HobbyKing Turnigy 1/16 4WD Monster Beetle
Ready-to-run brushless powered off-road buggy
Turnigy 1/16-scale Monster Beetle comes RTR and is Brushless-Powered!
At 1/16-scale, the Turnigy Monster Beetle from HobbyKing measures only 11 inches long which gives it the ability to not only tackle off-road terrain but also indoor running. It comes ready-to-run with only requiring a battery pack and four “AAA” batteries for the transmitter. It is powered by a 4800Kv brushless motor system complete with a 2.4GHz radio and high-torque steering servo. The 4WD chassis is equipped with adjustable oil-filled shocks, aluminum driveshafts, anti-sway bars, metal diffs, dogbones and a fully adjustable suspension.
Just add batteries and you are ready to go!
Turnigy 1/16 4WD Monster Beetle (RTR)
Motor:4800Kv brushless in-runner (20x40mm)
ESC:25A brushless (w/ reverse)
Battery:2S LiPo w/XT-60 connector
Max battery size:(max size 100x40x25mm)
Servo:15g high-torque micro
Drivetrain:4WD w/ dual differentials
Length:11 in. (280mm)
Width:8.3 in. (210mm)
Height:5.9 in. (150mm)
Ground Clearance (adj.):0.8 to 1.6 in. (20 to 40mm)
Top Speed:25mph on standard system
Item no.:9249000745-0
Price:$96.60
KEY FEATURES
  • Pre-installed brushless motor power system
  • Pre-installed high torque steering servo
  • 4WD drivetrain system
  • Fully adjustable suspension
  • Oil-filled shocks
  • Adjustable toe and camber links
  • Aluminum driveshafts
  • Metal diffs, diff cups & dog bones
  • Front & rear anti sway bars
  • Lightweight 2.4GHz Tx & Rx included
REQUIRES
  • 7.4v (2S) 1000+mAh LiPo battery pack
  • Four "AAA" batteries for Tx
Learn more—HOBBYKING!
Old Jan 02, 2014, 01:33 PM
SoloProFan is online now
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I thought this car had been around for a few years by now?
SoloProFan is online now Find More Posts by SoloProFan
Latest blog entry: Pictures of various boats
Old Jan 02, 2014, 02:43 PM
Paul Onorato is offline
Find More Posts by Paul Onorato
Paul Onorato's Avatar
United States, CT, Brookfield
Joined Jun 2013
It was most likely updated.
Paul Onorato is offline Find More Posts by Paul Onorato
Old Jan 02, 2014, 05:09 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Perhaps someone who has the older version can shed some light on the changes?
Old Jan 02, 2014, 05:59 PM
jerrysimon is offline
Find More Posts by jerrysimon
Crashing IS Flying
jerrysimon's Avatar
Joined Jan 2001
Yes I had been looking at one of these but an ORTR one.
https://www.hobbyking.com/hobbyking/...FQPmwgodcWYAnQ
Specs are very similar except the motor looks hotter ?
Spec.
Motor: Brushless Inrunner(2040)
ESC: 25A Brushless (with Reverse)
Battery: 2S LiPo (100x40x25mm MAX SIZE) w/ XT-60 connector [Required]
Servo: 15g Micro
Traction: Full Time 4WD, Twin Diff
Length: 280mm
Width: 210mm
Height: 150mm
Groung Clearance: 20~40mm Adjustable
Top Speed: 40km/h on standard System
Required.
2S 1000mAh LiPo (or larger)
Radio System (Rx/Tx)
Jerry
jerrysimon is offline Find More Posts by jerrysimon
Old Mar 25, 2014, 04:47 AM
nigelsheffield is offline
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
It's the same car but with a tx and RX.
Great car, had mine for over a year now, servo is poor and had to be replaced after a couple of months, ESC is marginal and I replaced with hk30 anyway to make it work on life cells. Its a tough little car and REALLY fast and fun.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Mar 26, 2014, 01:06 AM
SporadicIdiocy is offline
Find More Posts by SporadicIdiocy
Sakura Ultimate graduate
SporadicIdiocy's Avatar
Richmond B.C. Canada
Joined Oct 2007
I have the buggy version, fun little rocket on 3S, though need to watch for motor temps.
This looks to have the same spec as before, only now RTR with that lightweight Tx they're pushing.
$97 RTR is a pretty decent deal, though if you have your own Tx and Rx the ARTR version is a better deal.
SporadicIdiocy is offline Find More Posts by SporadicIdiocy
Sold Turnigy 4WD Monster Beetle simplyfly Cars - Cars and Parts (FS/W) 8 Dec 28, 2012 12:40 PM
Wanted Wanted: Spur Gear for Turnigy 1/16 monster beetle FIREWALL Cars - Trucks and Parts (FS/W) 3 Apr 27, 2012 09:41 AM
Sold 1/16th 4WD Monster Beetle Brushless***PRICE DROP,$70.00!!! !! witstick Cars - Cars and Parts (FS/W) 1 Jan 15, 2012 02:45 PM
Discussion 1:5 scale Big Monster Truck 2 stroke 4wd {hobbyking vers} ferral Large Scale Cars 1 Dec 14, 2011 06:38 AM
Question 1/16 Brushless 4WD Monster Beatle from HobbyKing merlin703 Off-road Cars 2 Jul 22, 2011 08:20 AM
