Pro-Line December Product Releases
Including scale beadlock wheels, buggy front tires, and Ford F-150 Raptor body.
Four new products from Pro-Line for scale off-road trucks, 2WD buggies and short course trucks!
DENALI 1.9” BLACK/BLACK BEAD-LOC 8-SPOKE WHEELS
Pro-Line has release two scale wheels for trail trucks and rock crawlers and the first is the Denali 1.9’s. It is a beadlock wheel that securely clamps the tire onto the wheel with now gluing required. The two rings are constructed of metal with the inside having a smooth surface while the outside is decorated with a scallop type patter. Giving the Denali its scale looks is its 8-spoke configuration with D-shaped holes and scale lug nuts for extra detail.
KEY FEATURES
  • Rugged 8-spoke Denali wheel style
  • Molded lug nuts for scale look
  • Fits all of Pro-Line’s popular 1.9” rock crawling tires
  • Satin black finish
  • Strong and durable nylon wheel material
  • Dual Bead-loc rings for scale looks and performance
  • Made in the U.S.A.
ITEM NO. 2747-15 PRICE $27.16/pair
FAULTLINE 1.9” BLACK/BLACK BEAD-LOC 10-SPOKE WHEELS
Here is the second scaler wheel for off-road trucks and rock crawlers, the FaultLine 1.9’s. It features a cool 10-spoke design wih an alternating star pattern for a realistic appearance. It is a true beadlock wheel with two metal rings that hold the tire onto the wheel. Molded on the outside ring is a scalloped design and the rear ring is smooth for maximum clearance.
KEY FEATURES
  • Rugged 10 spoke FaultLine wheel style
ITEM NO. 2748-15 PRICE $27.16/pair
PRE-CUT FLO-TEK FORD F-150 RAPTOR SVT CLEAR BODY
Stop struggling with getting your short course body cut out perfectly because Pro-Line has already done it for you with the Pre-Cut Flo-Tek Ford F-150 Raptor SVT body. Not only are all four wheel wells cut out for you, but the difficult to cut front and rear air vents are as well. This body offers awesome looking styling with the advantage of Flo-Tek technology that helps to minimize the parachute effect.
KEY FEATURES
  • Pre-Cut for maximum convenience
  • Bold Ford F-150 Raptor SVT styling
  • Flo-Tek technology specifically designed to minimize parachute effect
  • Bolt on modular number and side dam plates
  • Exceptional detail and style
  • Also available un-cut and in a pre-painted version
  • Made with crystal clear genuine GE Lexan
ITEM NO. 3366-17 PRICE $49.26
WEDGE SQUARED 2.2” 2WD Z3 OFF-ROAD CARPET BUGGY FRONT TIRES
The Wedge Squared tires are intended for the ever growing indoor carpet off-road racing scene. This tire offers twice as much tread as its predecessor to provide more steering. It is also fitted with a true drop-in bead that requires no hand fitting. These tires are super narrow and low-profile with hook shaped pins that give you just the right amount of steering without being too grabby. The Z3 carpet compound was engineered specifically for the needs of the indoor racer and can offer grip on a variety of different surfaces.
KEY FEATURES
  • Drop-in bead does not require cutting or hand fitting
  • Twice as many pins as the original Wedge tire
  • Super narrow and low profile 2WD buggy front tire
  • Hook shaped tread provides consistent steering
  • Specially formulated Z3 carpet compound
  • Combine with Pro-Line’s Pin Point Rears for an unbeatable combination
ITEM NO. 8230-103 PRICE $15.26/pair
Learn more—PRO-LINE!
There are no posts
News Pro-Line – Late October Product Releases Paul Onorato Car Talk 1 Oct 30, 2013 01:26 PM
News Pro-Line / Late September Product Releases Paul Onorato Car Talk 0 Sep 24, 2013 11:01 PM
News Pro-Line / Late July Product Releases Paul Onorato Car Talk 0 Jul 31, 2013 02:29 PM
News Pro-Line / Late June Product Releases Paul Onorato Car Talk 2 Jun 28, 2013 12:53 PM
