Old Jan 04, 2014, 09:58 PM
dirtrider2002 is offline
Find More Posts by dirtrider2002
Joined Jan 2007
flyguy 96
So I decided to upscale the flyguy 62 plans to make a more than lifesize version. Overall length is a little over 96 inches, putting him at just over 8 ft tall! Just mounted the motor and servos tonight, and hoping to get the wiring done tomorrow afternoon. Hopefully he will fly haha, but i think he will look awesome in the air if all gpes well.
dirtrider2002 is offline Find More Posts by dirtrider2002
Old Jan 04, 2014, 10:13 PM
Joined Jan 2007
pic with the motor and servos mounted
Old Jan 05, 2014, 02:49 AM
ttersu is offline
Find More Posts by ttersu
All can fly...Launch stronger!
ttersu's Avatar
France, Centre, Romorantin-Lanthenay
Joined Oct 2013
Wow, Nice
How are you going to paint it?
ttersu is offline Find More Posts by ttersu
Old Jan 05, 2014, 05:46 AM
Joined Jan 2007
Haven't decided on the paint yet, I want to try and get it up in the air first haha.
Old Jan 05, 2014, 06:34 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
Might be a good idea!
Old Jan 05, 2014, 09:24 AM
birdofplay is online now
Find More Posts by birdofplay
Retired CAD guy
birdofplay's Avatar
United States, IN, Indianapolis
Joined Dec 2005
WOW 8' that'll BE IMPRESSIVE.
Did you simply Scale the original ?
What material did you use ?
Scaling would make the slots and tabs larger so 9mm depron might work without
any adjustment.
96 / 62 = 1.54 to that's just about right for 9mm use. (mm seemns much stronger than 6mm.
I have used it in upscaled propinslot jets lately. Mig-29 and F-22 and F-15
Please Post your build and progress and equipment used if you can.
Bob
Hoosier Cutout Service
birdofplay is online now Find More Posts by birdofplay
Old Jan 05, 2014, 09:37 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
+1 for the Logs! Like this I should be able to build a Flying Super-Daddy for his Birthday
Old Jan 05, 2014, 09:40 AM
Joined Jan 2007
I bought 2 4'x8' sheets of the r max foam from lowes, 1/2" thick. I put the fly guy 62 plans into autocad and scaled them up. Had to adjust a few things here and there to keep the slots and tabs correct. Going to the hobby shop this afternoon to pick up some carbon fiber to reinforce a few places. I'll get more pics and info up this evening.
Old Jan 05, 2014, 09:49 AM
ttersu is offline
ttersu's Avatar
Joined Oct 2013
Ok, We are waiting for you!
Old Jan 05, 2014, 01:33 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
The only reason I don't use r-max is that is has that low temp plastic skin.
I cut everything on my CNC and the low temp stuff "melts" on my bit
and builds up and ruins the edges.
I switched to 1/2" OC foam then decided that it did not cut well with the new eco formulae.
so I am using 9mm depron now for new designs and converting some old ones
as appropriate.
r-max works good if it's hand cut and CF or wood supported as necessary.
Best
Bob
Old Jan 05, 2014, 02:05 PM
ewo is offline
ewo
Find More Posts by ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Hi Bob ....
Just out of curiosity ? What bits do you use?
and feedrate ? Im cutting with 1/16 and 1/8 , 1/4" endmill for pocketing .
ewo
edit here. Hows the weather there in indy ?
I have 7 " of heavy snow right now and the temps expected to drop to 13 below last i heard !
ewo is offline Find More Posts by ewo
Old Jan 05, 2014, 02:40 PM
Joined Jan 2007
Yeah unfortunately all I have for cutting is my x-acto haha, so no problems there. But yeah, definitely will be adding bracing in where needed as the feet and arms have a good deal a flex in them with just the foam.
Old Jan 05, 2014, 03:01 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Sorry DR.
Just a little shop talk between friends.
Please carry on . looking forward to your maiden report !
Old Jan 05, 2014, 03:14 PM
Retired CAD guy
birdofplay's Avatar
Joined Dec 2005
EWO:
My Shopbot uses a 5 speed PC Router.
Mostly I use the lowest setting 10k
1/8" bit spiral upcut and 1ips or there abouts for my best looking edge.
The OC Foam seems to have a "grain" embedded in it and chips out the edges
across the 4' but no so much the 8' .
I take OFF the plastic covering both sides that it comes with as IT TOO is low temp and creates probs.
THE SNOW is HEAVY and THICK for now.
I have my diesel truck PLUGGED IN and my Generator at the ready..
I've done -20 F when I lived in Mich but it wasn't fun.
It's still pretty warm here FOR NOW !
Huncker Down for Mon and Tuesday !!!
Bob
Old Jan 05, 2014, 03:28 PM
ewo is offline
ewo
ewo
ewo's Avatar
Spencer In.USA
Joined Oct 2003
Thanks Bob .
I have been cutting at 75 ipm . I think i need a new bit and also need to slow it down a little.
My inside and outside cuts are burnishing just a little bit.
Still pretty ok temps here now too but monday and tuesday will just kill this old man !
Build Log Build: Birdofplay 62" Flyguy Otto Dieffenbach Foamies (Scratchbuilt) 432 Dec 23, 2015 09:03 PM
Discussion Foamie Flyguy in 4 sizes Otto Dieffenbach Foamies (Scratchbuilt) 1665 Aug 14, 2015 06:14 PM
Discussion 23" Indoor sized Flyguy Petefoss Scratchbuilt Indoor and Micro Models 2 Jan 27, 2014 01:14 PM
