This thread is privately moderated by rockbus, who may elect to delete unwanted replies.
Old Jan 15, 2014, 02:04 AM
rockbus is offline
Find More Posts by rockbus
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Bagging Replacement Opus Wings
Delayed Still: Sorry for the delay. Will start back in 2015. Have a new belt sander to help shape the wings.
Note: Work is being delayed on this wing build due to Little James - James and Rosarios new baby.
This will be a slow going thread on making wings for a couple of Opus V fuses. Summer of 2013 I bought a 2M Carbon Blade fuse, 2 Opus V fuses and a T Tail fuse with a missing nose.
The 2M Blade fuse was fitted to my busted up Blade wings and is currently flying again.
Jame D and I will be making wings for the OPi. We started by blocking out blue foam, creating templates and cutting the middle section.
Plan is to cut the outer wing panels then building the wings PSS like. Which means Balsa or Ply wing Sheeting, a 3/4 inch popular or bass wood LE and a 2 inch Aileron Stock TE. We then plan on bagging the wing with carbon and 2 layers of 4 Oz glass. Kevlar live hinges too.
Thread on the drop arm cutter
http://www.rcgroups.com/forums/showthread.php?t=1779705
Josh18's Opus Wing Thread
http://www.rcgroups.com/forums/showthread.php?t=1544887
Video to follow.
rockbus is offline Find More Posts by rockbus
Old Jan 16, 2014, 06:41 PM
chip.greely is online now
Find More Posts by chip.greely
chip.greely's Avatar
Carlsbad, Ca
Joined Mar 2007
Pretty nice Ray,
Looks like you gotta little ridge on the top of your Blue Foam core (Center Section?) Shouldn't effect anything though, seeing on where it is on the airfoil.
You decided to go with RG14 airfoil. Was that the original for the Opus?
I need one for my fuse,...the fourth Opus fuse in your purchase, but I want CF Bagged only, no balsa/ply skin.
Subscribed
chip.greely is online now Find More Posts by chip.greely
Old Jan 18, 2014, 02:06 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Chip that line is when I moved the bow to the right to keep it centered. There is no ridge, luckily.
I dont know how the final wing will come out with the bagged balsa skin, once we do I'll know if the templates will be the right size for FG/Carbon only skins.
Old Jan 18, 2014, 02:09 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Video of the foam cutting
One vid uploaded showing the foam cutting.
There was a lot of setup to make sure the wire is pulled though the foam so the start and stop is the same on both sides of the foam block. Also this set of templates uses up too much foam but we wanted to get one core cut to make sure we're doing it right. This is the first blue foam wing cut so we were anxious.
Since then I've made a new set of templates so we can gut two wings from this thickness of foam.
Opus Middle Wing Top Cut (3 min 4 sec)
Video of the reveal.
Opus Center Section Reveal (0 min 34 sec)
Next step is to cut the wing tips.
Old Jan 19, 2014, 12:48 AM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Right tips cut Its gonna be a while before the left tips are cut.
Old Jan 19, 2014, 11:47 AM
Slopedaddy is offline
Find More Posts by Slopedaddy
Works to Fly
Slopedaddy's Avatar
United States, CA, Irvine
Joined Sep 2007
Nice! I'll have to learn how to make templates and cut cores one of these days.
Slopedaddy is offline Find More Posts by Slopedaddy
Old Jan 19, 2014, 09:39 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
I've got a vid of the bottom cut but I've reached my weekly limit in Vimeo until Tuesday.
OK Its past Tuesday here is the bottom cut video
Bottom Cut Opus Center (2 min 8 sec)
This weekend we're cutting the left wing tips....
Slow an steady. I really got to get my Zephyr done....
Old Jan 23, 2014, 10:44 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Chuck
I get formica from Lowes they have sample pieces 12X12 for 25 cents shipped.
Use one of the free airfoil programs and figure out the Airfoil and thickness then size it to the chord you want.
Make a couple copies and 3M77 them on the formica.
Then cut them out with a bandsaw/jigsaw/scrollsaw. Sand to final shape.
I'll take pictures of my templates.
Here is the thread on the drop arm cutter
Ray
Old Jan 27, 2014, 09:38 AM
agarchitect is online now
Find More Posts by agarchitect
On the Go Fly List
agarchitect's Avatar
United States, CA, Concord
Joined Dec 2009
Ray,
subscribed...and in search of a wing for my OPUS MC3 v-tail fuse. Why are there so many wingless fuses around?
Adam
agarchitect is online now Find More Posts by agarchitect
Old Jan 28, 2014, 02:42 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
To give credit. Here is Josh18's Opus wing.
Very nice.
Old Jan 28, 2014, 02:45 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Adam
Hope you find a wing. I dont know why there are so many fuses but not many wings.
There are a couple of Opi for sale.
Ray
Old Jan 28, 2014, 05:26 PM
jduartep is offline
Find More Posts by jduartep
Del Mar California
Joined Mar 2007
Pic of the wing
Here you go....
jduartep is offline Find More Posts by jduartep
Old Jan 28, 2014, 08:33 PM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
Nice James. I can already see the planes in the air......dropping down to the dark side.....
Old Feb 03, 2014, 11:07 PM
Carlsbad, Ca
Joined Mar 2007
Looking good Ray!
Looks like James' TE got a little thin on the center section. Maybe the wire was a bit too hot.
What chord widths did you use for your center and wing tips? Did you taper the wing tips both LE & TE?
Old Feb 26, 2014, 12:25 AM
rockbus is offline
rockbus's Avatar
Carlsbad, CA
Joined Sep 2004
OK I'll get photos later this week but we sheeted the bottom of James' wing and inlet a 3/8 X 3/8 Basswood spar with epoxy.
Sold Wing Tote wing bags - 42" & 59" Double Wing Bag ptgarcia Aircraft - General - Miscellaneous (FS/W) 6 Sep 29, 2012 02:35 PM
For Sale Wing Bags, Custom Wing Bags, Wing Carriers RoyAceWings Aircraft - Electric - Airplanes (FS/W) 5 Jul 01, 2012 11:03 AM
For Sale Wing Bags, Custom Wing Bags, Wing Carriers RoyAceWings Aircraft - Fuel - Airplanes (FS/W) 0 Jun 30, 2012 09:44 AM
For Sale Opus wing / plane bag Mark Canfield Aircraft - Sailplanes (FS/W) 5 Nov 28, 2008 08:47 PM
For Sale Shun Da J3 Piper Cub Replacement Wings (brand new in sealed bag) $9 delivered! kctrading Aircraft - Electric - Airplanes (FS/W) 0 Jul 21, 2006 04:48 PM
