Old Mar 09, 2004, 07:32 AM
PaddyinDublin is offline
Find More Posts by PaddyinDublin
poiteen power
Dublin City, Republic Of Ireland
Joined Jan 2004
Idea
Prop adapter for APC Props on GWS G-Boxes
Hi Guys,
Was wondering what prop adaptor i need to get to enable a GWS C box use apc-e propellors . I will be using a himax 2015 - 5400 motor with it ? I see on e-flightline.com the sell corbin gearbox shafts with the adaptor included , does anyone know any other adaptor which might suit ?
Hope y'all can enlighten me !
Cheers
PiD
PaddyinDublin is offline Find More Posts by PaddyinDublin
Old Mar 09, 2004, 02:41 PM
pipsta is offline
Find More Posts by pipsta
Norwich UK
Joined Oct 2003
I had the same problem when i bust my prop adapter that came from e-flightline. I havent been able to find any true 3mm adapters as of yet the best i can find is 3.17mm and 3.2mm which i currently use. Only trouble is u have to add a bit of tape around the shaft to prevent it from wobbling!!
sussex models does these
pipsta is offline Find More Posts by pipsta
Old Mar 09, 2004, 04:03 PM
Dennis Everett is offline
Find More Posts by Dennis Everett
Dennis Everett's Avatar
United States, CA, Ontario
Joined Mar 2002
If the shaft isnt cut off thease work pretty good,allerc and aeromicro have them..Dennis
Dennis Everett is offline Find More Posts by Dennis Everett
Old Mar 09, 2004, 04:20 PM
pipsta is offline
Norwich UK
Joined Oct 2003
thats an apc Slow fly prop.
I have done the same by placing the hub of a gws prop inside of a apc E prop after drilling it out to fit the diameter properly!!
Old Mar 09, 2004, 06:11 PM
beanie is offline
Find More Posts by beanie
Ann Arbor, Michigan, United States
Joined Sep 2003
you just need a 3mm prop adapter for the 300/350 series gearbox/prop shafts.
i get mine from www.aircraft-world.com... fits perfectly.
hope that helps
-beanie
beanie is offline Find More Posts by beanie
Old Mar 09, 2004, 06:18 PM
beanie is offline
Joined Sep 2003
oh i forgot, www.e-flightline.com also carries them.
-beanie
Old Mar 10, 2004, 07:36 AM
Happy|Harry is offline
Find More Posts by Happy|Harry
veni,vidi, roto volubilis
Happy|Harry's Avatar
Aberdeen, Scotland
Joined Jul 2003
the adapter you need is an MPJet part, most of the vendors that advertise here should stock them, MPJ8031 for the short version and MPJ8032 for the long
phil
Happy|Harry is offline Find More Posts by Happy|Harry
Old Mar 11, 2004, 02:46 AM
Smokin' Beaver is offline
Find More Posts by Smokin' Beaver
Registerd Beaver
Smokin' Beaver's Avatar
Australia, WA, Warwick
Joined Jul 2003
Hi Paddy,
I had same prob.
I bought a 9x6E APC and it came with the adaptor rings for all types of shafts - except the GWS 3mm
So I went to LHS with both items in hand & picked up a length of aluminium tube whose ID fitted shaft & OD fitted one of the adaptor rings.
cost me $3.50 and will give me....oh...about...200 x 6mm long adaptors!
Phil
Smokin' Beaver is offline Find More Posts by Smokin' Beaver
Old Mar 11, 2004, 04:27 AM
poiteen power
Joined Jan 2004
hi smokin
thats a great idea !!! Will ramble down to the LHS oday and see if they can oblige me with some aluminium tube !
Thanks again
PiD
3mm prop adapter for apc e props brianb10 Parkflyers 5 Jan 05, 2005 05:53 PM
5mm prop adaptor for APC props? Steph280 Flying Wings 2 Oct 30, 2004 07:01 PM
APC props on GWS shaft? Windysurfer Power Systems 9 Sep 27, 2003 08:12 PM
3 MM Prop Adapter for APC props genenjr420 Power Systems 3 Jul 17, 2003 08:14 AM
Using APC props on GWS gear boxes for IFO Nowell York Power Systems 5 May 08, 2003 12:18 AM
