Old Mar 08, 2004, 09:25 PM
rakm is offline
Find More Posts by rakm
rakm's Avatar
Pensacola Regional, Florida, United States
Joined Jan 2002
Power supply for bench testing Phoenix controllers
Any advice on what type of power supply is safe to use to power the Phoenix controllers for bench testing. I have one similar to this http://ramboy.com/cosel.htm (I have the K150 that's sold out) and want to verify it's safe to use.
Ron
rakm is offline Find More Posts by rakm
Old Mar 09, 2004, 04:53 PM
BEC is online now
BEC
Find More Posts by BEC
BEC
BEC's Avatar
Auburn, Washington USA
Joined Jan 2001
Do you want to use it directly in place of a drive battery? Hmmmm..... Patrick will have to weigh in here. One thing is that you'd have to make sure that your power system was propped for less than the current that supply can deliver (13A, isn't it?).
I don't know what the ramifications are of feeding rectified AC to an ESC in place of plugging in a battery. I know Kontronik and Schulze instructions caution strongly against doing such a thing, but that may be due to European CE RF noise regulations as much as any functional issues with the ESC.
BEC is online now Find More Posts by BEC
Old Mar 09, 2004, 05:54 PM
whanderson is online now
Find More Posts by whanderson
Baltimore Bwi Rr Stn, Maryland, United States
Joined Oct 2003
Re: Power supply for bench testing Phoenix controllers
Ron
I have run my PHX 50 with a 13.5V 15A bench supply with no trouble. The PS you reference is adequately regulated and protected, not a problem. Patrick and company do excellent work. Your controller is safe to use.
whanderson is online now Find More Posts by whanderson
Old Mar 10, 2004, 02:25 PM
rakm is offline
rakm's Avatar
Joined Jan 2002
Yes this was to use in place of a battery for bench testing various props with the same motor. I talked with Patrick on this and he said it should be ok as long as the power leads coming from the power supply to the esc are not excessively long. Tested this out last night and it seems to be working fine so far. Thanks for the replys...
Ron
Old Mar 10, 2004, 03:18 PM
BEC is online now
BEC
BEC
BEC's Avatar
Joined Jan 2001
Glad you got the answer right from "the man" himself.
Old Mar 10, 2004, 10:33 PM
Patrick del Castillo is offline
Find More Posts by Patrick del Castillo
Patrick del Castillo's Avatar
Olathe,KS,USA
Joined Oct 2000
The other thing is that the input caps will run hotter on a power supply than on a battery -- so it's a good idea to add some output caps to the power supply itself. About 10,000uf of 35V caps should work fine. (and can be bought fairly cheaply at Radio Shack.)
The reason is that a battery will take power BACK from the controller and a power supply won't. (A brushless controller will both source current from the power supply, and try to force the power supply to sink current as well -- a battery will source and sink current, a power supply usually will only source current.)
Patrick
Patrick del Castillo is offline Find More Posts by Patrick del Castillo
Mini-HowTo Convert a computer ATX power supply for bench work old man emu Australia 44 May 26, 2007 02:56 AM
Discussion Power Supply For Bench Testing The L Batteries and Chargers 11 Apr 04, 2007 05:43 AM
Discussion Power Supply For Bench Testing himszy Submarines 15 Feb 07, 2006 12:02 AM
PC Power Supply For Motor Testing Tom Frank Power Systems 1 Dec 08, 2004 06:00 PM
Universal power supply for motor testing? Radiofly Power Systems 42 Mar 23, 2004 11:15 AM
