fly itself to them. No distance limits! You can script entire missions, including camera control!
“Loiter” anywhere. Just flip the toggle switch and your copter will hold its position using its GPS and altitude sensors.
Automatic takeoff and landing. Just flick a switch and watch x350 Pro execute its mission completely autonomously, returning home to land by itself in front of you when it’s done.
Auto waypoints: allows you to map flight paths on computer for autopilot
Advance Failsafe: auto return home when radio signal loss or battery low
Circle: circle around by radius
Altitude Hold: stay on fixed altitude
Loiter: combination of position and altitude hold, hovering
Land: auto land
Simple: fly by compass
Simple GeoFence: user-defined box that if breached forces the copter to return
Ground Station Telemetry
Tuning and Auto Tuning
and many more...
The How To Mission Planner video  is available now  or you can watch all other 10 episodes about Arducopter/Taranis at DIYdrone [ youtube.com/diydrone ]
• BNF $279 tmart.com/~bnf
• BNF $310 bg.com/~bnf
• Devo F7 bg.com/~f7
• Devo F7 tmart.com/~f7
• Amazon: amazon.com/~x350Pro
• WiFi hobbywow.com/wifi
• Devo 10 G-2D http://bg.com/~devo10
• Complete FPV with Monitor http://banggood.com/~devo10FPV
Video Log:
Walkera QR X350 Pro APM Mission Planner. How-To (10 min 36 sec)
Co-Pilot Wireless. 2 Operators on one x350 Pro
Walkera Devo F12E Wireless Co-Pilot Mode (6 min 4 sec)
Short story with stock training footage, out of the box x350 Pro, iLook+ and G-2D
QR X350 Pro FPV iLook+ footage: Suspicious White Vehicle 1 (5 min 10 sec)
QR X350 Pro with the iLook+..... sweet.. heavy foliage and high speed looks great.. your settings view at 720p and up.
iLook+ 1080p FPV. Walkera QR X350 Pro & Devo F7 (4 min 50 sec)
Return to Launch (RTL) Test with iLook+
iLook+ 1080p FPV Camera Video TX. Walkera QR X350 Pro RTL Devo F7 (4 min 16 sec)
Remember to watch in HD where possible, or be pleased that the 360p is good.
FatShark goggle compatible
For those who submitted your questions about the QR X350 PRO to Walkera
here are some of the Q&A Updates from Walkera back in Jan 2014. We have transferred the original blog to this discussion.
ref.: http://www.rcgroups.com/forums/showthread.php?t=2077292
• What high capacity battery size will it come with the QR x350 Pro for 25 minutes?
5200-5800 mAh LiPo
• What is the advantage of the new propeller design?
Faster and longer flight time
• Can you control the gimbal from the Devo F7 and 10 transmitter?
Yes you can and the new version will be set with the new design DEVO 10 transmitter in White color, DEVO 10 white would get 2KM control range.
• Can existing owners easily upgrade from the QR x350 to the QR X350 PRO with the parts?
Yes, upper cover is completely the same, but you will need to replace many parts to make a PRO. It will be available to the public when the PRO is available.
• Other Related Releases
2015 x350 Premium: 2 GPS and OSD http://www.rcgroups.com/forums/showthread.php?t=2339777
Devo F12E: http://www.rcgroups.com/forums/showthread.php?t=2174140
Unlocking a Devo - Deviation: http://www.rcgroups.com/forums/showthread.php?t=2130645
Scout X4: http://www.rcgroups.com/forums/showthread.php?t=2251486
X350 Pro Race
Cellmeter 8 LiPo Tester and FPV day x350 (4 min 51 sec)
Coolest GCS with Devo F12E
Ultimate Ground Control Station GCS Yoke (12 min 56 sec)
6 flights modes with Taranis.
FrSky Taranis Setup 6 Flight Modes Mix plus 1 for APM Ardupilot (5 min 4 sec)
* DroneMission is a search and rescue team based in the USA. A DM archive project 写评论文章 *
tvdrone is offline Find More Posts by tvdrone
Old Jan 30, 2014, 02:39 AM
tvdrone is offline
SAR
Joined Aug 2013
About X350 Pro, OSD, Telemetry, DroidPlanner
News
Jun 3, 2014. iUAS, a Walkera company designated to support selective products in the North American market X350 Pro, Tali H500 US Edition, Scout X4 and X800. You can see their first releases at .. |more about iUASinc.com| and iUAS University https://www.facebook.com/iuasnews
great contribution from Taz007
http://www.rcgroups.com/forums/showp...postcount=2132
Information about Droid Mission Planning
3DRobotics IRIS - Mission Planning (2 min 12 sec)
2016 Updates Compatible and Supported HD cameras
http://dronemission.com/fpv-cameras.php
Git2 FPV Sports Camera Review Ft. Star Wars Disney Tali H500 (9 min 24 sec)
Firefly 6S GoFirefly! Unboxed, Reviewed and FPV Tested (5 min 32 sec)
Old Jan 30, 2014, 10:12 AM
BenHayat is offline
Find More Posts by BenHayat
Always Excel >>>
BenHayat's Avatar
United States
Joined Mar 2012
@TVDrone;
Beside the longer arms from the X800, what are the other differences between X800 and X350 Pro, both being quad?
