Old Jan 04, 2014, 11:39 AM
FyreSG is offline
Find More Posts by FyreSG
Vids: YouTube.com/FyreSG
FyreSG's Avatar
Singapore, Singapore
Joined Apr 2012
New Product
WLtoys V966, V977, V988, V930 Power Star Helicopters (previously WL925, WL926)
My friends over at Banggood informed me of the upcoming WLtoys helicopters.
WL966 6-Channel Power Star 1 (3-axis & 6-axis modes)
BG: http://www.banggood.com/WLtoys-V966-...-p-914250.html
WL988 4-Channel Power Star 2 (6-axis mode)
BG: http://www.banggood.com/WLtoys-V988-...-p-914249.html
Highlights for WL925
- Battery: 1S 3.7V 25C 250mAh
- Unknown brushed motor, could be same as V922
- Main Rotor Diameter: 245 mm; Body Length: 245 mm; Height: 77mm
WL977 6-Channel Power Star X1 (3-axis & 6-axis modes)
BG: http://www.banggood.com/WLtoys-V977-...-p-914247.html
WL930 4-Channel Power Star X2 (6-axis mode)
BG: http://www.banggood.com/WLtoys-V930-...-p-914248.html
Highlights for WL926
- Battery: 1S 3.7V 25C 450mAh
- Motor: brushless outrunner 1106
- Main Rotor Diameter: 245 mm; Body Length: 270 mm; Height: 77mm
Exciting new products!
FyreSG is offline Find More Posts by FyreSG
Old Jan 04, 2014, 11:48 AM
joeclone is offline
Find More Posts by joeclone
joeclone's Avatar
Joined Jan 2013
There's already another post started on this same subject do we need another? Maybe you could contribute your info on that post instead.
joeclone is offline Find More Posts by joeclone
Old Jan 04, 2014, 11:50 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
I just discovered that post! As BG translated to English wrongly, that thread contained a few mistakes. It's easier for me to put the correct information here.
Old Jan 04, 2014, 11:52 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
My translation of the Chinese specifications from WLtoys
WL925 6CH
1. Flybarless CP helicopter, aerodynamically designed to achieve unparalleled stability
2. Battery 1S 3.7V 250mAh 25C
3. Coreless tail motor (8520)
4. Transmitter has 3D aka Idle-Up switch, Throttle Hold switch, large LCD, low voltage warning. Hovering midpoint setting allows setting of the hovering point.
5. Transmitter supports switching between 3-axis & 6-axis gyro modes
6. 3D Mode activates 3-axis gyro, enables aerobatics such as flips, rolls inverted flight and funnels
7. Normal (aka 6G) activates 6-axis gyro, allows stable flight, suitable for beginners
8. USB charger 2 at a time
9. Flying weight: 43.5g; Flight time: 6-7 mins
WL925 4CH
1. Flybarless FP helicopter, aerodynamically designed to achieve unparalleled stability
4. Transmitter has D/R switch, Throttle Hold switch, large LCD, low voltage warning. Hovering midpoint setting allows setting of the hovering point.
5. Helicopter flies at 6G mode using 6-axis gyro, allows stable flight, suitable for beginners
6. USB charger 2 at a time
7. Flying weight: 41.5g; Flight time: 8-9 mins
WL926 6CH X1
2. Battery 1S 3.7V 450mAh 25C
3. Brushess outrunner (1106) motor
6. 3D Mode activates 3-axis gyro, enables aerobatics such as flips, rolls inverted flight, funnels and tick-tocks
9. Flying weight: 48.5g; Flight time: 6-7 mins
WL926 4CH X2
7. Flying weight: 46.5g; Flight time: 7-8 mins
Old Jan 04, 2014, 12:09 PM
JesseFDB is offline
Find More Posts by JesseFDB
JesseFDB's Avatar
Belgium, Flanders, Lanaken
Joined Dec 2013
Looks nice!
V926 seems an extended tail boom version of the V925.
@ FyreSG your pics for the V926 X1 & X2 are reversed, blue one is the X1.
JesseFDB is offline Find More Posts by JesseFDB
Old Jan 04, 2014, 12:14 PM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
Not really - V926 is brushless while V925 is brushed. The description on 3D aerobatics specifically mentioned "tick tocks" for the brushless V926.
