Old Mar 05, 2004, 09:52 AM
Radiofly is offline
Find More Posts by Radiofly
Radiofly's Avatar
Boston, MA
Joined Dec 2003
Universal power supply for motor testing?
I would like to get real world baseline measurements for various motor/prop/airframe installations. Batteries are inconvenient for testing purposes, due to power fluctuations and charge/recharge cycles. So, I'd like to get a variable DC power supply to facilitate testing motors, props, and airframe interactions. I'd like to get something to test up to about 250W motors.
Analog power supplies in the 25-30 amp region cost about $400 or much more. Switching power supplies are less expensive. I think a variable DC switching power supply is Ok to use with electric motors and their ESCs so that may be the least costly way to go.
Has anyone out there rigged up an inexpensive test station? Willing to show pics and details?
Radiofly is offline Find More Posts by Radiofly
Old Mar 05, 2004, 10:40 AM
GordonTarling is offline
Find More Posts by GordonTarling
Supersonic Engineering
GordonTarling's Avatar
UK, Greater London, Uxbridge
Joined Mar 2001
While a switching power supply MAY work with brushed motors and ESC's, don't even think about using one for brushless - you'll fry either the ESC or power supply or both in very short time!
GordonTarling is offline Find More Posts by GordonTarling
Old Mar 05, 2004, 10:58 AM
Dave Hederich is offline
Find More Posts by Dave Hederich
Walled Lake, MI, USA
Joined Feb 2000
Thank you, Radiofly, for bringing up the subject. And thank you, Gordon, for your response. I was just getting ready to order a variable voltage/current power supply for the dual purpose of charging Li cells and bench testing both brushed and brushless motors. All of the power supplies I am looking at are switching. It would have been a huge disappointment to spend a lot of money on a variable switching power supply and learn afterwards that it could not be used to bench test brushless motors!
Dave Hederich is offline Find More Posts by Dave Hederich
Old Mar 05, 2004, 11:29 AM
Radiofly is offline
Radiofly's Avatar
Boston, MA
Joined Dec 2003
I'm glad I asked, too. Thanks Gordon. I wasn't really aware that a switching power supply would be a problem with brushless. Is this due to phase interaction between the switching frequency of the power supply and of the brushless ESC?
Old Mar 18, 2004, 07:24 PM
Radiofly is offline
Radiofly's Avatar
Boston, MA
Joined Dec 2003
For the sake of general interest, I kept wondering why a switched power supply might not be good to use with a brushless ESC. I did contact some ESC manufacturers. They said that a switched power supply would be just fine. Good to know because they are so much cheaper than a capable analog (i.e., linear) supply.
Old Mar 18, 2004, 07:34 PM
rc-eflyer is offline
Find More Posts by rc-eflyer
T:W>1= :>)
rc-eflyer's Avatar
St. Louis, Missouri, United States
Joined May 2002
Why?
rc-eflyer is offline Find More Posts by rc-eflyer
Old Mar 19, 2004, 03:32 AM
vintage1 is online now
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Why? They are just a DC source, same as a battery...
You might need a bit of capacitor at the end of long test leads to make sure the lead inductance doesn't cause problems tho.
vintage1 is online now Find More Posts by vintage1
Old Mar 19, 2004, 06:40 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
Assuming the ripple rating is reasonably low, which it should be on any power supply, a switcher should be no different than a linear. The real difference is in the conversion... Linears dissipate more heat, and are considered more accurate, since there is not a filtering/conversion done after the voltage regulation section. The switchers have more capacitors to filter the input to the power transistors and then again after. The linears have more heat sink to dissipate the high loss of the power transistors.
Again, assuming a quality power supply, there should be no real difference in ripple, which is the significant problem for ANY esc, not just BL.
Gene Bond is offline Find More Posts by Gene Bond
Old Mar 19, 2004, 06:53 AM
RD Blakeslee is offline
Find More Posts by RD Blakeslee
Joined Jan 2002
What protects the power supply from motor start-up surges and reactive loads? The ESC?
