Old Mar 09, 2004, 11:05 PM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
Starting my first scratch built, need some help...
I am planning on putting together one of Chris3D's Tiger Moths and/or Pitts. This will be a scaled up version from his RFFS design and be assembled out of Depron. My question lies in this...
I have a bunch (30) of the J250 motors from All Electronics. I wish to run these DD (the cost of adding a gearbox and the Depron makes it almost as much as a NIB white Tiger Moth from GWS) using either the 4025 or 4040 GWS props. I also have the 3030 and 3020 props if that would make a better choice. My main issue is, what should my wingspan be? I am thinking in the 18 - 20 inch range, but since I am a foam kit builder, I know nothing about figuring out scratch dimensions.
Any help would be appreciated.
Thanks!
Kevin
Trikster is offline Find More Posts by Trikster
Old Mar 09, 2004, 11:44 PM
SlowRider is offline
Find More Posts by SlowRider
It's the last plane honey
SlowRider's Avatar
Granite Bay, CA USA
Joined Jul 2003
So that's why you were looking for the foam... Can't wait to see it.
Andy
SlowRider is offline Find More Posts by SlowRider
Old Mar 09, 2004, 11:45 PM
Trikster is offline
Zoom, zoom...
Trikster's Avatar
Joined May 2003
Yup!
Old Mar 10, 2004, 07:45 AM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
The motor itself weighs 1 5/8 ounces. Figure the weight of the rest of your gear, pick an acceptable wing loading, and let that determine your needed wing area, and work back from there to your wing span...
Mike Taylor is offline Find More Posts by Mike Taylor
Old Mar 10, 2004, 10:23 PM
Trikster is offline
Zoom, zoom...
Trikster's Avatar
Joined May 2003
I appreciate the advice Mike, but I have only built kits in the past. I have no clue what you just said...
Old Mar 10, 2004, 11:19 PM
BGR is offline
BGR
Find More Posts by BGR
BGR
Foam Junkie
United States, CA, Oceanside
Joined Dec 2003
Translation:
Square foot = length X width / 144
Wing loading = Weight / Square Foot
Generally the bigger the wing the more weight it will support at a slower speed.
A heavy wing loading needs more speed to keep it flying and that means more power. It will have a higher stall speed so your landings will need to be a little hotter.
A light wing loading like 4 oz per sqft for example will allow the aircraft to lumber along very slowly and use less power to do so.
Im no expert but this is the way I understand the concept. Someone correct me if I am wrong.
BGR is offline Find More Posts by BGR
Old Mar 11, 2004, 12:05 AM
Team 30 Micro EDF
Joined Apr 2002
OK, let's try again...
Look at the weights and wing areas of your other planes. Figure out the square inches, divide by 144 to get the number of square feet. Then figure out the ounce pers square foot. You should get some idea of how much weight a square foot will hold up. Heaveier weights per square foot of wing area will fly faster than lower weights.
Find the one you like and pick that as your target loading. Figures for park flyers are perhaps 6 oz/sq foot for the sake of argument.
Now weigh the motor, gear, batteries, and take a guess at the airframe weight. Add that all up. Using this weight, figure out how many square feet (or square inches) you will need to keep that wing loading.
Once you have the area your plane needs you can divide that in half (for your biplane). Pick an aspect ratio (like 6:1 is common).
Area = span X chord (and span = 6 X chord for 6:1 AR)
therefore, Area = ( AR times 'X')('X'), or
Area = X squared times AR
X squared = Area / AR
If each wings area is 100 sq inches, then
X squared = 100 / 6, or
X squared = ~16, and X = 4
Your wing would then be 4" chord, and 24" span...
It's just algebra...
Old Mar 11, 2004, 12:08 AM
Trikster is offline
Zoom, zoom...
Trikster's Avatar
Joined May 2003
The math part is easy, but without the equations it was difficult. Thanks Mike and BGR, I will work with that and go from there.
Yippee! check out my first scratch built... torcgolf Slope 9 Dec 08, 2003 07:22 PM
first Scratch built need Help beaver newby Foamies (Kits) 17 Dec 02, 2003 08:24 PM
My 1st MotorWorks conv. need some help please Billy Haynes Scratchbuilt Indoor and Micro Models 9 May 10, 2003 02:34 PM
My First Scratch Built Plane - Thanks Hoppy Andycart Foamies (Kits) 12 Nov 12, 2002 02:22 AM
Sky Scooter first flight but need some help Dauntae Foamies (Kits) 2 Jun 14, 2001 08:59 PM
