Old Mar 04, 2004, 10:44 PM
pequeajim is offline
Find More Posts by pequeajim
Where did that tree come from?
pequeajim's Avatar
New Holland, PA USA
Joined Aug 1999
SOme help with a power system
I have a Extreme FLight RC Edge 540 profile that I want to convert to electric. I have some experience with electric helis, but not with planes.
THe plane is the same in size as the Morris profile kits,
40-50 sized, 45" ws, 700 sq. in. and around 4.5 lbs as a glow setup.
I am looking for suggestions for motor/prop/GB and batteries.
I would like to go LiPos.
Any help would be appreciated.
Jim!
pequeajim is offline Find More Posts by pequeajim
Old Mar 05, 2004, 01:36 AM
Larry3215 is offline
Find More Posts by Larry3215
Permanently Banned
Larry3215's Avatar
Gig Harbor, Washington, United States
Joined Sep 2003
Mega 22/45/3
MEC super box 3.125/1
Castle Phoenix 80 (or 60)
UBEC or SBEC
6S1P Irate 2200
APC E 16x10
You will be pulling rite at 22 amps static, around 470 watts.
Motor and controller run very cool.
I'm flying this combo in a Freedom 3D at exactly 64 ounces AUW. Thrust is aprox 85 ounces. Speed is good. I like it
Larry.
Larry3215 is offline Find More Posts by Larry3215
Old Mar 05, 2004, 06:27 AM
pequeajim's Avatar
New Holland, PA USA
Joined Aug 1999
Larry
Thanks for the information!
Will this motor have enough power to easily hover the plane?
Jim!
Old Mar 05, 2004, 07:32 AM
Mike Parsons is offline
Find More Posts by Mike Parsons
Forgot how to fly
Mike Parsons's Avatar
Atlanta, Georgia
Joined Oct 2002
Jim,
I think you need to go with the Mega 22/30/2 geared 4:1 if you can swing a 17X10. This will put you at around 52 amps, your weight should be around 95 oz give or take on a 4S3P and your thrust about 131 (or a T/W of 1.38:1).
If you cant swing a 17" prop, you can either gear down and swing a smaller prop or incerase your voltage (ie: 5S3P). This combo will hover and pull out.
I am almost complete with converting the Mini3D. Chris is a great guy with a very nice product line.
-mike
Mike Parsons is offline Find More Posts by Mike Parsons
Old Mar 05, 2004, 06:09 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
My combo hovers and pulls out nicely at the 64 oz weight. It will depend on your AUW.
Mike's set up will work fine too. But 12 cells will cost twice as much and at 52 amps everything will run very hot.
If you are going to go with 12 cells, I recomend 6S2P with the bigger, low Kv Mega. You can prop for as much as 35 amps and you will still be running a lot cooler than Mikes system and have 50% more power for the same price
Can you say 2 to 1 thrust ratio
Larry
Old Mar 05, 2004, 06:35 PM
Forgot how to fly
Atlanta, Georgia
Joined Oct 2002
Twice as much cost but twice the the duration. Weight is the issue here. This plane is ending up around 100 ounces. My Funtana is at 102 oz AUW, but the 22/30/2 gives me a thrust of 150 oz. My Kyosho Sukhoi also runs a 22/30/2 and gives up about 135 oz of thrust. Both systems run in the mid 50's with no problem.
Either system will work, but I think the 22/30/2 is better suited for this plane. I was over at Extremeflightrc last week visiting Chris and this is a really nice plane. Now if I can just get my hands on the 68" Yak
Old Mar 05, 2004, 06:53 PM
Warren is offline
Find More Posts by Warren
Thermal Junkie
Warren's Avatar
San Diego - California - USA
Joined Feb 2001
I like the 22/30/2 option on 10 cells as well.
I am running mine with a 16x8 at 5:1, pulling close to 100 ounces and low 40's in amperage in my Freedom.
Warren is offline Find More Posts by Warren
Old Mar 05, 2004, 08:34 PM
pequeajim's Avatar
New Holland, PA USA
Joined Aug 1999
I also spoke with Ken at Mega and he's going to run some numbers and make a suggestion. Between whhat he tells me and what you guys have posted, hopefully I can some up with an intelligent choice.
Thanks for the help.
Now if I can figure out how to mount the 4s3p pack on a profile fun fly??
lol...
Jim!
Old Mar 05, 2004, 08:37 PM
Permanently Banned
Larry3215's Avatar
Joined Sep 2003
Don't forget the out runner choices.
Larry
Just got an ElectroStreak...need help with power system. msg73 Electric Plane Talk 11 Nov 03, 2005 09:46 PM
Help with power system on superstar ep savydad Power Systems 12 Aug 09, 2005 11:04 PM
Help with power system for 3D Plane joystix 3D Flying 4 Mar 16, 2005 07:58 PM
Need help with power system Oian Power Systems 2 Mar 04, 2005 01:20 PM
Need help with power system for the Slinger & Fundango ddekel Power Systems 4 Jan 10, 2005 05:00 PM
