Old Mar 08, 2004, 04:26 PM
jshelton is offline
Find More Posts by jshelton
Jim in Santee
jshelton's Avatar
United States, CA, Santee
Joined Oct 2001
incidence/CG problem with Timeless Flyer
Just flew my new Timeless Flyer. This is the old-timer style 480-powered plane from Hobby People. It has the wing mounted on a pylon like the old Playboy freeflight models.
On the first flight, I had to hold almost full up trim to keep the plane from diving (power off). I moved the CG back to the rearmost point suggested in the instructions but the same problem persisted as well as making the plane a lot more twitchy. I then decided to increase the wing incidence by 1/16: and it flew slower with less up trim needed to maintain a shallow glide path. However, it is still much too fast for an undercambered old-timer model so I increased wing incidence to 1/8". I flew it several times with this setting and it seemed to fly much slower and have a much better glide. However, I still have to fly with full up trim to keep the plane from speeding up/descending too quickly.
It appears that I need to raise the wing incidence even more so that I don't have to use full up trim. However, it's hard to believe that since the fuselage has the wing and stab mounts molded in that the default incidence could be so far off. I considered moving the CG back but I'm already at 34%.
Any ideas what the problem might be???
jshelton is offline Find More Posts by jshelton
Old Mar 09, 2004, 12:25 PM
Lone Yankee is offline
Find More Posts by Lone Yankee
Hiigaran member
Lone Yankee's Avatar
'on a mountian in New Hampshire
Joined Aug 2002
My first though would be to address the prop downthrust setting, but if you are having this issue power-off then that rather dismisses that theory. If you can, try some weight reduction from the nose, heavy landing gear components are infamous for being heavier than needed.
Good luck -LY
Lone Yankee is offline Find More Posts by Lone Yankee
Old Mar 09, 2004, 04:44 PM
jshelton is offline
Jim in Santee
jshelton's Avatar
Joined Oct 2001
thanks for the feedback. The problem is during power-off flight. I will probably try moving the CG back and see if it helps.
Old Mar 09, 2004, 04:46 PM
Phreakish is offline
Find More Posts by Phreakish
Nickel what?
Phreakish's Avatar
Prescott, Arizona, United States
Joined Jan 2003
duh question: Whats your weight? and what's the wing area?
an undercambered wing should make lots of lift and have not trouble keeping the plane in the air - but they do have some funny pitching moment quirks.
Whats your elevator incidence relative to the wing?
Phreakish is offline Find More Posts by Phreakish
Old Mar 09, 2004, 04:55 PM
jshelton is offline
Jim in Santee
jshelton's Avatar
Joined Oct 2001
The plane weighs 22 oz.
Wing Span: 61 in.
Area: 370 sq. in.
Don't have an incidence meter but the stab looks like it has about 2-3 degrees negative incidence in relation to the wing.
Old Mar 09, 2004, 05:00 PM
Nickel what?
Phreakish's Avatar
Joined Jan 2003
hmmmm... thats odd then.
Old Dec 16, 2004, 06:57 PM
Mark Gund is offline
Find More Posts by Mark Gund
Parrothead Extraordinaire
Mark Gund's Avatar
Island of Margaritaville.No parallels of latitude or longitude mark the spot exactly. Passports are not required
Joined Sep 2002
Mine flew great, out of the box. No pitch change, any or no throttle setting.
Mark Gund is offline Find More Posts by Mark Gund
Old Nov 14, 2012, 07:20 PM
pval3 is offline
Find More Posts by pval3
pval3's Avatar
raleigh, NC usa
Joined Aug 2001
any updates on your results?
building one now . . . any thoughts in retrospect?
thanks
pval3 is offline Find More Posts by pval3
Old Nov 16, 2012, 02:01 AM
jshelton is offline
Jim in Santee
jshelton's Avatar
Joined Oct 2001
thanks
Haven't flown it in years. Might just have been an isolated issue since other people don't seem to have had a problem. Good luck - it's a nice plane!
Discussion cg problem with superpower f 117 stealth retiredfitter Pusher Prop Jet Models 1 Oct 21, 2006 04:41 PM
CG Problem with a CAP 232 bjdenno Fuel Plane Talk 0 Sep 11, 2005 06:37 AM
Any problem with bipe dihedral and incidence??? TM! Magna Sport Planes 0 Jun 27, 2004 07:10 PM
Problem with charging NiMH cells on a Hitec CG-340 Biggles604 Batteries and Chargers 3 Mar 03, 2003 02:27 AM
Help! - Problem with Tiger Moth - CG? mrebman Parkflyers 5 Jul 07, 2002 12:10 PM