- RD
RD Blakeslee is offline Find More Posts by RD Blakeslee
Old Mar 19, 2004, 11:41 AM
jimsky is offline
Find More Posts by jimsky
Trying to defy gravity...
jimsky's Avatar
USA, NY, East Northport
Joined Dec 2003
A properly designed power supply (reguardless of conversion topology) should be immune from short circuiting and typical transient conditions one would encounter during "reasonable" operation.
Look around on eBay for used adustable voltage/current benchtop power supplies from manufactures like Lambda, Sorensen, HP and the like. I recently scored a nice used Lambda LP Series power supply. Just the ticket for doing motor/prop characterizing work.
Jimsky
jimsky is offline Find More Posts by jimsky
Old Mar 19, 2004, 01:13 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Granted we only used it up to 16 Amps, the Kosel power supply we purchased from www.Ramboy.com worked just fine, hooked directly up to the Phoenix 25.
I'm not power supply literate, so I dont know if a Kosel is switched or linear.
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Mar 19, 2004, 01:36 PM
jimsky is offline
jimsky's Avatar
Joined Dec 2003
The Kosel is a "switcher". If the small amount of output voltage adjustment capability that is provided is acceptable for your usage (and an adjustable current limit is not required) than this is a very cost effective solution.
Jimsky
Old Mar 19, 2004, 04:03 PM
Joined Mar 2001
Sorry, chaps, I'm not a technical expert on these matters, but I was clearly told by Matthias Schulze himself (who should know his stuff!) that a power supply should not be used for supplying a brushless ESC and only to use a battery. I think it's something to do with the high voltages produced by the switching transients due to lead inductance, but I could be wrong. Perhaps this only applies to Schulze ESC's ?
Old Mar 19, 2004, 04:27 PM
RagnarA is offline
Find More Posts by RagnarA
RagnarA's Avatar
Wichita,Ks
Joined Jul 2003
With due deference to Mr. Schultze( I have one of his 330d's) I am a ham radio operator. If a switching or linear power supply was going to fry a $60 esc, it'd fry a $500 ham transciever or a $1500 base unit. I routinely use a MFJ 25 amp variable voltage switching power supply for all ham and RC radio uses (testing). The problem is going with the cheapest power supplies that lack adequate filtering. Also in older units, the capacitors in the filtering circuit can break down. I've read a discourse by Mr. Schultze where I believe he points out that is the problem. If I wanted a 0-30 volt, 40 amp supply, I'd probably use a Dymond Ham Radio power supply. Last time I checked it was about $189. I bought a new lab quality, digital Chinese linear power supply a while back, just for testing and large lipo pack charging purposes. MFJ's good, Alinco's good, Dymond's good, etc. Samlex will work. Check with Ham Radio Supply Houses. I got my Chinese digital unit off Ebay, new, about 1/5 the cost of a used Hewlett Packard. If you use a really cheap and dirty power supply for a charger, put a 12 Volt, lead-acid storage battery between the power supply and the equipment, will filter the output, but only works for 12 volt applications. Cheers.
RagnarA is offline Find More Posts by RagnarA
Old Mar 19, 2004, 04:34 PM
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
- RD
a sizeable capacitor like on the Torcman teststand ( the black thing on the right hand side) should do the trick:
and it is to protect the esc , exactly like vintage said.
WimH is offline Find More Posts by WimH
Discussion Power Supply For Bench Testing The L Batteries and Chargers 11 Apr 04, 2007 05:43 AM
Discussion Power Supply For Bench Testing himszy Submarines 15 Feb 07, 2006 12:02 AM
Wanted Power Supply for Motor Test Stand Dynomike Aircraft - Electric - Airplanes (FS/W) 1 Aug 30, 2005 10:59 PM
PC Power Supply For Motor Testing Tom Frank Power Systems 1 Dec 08, 2004 06:00 PM
Power supply for bench testing Phoenix controllers rakm Castle Creations 5 Mar 10, 2004 10:33 PM
