Old Jan 18, 2014, 12:54 AM
notlkk is offline
Find More Posts by notlkk
Joined Oct 2012
Boscam RX-LCD5802 Questions
Anyone familiar with this monitor? What type of antennas would be a good replacement for the default ones?
I'm looking for an AIO monitor (with built-in battery and RX). I'd appreciate it if someone could recommend a good buy.
Thanks.
notlkk is offline Find More Posts by notlkk
Old Jan 18, 2014, 02:24 AM
djmorgan is offline
Find More Posts by djmorgan
djmorgan's Avatar
Australia, QLD, Gold Coast
Joined Aug 2013
Thanks.
I run this monitor and find it great I fly a Quad, and it is important what you fly for aerial selection, my vehicle is always in front of me and the monitor so I have a Panel antennae on one channel and a Boscam circular cloud on the other.
My TX is Boscam and has a circular cloud on that, I have had it out to 1200 meters without loss.
You can see the antennae swapping as it finds the best signal.
David
djmorgan is offline Find More Posts by djmorgan
Old Jan 18, 2014, 03:22 PM
CRuss is offline
Find More Posts by CRuss
Joined Dec 2013
Thanks.
+1, in the same boat. Any links to more info/ordering would be helpful.
CRuss is offline Find More Posts by CRuss
Old Feb 20, 2014, 01:10 PM
CJ31 is offline
Find More Posts by CJ31
Joined Jan 2014
Bumping because I'm ordering this monitor today. $150 from banggood.com. Anyone order from them?
David - 1200m is good range. Which tx and antennas do you have? Any links?
I'm considering the Boscam TS352 500mw tx or the Immersion 600mw.
Thanks!
CJ31 is offline Find More Posts by CJ31
Old Mar 05, 2014, 03:57 AM
aeromodellers is offline
Find More Posts by aeromodellers
Joined Sep 2010
This is a good screen but has some serious issues with Fatshark frequency.
When I connect it to my immersion RC tx, there is a lot of disturbance on the screen and it does not display the image properly. This happens only with Band C channels. The same video tx works perfectly with my other receiver (AOMWAY) the Fatshark goggles work fine... but this monitor does not display properly on the Fatshark frequency. I have had the same issue with another video monitor from infinity-hobby.com with 32 ch inbuilt receiver.
Looks like it does not like fatshark frequency. I have even tried with RHCP Clover leaf antennas... result if the same..
Can anyone using this with immersion RC video tx confirm the problem???
Thanks.
aeromodellers is offline Find More Posts by aeromodellers
Old Mar 08, 2014, 10:45 AM
djiatl is offline
Find More Posts by djiatl
Joined Dec 2013
Thanks.
Yes - having the same issues... see here:
http://www.rcgroups.com/forums/showt...2#post27726499
djiatl is offline Find More Posts by djiatl
Old Apr 10, 2014, 08:26 AM
theshadow is offline
Find More Posts by theshadow
Joined Apr 2014
Does anybody know what kind of antenna connectors the Boscam 5082 uses?
Unsure whether they're SMA or RP-SMA and what kind of antennas to fit.
This page on helical suggests that a male-to-male adaptor would also be needed:
http://www.helipal.com/boscam-7-moni...-recevier.html
theshadow is offline Find More Posts by theshadow
Old Apr 16, 2014, 11:54 AM
gnolivos is offline
Find More Posts by gnolivos
gnolivos's Avatar
United States, OH
Joined May 2008
I own this monitor. The antenna needs to have a small needle pin on it's connector. The LCD has a small hole on the connector.
gnolivos is offline Find More Posts by gnolivos
Old Jun 25, 2014, 12:01 AM
truemettle is offline
Find More Posts by truemettle
Joined Jun 2014
Replacement battery for Boscam LCD
Does anyone know where I can get a replacement battery for the Boscam LCD
It's a 7.4 volt 2450 mah part number ONG RH 12490
truemettle is offline Find More Posts by truemettle
Old Sep 02, 2015, 05:18 AM
(Jo)Hannes is offline
Find More Posts by (Jo)Hannes
der Frickler
(Jo)Hannes's Avatar
Trier, Germany
Joined Aug 2007
Has anyone tested the Diversity out of the Monitor?
Many others have the problem that it is not "strong" enough so that the image is blurry on the googles and on the monitor if you connect the googles to the output.
(Jo)Hannes is offline Find More Posts by (Jo)Hannes
New Product Boscam RX-LCD5802/5812 7" LCD Monitor 32CH Diversity Receiver GhostMaster FPV Equipment 1271 Feb 06, 2016 05:41 AM
Help! Boscam 7" monitor,duel 5.8 rx bonito13 FPV Talk 1 Jan 28, 2014 06:14 PM
Boscam 5.8ghz 1000mw TX & RX Flywithmerc Non R/C Items (FS/W) 0 Oct 27, 2013 08:18 PM
Sold boscam 200mw tx and rx. chuck4816s Aircraft - Electric - Multirotor (FS/W) 3 Oct 14, 2013 11:53 PM
Found Boscam 5.8 rx/tx combo (Want to Buy) Whoaty55 FPV Equipment (FS/W) 0 Oct 10, 2013 08:50 AM
