Old Mar 09, 2004, 10:08 AM
Jones Boy's Avatar
NORWICH NORFOLK.UK
Joined May 2002
New Mega's 16/20/2 and 16/25/2 for ducted fan
Mega have just informed me that these motors are suitable for Lipo use.
These motors are due to be on the shelves in a month or so.
16/20/2 35A Max 3100 rpm/V and 16/25/2 35A max 2650rpm/V
Both motors are discribed as 400-480 replacements can this mean 400W-500W from a mega in a mini fan?
Thought you would like to know the Latest
Graham
Jones Boy is offline Find More Posts by Jones Boy
Old Mar 09, 2004, 10:25 AM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
Re: New Mega's 16/20/2 and 16/25/2 for ducted fan
Yes Meteor posted a thread about these 16/25's a little before xmas. Their kv is a little low for current NiHM/NiCd standard packs but if you increase voltage (good for LiPo) they should perform very well. 450W should be within reach but as with everything max power is very duration/cooling dependant.
Looks like a good motor
Haldor is offline Find More Posts by Haldor
Old Mar 09, 2004, 10:39 AM
Jones Boy's Avatar
NORWICH NORFOLK.UK
Joined May 2002
Haldor
I think you will find these are 2 Turn motors meteor was refering to the 3 turn?
KV is much higher 3 turn is 1700rpm/V
Graham
Old Mar 09, 2004, 04:40 PM
meteor's Avatar
Ontario, Canada
Joined Nov 2002
2-turn not so good...
Hi!
I've got one of the new 16/25/2's, and it turned out to be a bit of a disappointment...
In my Kyosho EDF tests, it turned out to be a little less efficient than even the 16/15/x series!
I don't know if I have a bum motor, or what, but the numbers don't make a lot of sense...
I'm going to reserve final judgment until someone else tests this motor in a similar manner.
I've included the Excel file, but be careful to compare apples to apples. (Be sure to pick a consistent target RPM, and try to find a match across all the motors, as the apparent "efficiency" (RPM/Watt) will increase as the power level drops)
I'm in the midst of trying to get a high-end power supply, so I can test motors in a completely consistent manner. (like this: http://cgi.ebay.com/ws/eBayISAPI.dll...category=32720 , but I'm waiting for a 0-20V, 0-50A version to appear on E-Bay)
Essentially, a power supply like this one will allow you to pick a target RPM for a given prop/fan, and them simply increase the voltage until you meet that RPM with each motor under test.
You then record the amps drawn, and move on to the next motor
(I attempt to simulate this with different battery counts/types, but it's a bit of a crap-shoot the get the RPM you're looking for)
I now have a MiniFan 480, so I can do a lower-load test as well.
Hope this helps.
meteor is offline Find More Posts by meteor
Sold 2 New mega's 16/15/7 stealthy Aircraft - Electric - Power Systems (FS/W) 2 Dec 13, 2006 07:59 AM
For Sale Wemotec Mini Ducted Fan w/ brushless Mega Acn 16/20/2 Pandy Aircraft - Electric - Jets (FS/W) 11 Dec 06, 2006 05:47 AM
Mega 16/20/2 in a Minifan like2fly! Power Systems 0 Oct 07, 2005 09:00 AM
New Mega 16/20/2 TMorita Electric Heli Talk 0 Apr 23, 2005 04:18 PM
Question JePe Pyranha Mega 16/20/2 Forest Electric Ducted Fan Jet Talk 60 Sep 10, 2004 03:11 AM
