Old Mar 06, 2004, 09:39 AM
jcarstan is offline
Find More Posts by jcarstan
Dunetop Flyer
jcarstan's Avatar
Cape Cod, Mass., USA
Joined Dec 2002
Dornier Do-335 "Pfeil" Build
Just saw the "What kind of plane was that thread" and thought that some of you might be interested in the building of the Dornier Do-335 "Pfeil", also known as "Aardvark" or "Anteater". You either like or dislike the shape of this thing. Beauty is in the eye of the beholder.
Started a couple of months ago with plans by Ted Biggs for a twin Speed 400 electric. The original has a wingspan almost the same length as the fuselage. TFLG suggested a larger wingspan for a PSS plane, and since I don't know how to cut wings, I got a set of Patton ME-262 cores which are fairly close to what the Do-335 wing looks like. Version 4 of the Do-335 tested longer wingtips and this is the plane I settled on.
For those interested, there is an excellent book on the Do-335 by Marek Rys (Aircraft Monograph series #15) which is loaded with 3 views and color schemes.
First off I made the templates for the plane from the plans. Overall length is 39" and wingspan eventually came out at 52"
jcarstan is offline Find More Posts by jcarstan
Old Mar 06, 2004, 09:41 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Both halves sawed out of EPP and the template station lines have been marked.
Old Mar 06, 2004, 09:43 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Fuselage has been shaped using sandpaper and drywall sanding screens.
Old Mar 06, 2004, 09:44 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Radio gear located and carbon tubes installed.
Old Mar 06, 2004, 09:47 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Tail parts completed. Here I used the TFLG method of covering 2mm coroplast with 1/16" balsa. Since the bottom vertical fin will come in for some heavy abuse, I used basswood on the leading edge and tip.
Old Mar 06, 2004, 09:51 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Bottom parting plate (I guess that is the term). 1/32 ply is used for both surfaces. Rare earth magnets will be placed in the cups on the fuselage. I then ended up using a steel disk in the large hole and another rare earth magnet in the aft hole. Since two magnets will line up by themselves this will ensure fore and aft alignment. Since the rear of the fuselage angles up steeply on the bottom I am hoping that the lower fin will easily separate on landing without damage. We'll see. At least this part can be easily duplicated and replaced.
Old Mar 06, 2004, 09:53 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Wing glued to fuselage with fillets per Hellcatman's instructions. Don't know why I didn't carry them all the way forward. Brain fade. Needed to spend time filling this area in. Also attached balsa wingtips since I didn't want the ailerons all the way to the tip.
Old Mar 06, 2004, 09:56 AM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
This is where I am now. Tail in place, spackled, taped ready for covering. Have to get a few six packs first. Least favorite part of building but have to do this to get to the part I love - painting.
Old Mar 06, 2004, 10:32 AM
SJ is offline
SJ
Find More Posts by SJ
SJ
SJ's Avatar
Denmark EKCH
Joined Apr 2001
REALY nice!!
SJ is offline Find More Posts by SJ
Old Mar 06, 2004, 11:35 AM
dcairns is offline
Find More Posts by dcairns
David Cairns
dcairns's Avatar
Orange, CA
Joined Apr 2002
Cool !!! It is great to see unusual subjects being modled.
dcairns is offline Find More Posts by dcairns
Old Mar 06, 2004, 11:55 AM
surfimp is offline
Find More Posts by surfimp
Feeling FrSky
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Very Nice! Zee Germans Are Coming!
Steve
surfimp is offline Find More Posts by surfimp
Old Mar 06, 2004, 01:15 PM
Kodman is offline
Find More Posts by Kodman
Cordova, Alaska
Joined Feb 2003
jcarstan,
Very nice job. Can't wait to see the finished product and hear the flight report. I guess I will have to find another plane to build, since you stole my idea, or maybe I'll just continue to be a follower.
Tony
Kodman is offline Find More Posts by Kodman
Old Mar 06, 2004, 01:32 PM
nwoods is offline
Find More Posts by nwoods
Retired Slope Racer
nwoods's Avatar
SoCal
Joined May 2003
that hinged elevator just looks so....odd.
Cool build though!
NW
nwoods is offline Find More Posts by nwoods
Old Mar 06, 2004, 02:05 PM
jcarstan is offline
Dunetop Flyer
jcarstan's Avatar
Joined Dec 2002
Thanks for the nice comments guys.
kodman - there are a number of variants to build. The ones below plus a night fighter and a piston/jet version for starters. Go for it!!
nwoods - the elevator does look "odd" but then the whole plane does. I mean, a round long nose for an inline engine?! It's an odd one for sure.
Jan
Old Mar 06, 2004, 02:49 PM
spitfirem9 is offline
Find More Posts by spitfirem9
Blue skies forever!!
spitfirem9's Avatar
Orange County, CA
Joined Nov 2003
I built an EPP Do 335 several years ago for combat. It flew great. 39" long with a span of 45". I am currently building a scratch-built fiberglass version (48"span). The wing, tails, and fuselage templates are finished. The fuse will be a lost-mold. Here's a couple of photos of my EPP Arrow:
Jeff Vosburg
spitfirem9 is offline Find More Posts by spitfirem9
Discussion Ted Biggs/ Dornier DO-335 "Pfiel" St. Martin Scale Kit/Scratch Built 124 Feb 26, 2009 03:48 PM
Dornier Do 335 Arrow spitfirem9 Scale Fuel Planes 17 Dec 07, 2004 02:08 AM
Dornier Do 335 Arrow spitfirem9 Slope 9 Jun 17, 2004 06:02 PM
Dornier Do.335 research questions.... bipeflyer Scale Kit/Scratch Built 7 May 10, 2003 05:22 PM
