Old Dec 16, 2001, 03:42 AM
xadmin is offline
Find More Posts by xadmin
CA and NH
Joined Oct 2001
Rudder and throttle on left control stick on Pico Stik
Hi, I learned how to fly on a sailplane and it uses rudder and elevator on the right control stick. Now I just started on an electric power aircraft and it uses rudder and throttle on the left control stick. Is this the normal set up?? It seems pretty inconsistent because whenever you turn left or right, your throttle changes a bit due to both function on one stick.
xadmin is offline Find More Posts by xadmin
Old Dec 16, 2001, 03:55 AM
Azarr is offline
Find More Posts by Azarr
RIP Azarr - "Old age is not for sissies"
Azarr's Avatar
Dayton Intl, Ohio, United States
Joined Jan 2000
Just move you rudder servo to the aileron port in your receiver. Most of us in the US use the right stick for primary roll control (Mode II), whether it's an aileron or rudder makes no difference as far as the radio is concerned. Or did I miss something?
Azarr
www.ecubedrc.com
Azarr is offline Find More Posts by Azarr
Old Dec 16, 2001, 04:40 AM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
I completely agree with Azarr... If it's a r/e/a plane, r on left, a on right... if it's e/a, a on right... if r/e only, r on right...
i think that's the same thing azarr is saying...
opualuan is offline Find More Posts by opualuan
Old Dec 16, 2001, 01:23 PM
xadmin is offline
CA and NH
Joined Oct 2001
I am sorry I missed what you guys are saying. My throttle and rudder are on the left control stick and my elevator are on the right. Is this normal?
Old Dec 16, 2001, 02:44 PM
Dauntae is offline
Find More Posts by Dauntae
Dauntae's Avatar
New Bedford, Ma. USA
Joined May 2001
The setup is chosen by what the controls on the plane are, the right stick is set up for which ever control you want to use to turn the plane, If the plane has ailerons you would put the ailerons and elevator on the right stick because the ailerons are the control surface that will mainly be used for turning. if you have a plane with rudder and elevator only than the rudder should be on the right stick with the elevator. Most of the electric's have either just ailerons and elevator or rudder and elevator except for aerobatics reasons, I have a wattage Hawk that I set up with the ailerons and elevator and later added the rudder to see the differences and found I almost never used the rudder for turning, It was used mainly for doing things like snap rolls where you can use ailerons and rudder together to achieve a particular maneuver but for turning alone I found the ailerons where all I used, So in short which ever control surface is used for turning should go to the right stick with the elevator and with ailerons the rudder is put to the left stick because it will be less used with a aileron plane. I hope this helped you understand the setup a little better and have fun.
Dauntae
Dauntae is offline Find More Posts by Dauntae
Old Dec 16, 2001, 07:15 PM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Move the rudder servo to channel 1!!!!! You have it on chanel 4 right now.
Gene Bond is offline Find More Posts by Gene Bond
Left and right stick config on jr xf421 chargin Electric Plane Talk 3 Jan 02, 2002 08:35 AM
Question for mounting pico servo on Pico Stik xadmin Foamies (Kits) 7 Dec 09, 2001 10:41 PM
APC prop on a pico stik F balajiramani Parkflyers 8 Oct 22, 2001 02:33 PM
alierons on a pico stick singlespeed7 Parkflyers 4 Sep 09, 2001 04:15 AM
CG on Pico/Lite Stick??? deadcell Parkflyers 1 May 20, 2001 04:32 AM