What are the differences for a person to consider which to buy?
Would you say the 350 is more like a Sport FPV and 800 is more more for AP/AV?
Thanks!
BenHayat is offline Find More Posts by BenHayat
Old Feb 26, 2014, 05:42 AM
NewJersey is offline
Find More Posts by NewJersey
Joined Feb 2014
Hi,
How to achieve the "2 Kilometer" video range?
NewJersey is offline Find More Posts by NewJersey
Old Feb 27, 2014, 10:02 AM
tvdrone is offline
SAR
Joined Aug 2013
Originally Posted by NewJersey View Post
Hi,
If 2 km is capable, I believe using new Devo 10 or installing DeviationTX. I have not been able to confirm the maximum video range tested.
Old Feb 27, 2014, 11:01 AM
Joined Feb 2014
Hi,
Thanks for replying but I'm talking according to the official specs, what should I buy in order to make the 2 kilometer video range?
Thank you
Old Feb 27, 2014, 11:14 AM
Joined Feb 2014
Originally Posted by tvdrone View Post
If 2 km is capable, I believe using Fatshark goggle. I have not been able to confirm the maximum video range tested.
related discussion:
iLook: http://www.rcgroups.com/forums/showthread.php?t=2108176
Original Blog: http://www.rcgroups.com/forums/showthread.php?t=2077292
Hi,
Thank you
Old Mar 05, 2014, 08:21 AM
Ariete is offline
Find More Posts by Ariete
Madrid, Spain
Joined Oct 2009
The official specifications are:
  • Devo F7
    • 1 Km control range
    • 250 meters video range (VTX5803)
  • Devo 10
    • 2 Km control range
    • 400 meters video range (wifi VTX)
There are ways to increase the video range, walkera sells an amplifier. But in the FPV community the general consensus is that the best way to increase the video range is through circular polarized antennas.
Right out of the box devo F7 has a very crappy internal antenna that doesn't even reach the promised 250 meters, you have to mod the F7 to connect external antennas.
You can also use Devo 10 and use a video receiver compatible with VTX5803 such as the one on the fatshark goggles but to maximize the range you will have to use after market antennas.
Hi,
Thank you
Ariete is offline Find More Posts by Ariete
Old Mar 05, 2014, 08:47 AM
Aaron qin is offline
Find More Posts by Aaron qin
Aaron qin's Avatar
China, Guangdong
Joined Oct 2011
The QR X350 PRO will be available in these two days in BG.
Aaron qin is offline Find More Posts by Aaron qin
Site Sponsor
Old Mar 05, 2014, 02:41 PM
ElGuano is offline
Find More Posts by ElGuano
Joined Sep 2013
What are the dimensions of the battery and what is the cost?
ElGuano is offline Find More Posts by ElGuano
Old Mar 06, 2014, 09:32 PM
Flying Barry is offline
Find More Posts by Flying Barry
Australia, NSW, Sydney
Joined Jan 2007
QR X350 PRO Manuals & Parts List
Hi All,
If you are looking for the QR X350 PRO Manuals & Parts List have a look at the Walkera web site now here.
Barry
Flying Barry is offline Find More Posts by Flying Barry
Old Mar 06, 2014, 09:50 PM
ElGuano is offline
Joined Sep 2013
Originally Posted by Flying Barry View Post
Hi All,
Barry
I literally had my wallet in-hand and ready to order to Pro-Z-14 5200mah battery. But 1) I can't find it for sale on the site, and 2) their 3S 2700mah battery is more than $70
Old Mar 07, 2014, 02:35 PM
Joined Jan 2007
Besthobbysite have the (HM-QR-X350-PRO-Z-14) Li-Po Battery 11.1V 5200mAh here.
Barry
Old Mar 07, 2014, 08:29 PM
TiggyWiggy is offline
Find More Posts by TiggyWiggy
United States, GA, Woodstock
Joined Aug 2013
Personally, this new QR X350 looks good but so did the first version when I bought early. I am not going to beta test another Walkera product. I choose to wait this time to see what other users experience.
TiggyWiggy is offline Find More Posts by TiggyWiggy
Old Mar 08, 2014, 12:23 AM
ElGuano is offline
Joined Sep 2013
Barry
Out of stock there, but I had already found a couple of places in China and ordered several for testing Thanks!
Discussion Issues with a new Walkera QR X350 internetbug256 Multirotor Talk 29 Sep 08, 2016 10:04 AM
Discussion Walkera QR X350 a new start Bigglesquad Multirotor Talk 27 Jul 03, 2016 04:47 PM
Discussion New Walkera QR X350 Owners cornplumb80 Mini Multirotors 24 Nov 16, 2015 09:27 AM
New Product Walkera new GPS QR X350 releasing.. WXIA Micro Helis 1 Jul 31, 2013 05:47 AM