Thanks! I've corrected the wrong photos.
Old Jan 04, 2014, 12:19 PM
JesseFDB is offline
JesseFDB's Avatar
Joined Dec 2013
Nice that the V926 is brushless! I'm surprised it's not more expensive than the V925.
Still it seems extended, just look at the pics and the position of the same length main rotor blades. And your stats do indicate a 25mm larger body length, while all other sizes remain the same.
Old Jan 04, 2014, 02:30 PM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
Yes, V926 is extended. I had meant "not just..." instead of "not really".
Old Jan 05, 2014, 07:35 AM
asanovrus is offline
Find More Posts by asanovrus
asanovrus's Avatar
Ukraine, Crimea, Bakhchysarai
Joined Mar 2012
finaly they did it. I was looking for bigger flybarless gyro helicopter, they all were micros: f48, v933,v944,v955 etc
any info on protocol they use?
asanovrus is offline Find More Posts by asanovrus
Old Jan 05, 2014, 09:55 AM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
I have asked a series of questions and this is one of them. Let's hope BG is able to get the answers from WLtoys soon.
Old Jan 05, 2014, 07:57 PM
jl1252 is offline
Find More Posts by jl1252
jl1252's Avatar
United States, CA, Grass Valley
Joined Feb 2012
These look suspiciously similar to the Solo Pro 125/126 and their cousins the HeliMax 100FP/CP/SS....
jl1252 is offline Find More Posts by jl1252
Old Jan 05, 2014, 08:14 PM
zadaw is offline
Find More Posts by zadaw
Hong Kong
Joined Jan 2010
This is likely to be their pedigree. A large proportion of Walkera's design team was poached by a large toy company and the San Huan 6050 is one of their designs. It looks like that WL Toys has commissioned that company to make the heli but using its transmitter. The Solo Pro 125A itself is a clone of the Genius CP. If you look at that, the 3D performance exceeds that of the V922 with stock transmitter. The V922 can compete with Walkera effectively on its own, but I imagine that WL Toys now wants to finish off Walkera completely in the micro CP market. If there are a lot of compatible spare parts with Walkera, then it would hit Walkera even harder.
SH 6050 3D 2.4GHz 6 Channel Remote Control RC Helicopter Mode 2 RTF (1 min 40 sec)
Correction: they are likely to be designed by ex-engineers from Nine Eagles as reported from another thread.
zadaw is offline Find More Posts by zadaw
Old Jan 06, 2014, 08:12 AM
asanovrus's Avatar
Joined Mar 2012
how about MJX? they screwed up with f48 but will they make a big flybarless heli?
Old Jan 08, 2014, 12:13 PM
FyreSG is offline
FyreSG's Avatar
Joined Apr 2012
WLtoys have renamed "V" to "WL"
BG confirmed with WLtoys that the heli is named WL925 and WL926 instead of V925 and V926. "V" stood for "volitation".
Old Jan 08, 2014, 03:07 PM
dankar04 is online now
Find More Posts by dankar04
Tucson, Az
Joined Feb 2007
Going to be intertesting to see how market is another year. Looks like WL toys decalred War on Walkera. I like Genius c/p but new ones are way over priced.
They changed board on Mini c/p and I don't like Super c/p. I don't know who runs the show at Walkera but they should be replaced ASAP.
dankar04 is online now Find More Posts by dankar04
Help! Wltoys V959 Upgraded V222 6-Axis RC Quadcopter problem! salamala Micro Helis 8 Oct 03, 2014 09:50 AM
Help! WLToys V222 Won't Bind FiftySixer Multirotor Talk 4 Jul 13, 2014 07:55 PM
Discussion WLtoys v911 VS WLtoys V912 Santoyo Micro Helis 7 Feb 27, 2014 09:19 PM
Help! WLToys V222 Won't Bind to Tx FiftySixer Mini Multirotors 7 Jan 17, 2014 07:02 PM
Discussion WLtoys V949 + MultiWii get ready! geovas Mini Multirotors 0 Sep 30, 2013 04:35 AM
