Old Jan 14, 2014, 04:41 AM
Sai Kiran is offline
Find More Posts by Sai Kiran
Joined Aug 2013
Ornithopter gear mechanism
Greetings
Hello friends . I have started to work on ornithopter and collected some information but still there are many gaps left . I hope anyone to clear the gaps
1)What should be the gear mechanism for flapping wings ? There are few mechanisms out there . One of them is four bar linkage mechanism . Are there any other mechanisms for flapping wing flight ? Which of those is the best one ? Why ?
2)What should be the gear reduction ? What should be the flapping frequency of the wings ?
Also, birds twist their wings during the flapping to maintain the angle of attack.What mechanism should we follow for twisting ? What should be the angle of attack of the wings?
3)I am thinking to use balsa wood for my ornithopter and ripstop nylon for wings . Do you suggest any other materials?
4)How do you attach the spar rods to the main frame ? How do you connect the flapping wings and the reciprocating motion of the gear?
5)Is there any theory regarding the flapping frequency and the lift of the bird ?
Please help me with my doubts .
Thank you
Sai Kiran
Sai Kiran is offline Find More Posts by Sai Kiran
Old Jan 14, 2014, 12:42 PM
KJELL is offline
Find More Posts by KJELL
Kjell Dahlberg
KJELL's Avatar
Mallorca Spain
Joined Nov 2005
You can learn a lot from Kazuhiko Kakuta
http://homepage2.nifty.com/smark/FalcH22E.html
KJELL is offline Find More Posts by KJELL
Old Jan 14, 2014, 10:50 PM
Joined Aug 2013
Thanks a lot
Old Jan 15, 2014, 06:39 AM
seagull10 is offline
Find More Posts by seagull10
Joined May 2011
Here is one more good place to learn from :
http://http://www.ornithopter.de/
seagull10 is offline Find More Posts by seagull10
Old Jan 16, 2014, 12:00 PM
BrokenSmile is offline
Find More Posts by BrokenSmile
Joined Oct 2013
I'm a newbie in this field, so correct me if I'm wrong :
2) The frequency is about 3 to 7Hz, it's depended on the size and the shape of the wing. About the twisting things in birds, if the aoa is negative, it creates negative lift but gives more thrust. Beside, the part of the wing near the body has a small changes in aoa and almost always creates the main lift. Therefore, for ornithopters, even without the twisting mechanism, they can fly. In case you want to apply twisting mechanism, you should study the Smartbird of Festo, in which they use servos to twist the wing (using sensors to measure the wind, etc.). The angle of attacks or do you mean the flapping angle?
5) I find this website quite interesting: http://people.eku.edu/ritchisong/554notes2.html
I'm trying to build one on my own... Hope you could build yours soon )
BrokenSmile is offline Find More Posts by BrokenSmile
Old Jan 17, 2014, 12:54 AM
Joined May 2011
One more helpful article:
http://groups.csail.mit.edu/robotics...ackowski09.pdf
Discussion A possible ornithopter flapping linkage mechanism GreenAce92_v2 Ornithopters 9 Aug 14, 2012 09:16 PM
Alert Problem with glide lock mechanism on SK Ornithopters bwayneholt Ornithopters 20 Jun 18, 2012 12:23 AM
Discussion Ornithopter Mechanical Design Eric1635 Ornithopters 12 Jul 15, 2011 10:09 PM
Gallery Test of an ornithopter flapping mechanism and wings djacob7 Ornithopters 6 Dec 01, 2009 08:38 PM
Plastic geared servos for ornithopters- no way !!!!! andyUK Ornithopters 4 Dec 20, 2002 11:47 PM
